Question about Lakewood Oil-Filled Electric Radiator Heater
How to replace switch on lakewood oil heater 9000
Model 9000 The switch broke
Where may I find a service place to replace a switch ?
Posted on Dec 14, 2015
  • 34 Answers
SOURCE: Lakewood oil radiator heater quit
visit http://www.lakewoodeng.com/html/parts.html for service center info and parts.
Posted on Apr 18, 2009
SOURCE: Lakewood oil filled heater model 5600/7 won't turn on.
I went to buy a new oil filled heater because mine was blowing the breaker. After I bought two, I heard the sales rep telling a customer to store the heater on it's side or upside down or give it a good shake to loosen the oil from the bottom. So, I went home and tried this...it may take a couple of times before it stops blowing the breaker, but it works.
Posted on Jul 07, 2009
Natemane
SOURCE: ROCKER SWITCH DIAGRAM
On the top of the switch (inside the heater) there is a common connection.....even though it looks as if it is connected (electrically), it isn't electrically affected by the switch; it's just used as a post. It's just the place where the striped wire connects to the "common" point for the heater coils (they are in a parallel). Also, while you're in there you might want to put some electrical grease on the exposed conductors.....mine had quite a bit of corrosion (which was the reason for the failure). I had to replace 3 of the female connectors.
Posted on Jan 01, 2010
SOURCE: The Lakewood 5500 oil-filled heater has stopped
Similar problem here. But in my case, it was a blown fuse. There's an in-line fuse on the internal wiring of the heater. Take the control-side off (remove the bottom grey plastic bracket, then remove a sheet metal screw, then slide the whole assembly down off of the radiator). Where the elements go into the reservoir at the bottom of the radiator, the white wire should have an inline fuse connected to it. It will probably be covered with what looks like heat-shrink tubing. Snip, snip, and replace.
Posted on Jan 11, 2010
  • 3 Answers
SOURCE: my lakewood oil filled heater model 5600/7 just
The reason that it stopped is an open circuit. It is probably a blown thermal fuse. However, it could be any of the following if that is not the problem:
bad switch, broken or disconnected wire, burned open heater element, bad connections between terminals and wires, or between wire connectors and the wires within them.
If you take it apart, you will find the heat sensitive thermal fuse device under the heating elements, near the bottom of the unit. If the thermal fuse is good, it will appear as a short to an ohmmeter (zero ohms). If it is failed, it will appear as an open (infinite ohms).
The thermal fuse device can be replaced. Here is where to get one:
http://www.goodmans.net/get_list_632_2.htm
The thermal fuse may be this one, but check the temperature indication on yours first: Item#: TH-TF167C
Good luck.
Posted on May 10, 2010
How can i replace the ADF hinge on the konica 7020
just get the model number of it and take the to where they sells the part
Feb 19, 2014 | Brother DCP-9000 Copier
I need a free unlock for Blackberry 9000
Hi, You can unlock a Blackberry 9000 safer and easier using unlock code. But you can't get free unlock code for your mobile model. Anyway you can get the accurate unlock code for your Blackberry 9000 from www.superunlockcodes.com/blackberry-9000-bold/rs16wp9/ at low cost.
UNLOCKING STEPS FOR BLACKBERRY 9000
-*-*-*-1 - Switch on your Blackberry 9000 without any sim card.
2 - Turn on the phone and Go to Manage Connections and select Turn off all connections. All The wireless connections will be turned off.
3 - Go to Options.
4 - Select Advanced Options.
5 - Select SIM Card.
6 - Press the following keys in order: (M) (E) (P) (E)
7 - A prompt will appear asking for the unlock code.
8 - Reboot your device.
9 - Re-enable the cellular radio *-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-
Oct 16, 2012 | RIM BlackBerry 9000 Cell Phone
Belt Reset Button
please go to the next web page and download your free manual from elextrolux:
http://smallappliances.electroluxusa.com/en-US/Customer-Support/Guides-and-Manuals1/
God bless you
Jul 27, 2012 | Electrolux Vacuums
Maytag 9000 washer series manual
the hinge on the door is broke the door is about fall off
Feb 03, 2012 | Maytag Washing Machines
How do you remove and release the quick grinder pad?
There is a button at the front of the grinder usually black or red, depress it lightly and rotate the wheel (unplug grinder please) wait until you feel it fall into spot, depress tightly and hold then turn wheel and unscrew to replace pad. Reverse to reassemble.Good Luck....
Apr 21, 2011 | Metabo ® 12 Amp 9000 RPM Model WE14150...
Epson dfx-9000 printer is showing error 0D when it is switched on
check print head built in thermistor and the carrier cable.
Nov 20, 2008 | Epson DFX-9000 Matrix Printer
Janome 9000
I have a Janome 9000, was sewing and broke needle, replaced and broke another. I didn't have machine threaded, took out bobbin and would sew a little and stop saying thread broke. I took off top plate and started machine again, sew a little and stop saying thread broke. So I took out bobbin case and sewed again and stopped repeating the message. Everything looks OK, bobbin case and top plate. I guess I want to know if the timing could be off or do you think it is the computer part of the machine...Should I take it to the Sewing Machine Shop??
Apr 30, 2008 | Janome Memory Craft 9000 Computerized...
Toshiba Tecra 9000 WiFi
it's a wireless connection set up issue..in control panel, among last icons..follow that direction..should get you there.
Apr 21, 2008 | HP Pavilion dv6000z Notebook
Lakewood Oil-Filled Electric Radiator Heater Logo
117 people viewed this question
Top Lakewood Heating & Cooling Experts
Mack Baxter
paulcarew
jdthefixer
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
