I have a/c SANYO split unit model Sap-k18bl and has massage E5
My A/C not working well : compressor. not working and internal unit has a massage E5 , what is the problem ? Thank you
hemantraj
  • 638 Answers
SOURCE: Fedders Air conditioner
e5 is comp overload code . if you have infared remote for indoor units point at anyone while pushing all 3 buttons at the same time- 'mode' 'temp up' temp down' this will bring up OO where temp set point is normally displayed. scroll up or down with temp up or down buttons (1st digit only) untill you here the beeping sound change tone, this is the 1st part of the fault code. press mode once to change to 2nd digit, scroll again with up and down listening for change of beep- 2nd part of code ie "E5". press mode again will bring up afunny looking T-test mode. press mode again to exit. THATS VERY ACCURATE SOLUTION.SAVE IT FOR FUTURE.WISH U SUCCESS .REPLY FOR FURTHER ASSISTANCE IF REQUIRED.BYE
Posted on Jun 07, 2008
SOURCE: leaking water from inside samsung split sytem
if your indoor unit is leaking water down the wall,it is from one of two things.First, is possibly the insulkation on the copper lines is coming loose and the suction line is condesated,with no way to drain,it drips down the unit.The other possiblity is that the drain hose is coming loose from vibration and leaking a little.
Posted on Dec 31, 2008
notsomot
  • 67 Answers
SOURCE: Have purchased premises with a
There you go
http://service.airwell.com.au/airwellsanyoparts/Website 2007 update/sanyo/SAP-C302AH/sm700568-00_11 service manual.pdf
If you cannot veiw please let me know and i will re post the link or email it to you
thanks for using fixya
Posted on Apr 22, 2009
alex_salve
  • 78 Answers
SOURCE: My Sanyo KS1211W split air conditioning unit does not cool
u r compressor is not functioning,sure u need the service technician
Posted on May 17, 2009
  • 306 Answers
SOURCE: need recommended sub-cooling and superheat for
Superheat should be 8 to 12 degree's. Sub cooling around 18-22. I like to use superheat that way I know the coil is doing all it can do.
Posted on Jun 16, 2009
Comperasor running e5 problem
Change capacitor motor and outdur working almost
But 3 minute working ok
After E5 error show display screen on indur with outdour fan stop but compressor sound
Apr 23, 2015 | Haier HSU18VC7-G Mini Split Wall A/C Unit
Hello, I have a split system air conditioner (one of SAP-K181AA or SAP-K241AA or SAP-K251AA) and it is dripping cold water inside onto the floor. Can you help.
try to unclog drain line of your ac.or check the elevation of you indoor may be the drain water cannot flow smothly.
Jan 30, 2011 | Sanyo Heating & Cooling
I'm looking for an enigma split system airconditioner manual-I have an error message E5 with no compressor activity
E5 Communication errorbetween outdoor and indoor. Check output (call) from your indoor unit to out door unit by Volts meter. If no power in out door, you have to check setting of temp whether it's 23 and less than that and also mode in "Cool".
If power is there in out door and fan only running means compressor is tripped by overheated
Dec 16, 2010 | Heating & Cooling
IDEC aircon E5 error what does it mean?
i am air con tech and i face all ready this problem may be it will help u . e5 error is ur air con not have gas becoze of that the low presser switch give error on disply thanks best regard for all. pls let now if its help full
May 27, 2010 | LG LSC183VMA Split System Air Conditioner
I has a split AC there is problem of electrical wiring between compressor and in house machine. I need some service center address in Ahmedabad city Gujarat to recify the same. My model No. is SAP-K184ML
hi,there is a problem commucating...possible one of the wires has gone bad....you will need to to turn off all power to both units at the breaker at the panel or disconnect...you will need to go to walmart purchase a electronic test meter..they have one for 20.00 ..i bought one yesterday...yiu will need to remove one wire at a time from the indoor unit...get a piece of paper befor removing any wires...mARK NUMBERS....
Mar 26, 2010 | Sanyo Split System Air Conditioner
I have a split system SAP-K181AHA, SAP-K241AHA that is leaking water from unit inside house.
Air conditioners wring moisture from the surrounding air that collects in a pan under the cooling coil in the inside unit.
Chances are that the condensate drain is plugged or the drain pan is plugged. Look for a hose that exits the inside unit and runs to a drain. You can follow it back to the drain pan of the A/C unit. If there is water sitting in the pan, then either the hose or pan or both are plugged.
Turn the unit off, get a small bucket and remove the drain tube. Catch the water in the bucket. Blow through the drain line until it's clear. If the thought of doing this is too repulsive, then use an air compressor or even a manual tire pump. Now check the drain pan in the unit for debris and remove as much as possible from the pan and the drain fitting.
Both the pan and drain line should be checked at the beginning of each cooling season.
Reinstall the drain tube and see how it works!
Jan 07, 2010 | Sanyo Heating & Cooling
Compressor not turning on
is the compressor actually turning over ?? if not check the contactor, or capacitor is actually ok...
if it does turn over, are the stop valves open ??
Jun 16, 2009 | Sanyo Split System Air Conditioner
May 17, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
