Question about HP DeskJet 5550 InkJet Printer
HP 5550 stops in middle of job
A window says that the black print cartridge is not compatible with the printer.  But it is the correct number (56) and it was working fine till it stopped, so it has ink.
  • pbw6 Jan 11, 2009
    I'd need advice on how to do this.
    Genius:
  • 1,239 Answers
Inkjet printers have the major disadvantage of having often having clogged print head cartridges that can be very annoying in the long run. Though advanced inkjets might possess their automatic print head cleaning process, this might not work every time. The problem might be because a layer of thick ink might have blocked the holes of the printer’s head.
There are some useful ways to get the printer’s head clean without halving to buy another cartridge.
Solution 1
Once you remove the ink cartridge from the printer, you can make use of the Isopropyl Alcohol, and put at maximum of 10 drops in the ink cartridge. You will find a hole there, in which the ink usually runs from the ink cartridge to the head of the printer. When done, you can put the cartridge back in the printer and run the auto cleaning process from the printer’s option in order to clean the blocked holes of the cartridge. I would suggest you to run print tests first and once you are satisfied with the results, you can start using the printer normally.
Solution 2
Using a syringe and some alcohol to unblock the holes can also be very effective.
  • Step 1: Remove the cartridge from the computer
  • Step 2: With the syringe, take in some alcohol and put in some drops in the tiny hole where the ink runs from the ink cartridge to the head of the printer.
  • Step 3: When done, put the cartridge (only where the tiny holes are found) in some warm water. If some ink runs in the water, it means that the holes have been unblocked.
  • Step 4: Hence, let the alcohol act for 20 minutes on the ink before putting the cartridge back in the printer.
  • Step 5: Run some test prints before using the printer normally.
Note: I would suggest you to do an automatic head cleaning each time before any printing task. Hence it will reduce the risk of having the print heads blocked by dried ink.
Posted on Jan 11, 2009
    Sergeant:
    Scholar:
  • 199 Answers
Just remove the cartridges clean the brown dotted circuit of the cartridge and reinsert the carttridges and check if it gives the same error.it is quite possible that the cartridge needs replacement.as the circuit of the cartridge is gone faulty.
    Genius:
  • 1,199 Answers
Thids sounds like a curruption in the printers driver and software! re-install software for printer restart your pc and try again!
  • HP Master
  • 19,396 Answers
Try cleaning the cartridge sensor.
  • Ginko
    Ginko Jan 11, 2009
    Try cleaning the cartridge sensor inside the ink carriage, use isopropyl alcohol and cotton to do this.
    If that did not work, then the printer new cartridge has a defective chip, take it back to the retailer.
  • Ginko
    Ginko Jan 11, 2009
    The sensor is the metal plate contact inside the ink slot, on the printer, just clean it with cotton tips and alcohol, if that is not a problem, then usually it is a faulty cartridge
How to stop the top light from blinking?
Make sure the installed cartridges are original and the right numbers 56 black and 57 tri-colour
Nov 22, 2011 | HP DeskJet 5550 InkJet Printer
I have an HP 5550 printer. The Ink Cartridge light continually blinks (and nothing prints) when I have both the colored and black cartridges installed. When I remove the black cartidge, it works fine and...
More than likely you have either a defective 56 (black) cartridge or it's empty. If you have Windows XP you may go to control panel and select printers and then right click to get to properties and preferences. From one of those you can get maintenance and attempt to do a clean and see if that works. If you have a cartridge refiller in your area take the cartridge to them and get it weighed....they'll know if it's empty or not by the weight. If you're lucky enough to have a kitchen scale that weighs in gms then weigh it yourself...if it's empty then it will problem be in the mid 20's vs. mid to upper 30s when it's full. EBAY has lots of 56 cartridges for sale and they will usually work just fine. The tri-color ones are more of a crapshoot.
Aug 14, 2010 | HP DeskJet 5550 InkJet Printer
Hp clj 5550 not printing cyan
Check the black cover on the pick up assembly under the cyan cartridge. If it is only a fraction too high cyan will not print. Make sure it is clipped in place correctly.
Jan 20, 2010 | HP LaserJet 5550 Printer
Hp 5550 deskjet not printing
This is typical cartridge problem.Which cartridge changed?This printer can print with the only one cartridge inside it, whatever which.Try this: Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
If this not help your printer has problem in carriage unit and need repair.
Nov 04, 2009 | HP DeskJet 5550 InkJet Printer
Ink cartridge 56 and 58
the printer itself recognizes cartridges
hp 57 print cartridge
hp 58 photo inkjet cartridge
and hp 28 inkjet print cartridge
any other cartridges will be of no use for this specific printer
Oct 31, 2009 | HP DeskJet 5550 InkJet Printer
Can I replace the 57 cartridge with the 58?
'58' should only be used with 'photo' paper, '57' is for everyday use.
Mar 31, 2009 | HP DeskJet 5550 InkJet Printer
HOW DO I CLEAN MY PRINTER CARTRIDGES/HEADS?
For using the HP Deskjet 5000 series Printer Assistant:
  1. Double-click the 5000 series printer assistant icon on the Desktop of the computer.
  2. Click Utilities .
  3. Click Printer Maintenance .
  4. Click Clean Cartridges .
  5. Follow the on-screen instructions.
read info on this HP link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09339&cc=us&lc=en&dlc=en&product=71896
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 15, 2008 | HP DeskJet 5550 InkJet Printer
CARTRIDGE TROUBLE
take the new one out again and then replace it again
Nov 02, 2008 | HP DeskJet 5550 InkJet Printer
5550 DeskJet 5550 curious error message
Do you happen to be getting this on a Mac? I'm wondering if this is the Mac's notification for your cartridge being too out of ink to print. I came across this error today and had to replace the cartridge to fix the problem (mind you with the exact same version, just new).
Feb 13, 2008 | HP DeskJet 5550 InkJet Printer
Help
1st page prints perfect but the 2nd page comes out with very light and skipped printing.
Oct 22, 2007 | HP DeskJet 5550 InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
Ben Johnson
