Question about Samsung RS2630SH Side by Side Refrigerator
Fridge side not cooling and no air blowing at all
Fridge side no air flow
  • 700 Answers
Are the aair intake blocked? if note them it needs to be defrosted and them turned back on youcan easily defrost the unit by taking a shop vac and blowing the warm air from the outlet to thaw out the coil. Then you have to take the pahel off to make sure that the coils is clear and the drainline not plugged up. Good luck.
Posted on Jan 11, 2009
How does a side by side domestic fridge work
Freezer one side, refrigerator the other side. Compressor is in the bottom at the rear. Often ice and water dispensers in the door.
Jan 23, 2016 | Refrigerators
Water dispenser line frozen, items freezing in fridge side. Freezer constantly running/blowing
Your freezer is what actually cools the refrigerator. The cool air enters from that spot on the top left of the freezer. Make sure that isn't blocked. It's sounds like the thermostat that controls the air flow from the freezer to the refrigerator isn't working or the air flow control device is stuck.
Either way if you can, unload and unplug the unit. This will do to things. First it will reset the circuits that control everything and secondly if the air flow control is frozen thawing out the refrigerator and freezer may free it up.
Feb 04, 2014 | Electrolux 25.9 Cu. Ft. Side-by-Side...
ON MY KENMORE SIDE BY SIDE REFRIGERATOR THE FRIDGE ISNT GETTING COLD BUT MY FREEZER IS FINE
Check to see if the air flow vents are not being blocked. The refrigerator side sucks air from the freezer side and blows it through vents on the side top and is controled by a thermostat marked, usually Refrigerator Cooling. If your thermostat is off, then no air, if the thermostat is kaput, then no air.
Dec 12, 2010 | Kenmore Refrigerators
Actually a side by side freezer's way cold but fridge won't cool.....started it 3 hours ago empty
ck the dampner control as it controls the air flow to the fresh food side. also see if the evap fan is working .. inside the freezer side . this blows the cold air to the fresh food side. mm
Aug 10, 2010 | Magic Chef (CSD2610KRW) Top Freezer...
Freezer side working refrigerator side wont cool
check for ice buildup where the vent is to make sure there is a good air flow . If none try turning fridge off for a day if you can or using a blow drier to melt the air passage and try again
May 24, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Freezer to cold refrigerator not cold enough
sounds like your defrost timer is not working properly . Most fridge/freezers the fridge gets cooled from the cool air from the freezer . But when the defrost timer is not working properly the section between the fridge and freezer freezes up and hence doesnt allow the flow of cool air into the fridge. The defrost timer can be easily replaced.
Jan 28, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Freezer quit then noticed fridge side not cooling
the relay on your compressor is bad go behind you refrigerator and take off the the bottom panel the relay is on the left side of your compressor usually
Dec 29, 2008 | Whirlpool GD5SHAX Side by Side...
Side by side fridge not cooling properly
If you have NO water in ice maker... check to see if inlet water valve to ice maker is still good.
Frig not cooling...
Look in freezer see if any frost build up, on back wall ..make sure fan in freezer is blowing.. also fan in back by compressor
Jun 09, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Samsung RS2630SH Side by Side Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
