Question about Intertherm P3RA-048K Air Conditioner
Heater coil clicks on and off while running
Breaker hums when click on humming stops when clicks while running
  • 70 Answers
This is a sound usually meaning the breaker has a higher amp on start up your breaker probably has a loose connection or your breaker is going bad hope this helps
Posted on Jan 11, 2009
Kenmore 7.5 freezer stopped working.
Thanks for all the suggestions. I just replaced the overload relay and it does the same thing. Runs for a few seconds and the loud click from overload relay. I did notice the relay is really hot to the touch, if that matters.Coils on back are clean. I had noticed the last few months that the inside coils were frosting up quite a bit.Really had hoped it was the relay.
Dec 04, 2012 | Kenmore 7.5 cu. ft. / 212 liter Upright...
I have a 115000 heater and when I turn on the switch the unit just hums and then it sounds like it blows an internal breaker and the humming stops
sounds like the motor start capacitor is bad causing the unit to stall and pop the internal circuit breaker...you will need to remove the cover and look for the silver can looking component that connects to the motor...you will then need to get a motor start capacitor to repair the problem ..these usually cost about 6-15 dollars at most appliance parts stores...or you can try a place like www.grainger.com
Jan 23, 2011 | Reddy R115DT Oil Filled Utility Heater
Trouble with the spin cyle.
Bad motor. Easy to replace. Worth the effort.
To find out how, click HERE
Feb 04, 2009 | Kenmore 24982 Top Load Washer
Pipes humming in house
From your description, I am guessing you are on a deep well with this answer. I think you have an issue with the well pump. To isolate it do this...........
Turn the main supply valve off to the house. Your well tank should have a hose bib on the well tee. Hook a hose up to that and run it outside. Open the valve to the hose until you heard the pressure click on which activates the pump. After the click close the valve and listen for the hum. If it still hums it is the Well and not the piping in your home.
Will follow-up.............
Please rate this response after testing and Good Luck, Phil
Dec 30, 2008 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
Fan
Ifs its a small humming sound,then its the contactor pulling in. But if it a loud humming sound then its the compressor kicking in. and the fans not, try to take something long and turn the blades on the fan, if it takes off and run then your capacitor is shot or swollen at the top,which was cause by power surge. Take-off and replace with the same mfd. writings ,on the outside of can. Also check for blown fuses or tripped breaker . the fuses should be in the disconnect box on the wall, or the breaker in the breaker box.. Older house has fuses instead of a breaker box!
Sep 01, 2008 | Bryant Heating & Cooling
Intertherm P3RA-048K Air Conditioner Logo
41 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
