Question about Hoover Washing Machines
Hoover optima 1600 drum not turning
Optima
4 Suggested Answers
SOURCE: Hoover Vision 1600 drum not spinning?
I have similar problem with same model unit, found brushes on motor worn to point copper contact is hitting and scoreing commutator. Easy checked, ensure power completely disconnected, lie machine on side and gently rotate drum looking in side the motor. The commutator is what looks like a circular block of copper segments which will rotate with the drum and should be evenly worn and coated with carbon from the brushes. If you see a clean copper area, usually in the center, then the brushes are worn down below workable levels. Suggest replacing should resolve problem.
Posted on Jun 08, 2008
garing
  • 998 Answers
SOURCE: Hoover Washing machine wont spin
look at the belt and thumbs up
Posted on Aug 09, 2009
FaceTheFacts
  • 245 Answers
SOURCE: service to repair pcb module hoover optima washing machine
Two screws on the back. Lift the cover off. Pull out dispenser, push middle tab. Pull out. Two screws on the dispenser. 2 screws on the top of the control panel. Take a pic with your cellphone at the wires. Replace and reverse.
Posted on Feb 15, 2012
Hoover optima 614 drum wont spin
Either a broken drive belt or a failed transmission.
Jan 12, 2015 | Hoover Washing Machines
One of the bars inside the drum has come loose how do i fix it
Open the shell, find what screws fell out, replace screws tightly.
Dec 06, 2014 | Hoover Optima 7 OPH716DF White 600 mm...
A knocking sound when it spins
what is the drum doing whan you start the washer with the drum
Jan 22, 2013 | Hoover Washing Machines
Vibrating drum on a nextra 1600
a bearing is worn out or there is a clip that holds it in place that has worn out to
Jan 18, 2012 | Hoover Nextra HNF 2137 Front Load Washer
Water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
Nov 15, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Have the same problem, different model and it looks like I am outside 5 years spare parts. Probably just a belt or something from overloading. Also looks like it would nearly be cheaper to buy a new machine.You must have checked your pump???? What a rip off
Nov 27, 2006 | Hoover HF7 160E Front Load Washer
Washing Machines Logo
42 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
