Question about Dryers
Broken Hotpoint tumble dryer
Keep getting error code F-11
  • 3,463 Answers
If it is a stand alone dryer, and not a washer dryer, then F11 means that the pump is not working.
This can be due to one of several reasons,
First and foremost of course is that the pump itself is faulty,if it is o/k, then I advise you to call an engineer to sort it out, as it could be involved.
Plz rate my solution.
Thanks.
Posted on Jan 11, 2009
5e error code
Samsung Washing Machine cleaning the pump & coin trap ...
? 5:11
www.youtube.com/watch?v=OofFb280Cn4
Jan 15, 2012 - Uploaded by whichwasher2007 Samsung Washing Machine cleaning the pump & coin trap .....you could try installing a new pump to avoid the 5E error, fixing the pump will ...
Sep 19, 2015 | Washing Machines
I keep getting an error Code: 209600. what can I do about this?
Hey there mtally. Wii error code 209600 is usually a failed connection to your wired router. Try switching the channel of your router to either channel 1 or channel 11.
Have fun :)
Aug 22, 2011 | Nintendo Wii Console
I keep getting an F 11 error code on my duet washer. What does it mean exactly?
Motor control Unit error Most likely means the MCU is bad but a tech can check.
Nov 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I keep getting a C2 11 error code. Unit lights and immediatly goes out showing that error. At other times it operates fine. The problem seems to be occurring more frequently. It has been in service...
that error code means not enough gas.
however, there might be something going on with your venting. it could be sucking exhaust air back into the unit. this will cause the same error code.
if your problem is intermittent, then I would suspect the venting to be the issue.
Aug 22, 2010 | Rheem Paloma Tankless Water Heaters...
I keep getting an f 11 error code? what seems to
F11 is the code for a communication error between the CCU and motor control unit.  sometimes just re-seating the connectors on the CCU cures it.  if not, odds are it is a faulty CCU and needs to be replaced.
Jul 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a v-fit kik-036-11 and keep getting e-1
Your problem might be a magnet that has fallen off from within the treadmill. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jun 02, 2010 | Exercise & Fitness
Keep having an f 11 error code,even in middle of a cycle
Hello there:
this dreaded error code is caused by the following
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Jan 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore he4t washer shows f-11 error
F-11 // WILL THEN APPEAR FDL CODE DOOR LOCK LOCK FAILURE, F-11 COMMUNICATION ERROR REPLACE MAIN CONTROL,, JUST REPL 3 TODAY ....
Nov 28, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Keep getting f11 error on
Click on the following link for an explanation of the "F11" error code:
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
If you require additional assistance, please let me know. I hope this helps you.
Jul 09, 2008 | Whirlpool Washing Machines
Dryers Logo
109 people viewed this question
Top Dryers Experts
