Question about Garden
FH661V-AS05-R won't start
Backfires when trying to start
2 Suggested Answers
bargainbin2
  • 123 Answers
SOURCE: RZT 50 Floods /had carb. serviced 4 times -runs 5
Sounds like you are in a hot weather if so it may be the vent in top of the fuel cap. In the hot the pluged hole lets the gas tank build up pressure forcing fuel by the needle valve causing fluding in the carb.
Posted on Aug 28, 2009
Backfiring won't start bought new coils still won't start and pops backfires
Do you have a carburetor? If you do, it is set too rich. Also, your timing appears off. If you do have a carburetor, adjust the setting to the left a couple of turns. This will lean out the gas mixture. If you have a fuel injector, have the system checked. The air filter could be clogged and the fuel injector could be misaligned.
A backfire is often created because the timing is off, forcing the spark plugs to fire before the pistons get to the top of its power stroke, causing the mixture to burn prematurely.
Feb 22, 2013 | Motorcycles
93 Honda CBR 600 F2 Won't start just backfires
carb needs cleanin or rebuild--getta clymermanual for procedure
Dec 11, 2012 | Motorcycles
Won't start and makes fire when I try
check the gear on the bottom of the distributor
Sep 07, 2012 | 1992 Ford Explorer
Engine won't start getting fuel and fire crank but won't start it wants to backfire
Try posting this question under mowers. This is the measurement tools category.
Aug 27, 2012 | Briggs & Stratton Briggs Stratton Intek V...
My 1987 yamaha razz riva scooter won't start and it;ll backfire then almost start then nothing?
take out the spark plug and clean it or replace then check the gap
Jun 11, 2012 | Motorcycles
89 K5 Blazer 350 TBI cranks but won't start... the rad hose blew, i fixed it then the next day it bogged and backfired, ran fine cold, but when warmed up it would lose power and stall when trying
Have you checked Google I found this hopefully it's not your timing or it may be flooded but doubtful have you tried spraying starting fluid into the intake while cranking it
Jun 01, 2012 | Cars & Trucks
Have a 1999 Kia Sportage that won't start. Have changed Head gasket and set timing. Have also check to see if getting spark and am getting spark. Will crank but won't start.
dose it backfire when you crank it over. if it dose your timing is off. If it dosent backfire when you crank it then look at all your wires and make shur you pulged ever thing in. and if you have one ground not hooked up that can cause a no start do you have fuel?
let me know and we will help more if needed
stockam auto
Jul 11, 2011 | 1999 Kia Sportage
RZT 50 Floods /had carb. serviced 4 times -runs 5 mins to 1hr before it stalls /have to drain carb.bowl let sit for several min. before it will start. Kawasaki FH661v-AS05-R engine
Aug 27, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
