Question about Kenmore Freezers
Kenmore freezer model 2722
I need a new seal for the door.
  • 1462 Answers
SOURCE: new freezer has bad door seal
it often works to warm the seal with a hairdryer and reshape it
Posted on Nov 29, 2008
  • 1779 Answers
SOURCE: door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
Posted on Aug 08, 2008
ngfam1
  • 639 Answers
SOURCE: Kenmore freezer
Hi Robert,
Happy to help.
You need a new door seal.
But they are not easy to put on properly
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Posted on Aug 25, 2008
  • 126 Answers
if the gasket isn't torn and the gap isn't caused by a door hinge problem you might try putting some vaseline on the door seal. If that doesn't help you may have to replace the seal.
Posted on Jan 08, 2009
Controlfrk
  • 304 Answers
SOURCE: I have a kenmore upright freezer model
I'm assuming you don't want to replace the door seal. Open the freezer door. Stand "inside" the open door and place your foot at the right bottom corner (looking from the inside). Place your hand in the top right corner and pull it very slightly toward you. Do this in small amounts until the gap closes making sure you don't open one at the bottom.
An alternate method is to warm the gapped section of the door seal with a hair dryer to soften the rubber enough to allow the magnet within the rubber to pull the seal gap closed. This has worked for me numerous times by making small adjustments at a time. Good Luck
Posted on Sep 03, 2009
Testimonial: "I want to thank you very much i have been messing with this for a few days within 2 seconds it was fixed you were a great help "
HOW DO I REPACE D00R SEAL
To replace your seal you'll have to remove the screws around the perimeter of the door's inner panel. Once all the screws are off separate the inner panel from the old seal and peel the seal away. It should peel away easily- if not use a Putty Knife to remove it.
Now take your new seal and "soften" it up a little by placing it in hot water for 10 minutes or so. It'll make it easier to place back in the correct position around the door since the seal was probably all twisted up and sharply folded doing shipping/storage.
Now simply lay it back in the same position the old seal was making sure there are no folds, creases or cuts in the seal. It must lay flat or it will leak all over again. Note: there is a sealant that you may want to get that's specially made for these seals to guaranty the seal gaps are filled and the seal stays in place. I use "Kitchen and Tub" Caulk when I don't have any refrigerator caulk available.
Now reassemble the door inner panel, your new seal, and the outer door all together with the screws you previously removed and you're all done.
If you need more info an excellent source is "Appliance Parts Pro". http://www.appliancepartspros.com/parts-for-frigidaire-ffu14k0dw0.html
Click on your Seal (item #1) and see the comments below that other customers asked.
Hope this helps.
Jun 27, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Seal door twisted
Take the SEAL and put it in a BATHTUB with HOT HOT WATER.... It is become very flexible. Dry it off well and attach it. You may need to use a hair dryer to deal with small defects in the seal, but patience will pay off well in this repair.
kindy,
Jim
Jan 14, 2014 | Whirlpool Freezers
Freezer door does not make vac sound
Might need a new seal.
A better test than sound is the put a dollar bill in sealing area and close door. Check how hard it is to pull dollar out (check tightness).
Do this all around the door in various spots.
Jul 22, 2013 | Freezers
Fridge door Magnet does not work
do you mean the door seals,if so you may need new ones or you have lost the vacuum in your ff, they are not magnets they feel like it but it is vacuum sealed,,try a ff second hand shop
Mar 27, 2013 | Kenmore 17.5 cu. ft. Top Freezer...
After defrosting door will not seal well
Check there are no small vegetables stuck in the seal. Crazy, I know, but it's amazing the places frozen peas can end up.
If there's nothing caught in the seal, perhaps the seal has deformed. How did you do the defrosting? Sometimes people use knives and damage parts of their freezer. Some people use boiling water, which can cause damage to seals. If the seal has become deformed, you will most likely need a new seal.
It might also be worth checking the door hinges; if the door isn't flush with the opening, the seal won't seal properly. Defrosting shouldn't cause any problems with the door, but sometimes accidents happen.
Oct 09, 2010 | Woods Freezers
Freezer door of electrlux freezer keeps coming
Try cleaning along seal and seal itself. If it does not work get new seal. The seal do go bad after a while.. If under warranty call dealer you purchased from for them to replace.
Jul 06, 2009 | Freezers
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 | Freezers
New freezer has bad door seal
Nov 29, 2008 | Haier Freezer HUF168PA 16.8 Cu. Ft....
Door not sealing
After putting a new gasket on you will usually need to form it. You can use a hair dryer to heat the gasket and flat screw driver to form it.
Nov 07, 2007 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezers Logo
129 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
