Question about Lexmark Color Z35 InkJet
Colored Ink problem
Good day sir. I badly need your help. its regards to my Lexmark Z35 color printer. I bought new ink cartridge both colored and black. I install the new ink but only my black colored ink printed out. i tried my new ink to use in other lexmark printer but it printed all ink both colored and black. How can i fix it this problem.. plss... help me. thank you.
  • 6 more comments
  • Anonymous Mar 14, 2014
    the black ink is really light in color but all other colors are bright
    why would my black ink be printing light in color
  • Anonymous Mar 18, 2014
    says i have both black and color ink but it won't print out on the paper
  • Anonymous Mar 22, 2014
    I installed it with disc, did a test page and it s blank, shows that the cartridge has ink both color and black. windows 8
  • Anonymous Mar 23, 2014
    I can't print even in B&W, says printer out of ink. Only cyan is out.
  • Anonymous Mar 27, 2014
    black not printing color ok
  • Anonymous Mar 29, 2014
    i just installed a new 14 black ink and a 15 color ink cartridge and now it says they are incompatable
  • 203 Answers
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Posted on Jun 08, 2007
Good day sir, My Lexmark z35 color printer doesnt work. I already tried to use the printer settings properly but still failed to print the color ink. Only black ink in printer is printing. Im still hoping that you have any solution for this. pls.. help. thanks!
Posted on Jun 16, 2007
  • Rebie Buco
    Rebie Buco Jun 16, 2007
    Good day sir,
2 Suggested Answers
SOURCE:
  • 62 Answers
SOURCE: Colored Ink problem
Make sure you are using the correct cartridges for the Z35. They should be #26 (color) and #16 (black).
Make sure the contacts are clean where the cartridge connects to the printer electrically. A little alcohol wipe is good for this. Clean contacts on both the cartridge and the carrier in the printer.
Posted on Nov 21, 2007
My documents will not print the colored part. just Black and white
I would first check to see how low the color cartridge is. If it is out of ink, you will need to replace it.
Your Lexmark has two cartridges, one for colors and one for black.
To check the level of the ink cartridges, go to the Lexmark Solution Center. This is the software that was installed to run you Lexmark printer.
Check the cartridge ink level images that appear on each tab. If a cartridge is low, or if you have received an Ink Low message on the computer screen, install a new cartridge. An empty or low cartridge is marked with an exclamation point ( ! ).
To order print cartridges:
1 }}--> }}-->Open the }}--> }}-->Lexmark Solution Center .
2 }}--> }}-->Click the Contact Information tab.
3 }}--> }}-->Click Ordering Ink and Supplies.
For help installing a cartridge, go to How to install the print cartridge.
Dec 30, 2010 | Lexmark X6150 All-In-One InkJet Printer
How do i install the ink cartridge in my lexmark z35 printer
Select the ink cartridge specific to your printer. Canon inks are versatile, so your selection may be as simple as choosing between black, color or a multi-pack with black and color cartridges.
Turn on your Canon printer. The switch is generally located on the top right hand side of the printer. Open the printer's lid.
Wait a moment. The cartridge carrier will automatically disengage.
Put your hand behind the existing ink cartridge and pull the cartridge towards you until it pops out. Dispose of or recycle the used cartridge.
Carefully pull the tape off the new cartridge.
Position the new cartridge into the cartridge carrier. Make sure it is facing the correct position.
Press the cartridge carrier gently until it clicks into place. Some cartridges have indicators to demonstrate that they are properly positioned.
Close the printer's lid. Print a test page to ensure everything is working properly.
Oct 31, 2010 | Lexmark Computers & Internet
HOW DO I REPLACE THE INK .I BOUGHT THE INK BUT FOR GOT HOW TO PUT IT IN
In order to replace the ink..please follow the following steps
#1
Spread out a piece of newspaper where you plan to work. Remove the supplies from the refill kit. The Lexmark 44 will have one bottle of black ink, one thumb drill and one syringe. The Lexmark 43 will have one bottle each cyan, magenta and yellow, three syringes and one thumb drill.
#2
Remove the label from the ink cartridge. The black refill hole is at the top of the ink cartridge. Use a toothpick to check the color of each fill hole on the color ink cartridge. Generally, the magenta is at the top of the cartridge, the yellow is at the left center and the cyan is at the right center.
#3
Use the thumb drill to open up the fill hole to fit the syringe needle. Place the tip of the thumb drill on the fill hole and twist until the hole opens up larger. Do this for each color hole on the color ink cartridge.
#4
Fill each syringe with 7 ml of color ink (one for each color) and 15 ml of black ink. Insert the syringe needle into the bottle of ink and pull the plunger upwards.
#5
Place the tip of the syringe needle into the fill hole. Slowly press down on the plunger. If the ink seeps out while filling, stop filling the cartridge and wipe up the ink with a paper towel. Some cartridges may not need the full amount of ink. Repeat this step for each of the colored ink fill holes.
#6
Replace the ink cartridge in the carriage of the printer. Run one to three test pages to cycle the ink and check the printing. Use any document with color on it for the Lexmark 43 and any document with black text for the Lexmark 44.
Thanks
Oct 06, 2010 | Lexmark X9575 InkJet Printer
Cartridge Error message on our Lexmark X5150
The Lexmark machines are designed to kick out anything it suspects may be refilled. If your old cartridge has bad print nozzles this may be tripping the error. Printers are typically for sensitive with their color cartridges anyway because the manufacturers make more money on the color ones. You can try looking around the settings on the machine and in the printer preferences to see if you can tell it to ignore the ink levels and see if you can continue to print.
Dec 19, 2009 | Lexmark X5150 All-In-One InkJet Printer
My printer wont print in color & its a new color ink cartridge
have the printer preferences been changed accidentally to print in greyscale? Is the cartridge installed correctly? Now and again if the cartridges are opened and not installed straight away the ink dries up in the nossel and clogs the printer head, easily rectified with some cleaning solution. Cartridges also go out of date. hope this helped
daveywhite
Nov 11, 2008 | HP DeskJet 812c InkJet Printer
Removal of black ink cartridge Lexmark Z35 printer
Put your printer "on", then open the central lid, where "lexmark z35" is written. The cartridges appear.
Open the dark green lid (on the right), same color as your new cartridge. Remove the old cartridge and put the new one in, after removing the tap.
Your printer should print a test page. If it doesn't, go to "printers" in the "control panel" (panneau de configuration in french !), right click on your printer name and chose "properties".
Aug 08, 2008 | Lexmark Color Z35 InkJet
Lexmark x5150
Your ink cartridges have dried out. Replace the black to confirm this prognostication and, if black works, replace color also. If you are into refilling ink cartridges youself try soaking the black one in 91% rubbing alcohol in a small ziploc type bag for several days. when the alcohol becomes ink colored, remove the cartridge from the baggie, dry it with tissue paper, reinstall it in the printer and up to 3 times run a clean the nozzles page until it prints a solid black line. Repeat with the color cartridge. Good luck.
qwester1
Apr 02, 2008 | Lexmark X5150 All-In-One InkJet Printer
Color cartridge won't print/ black and white is fine
Hi Franelyn !!
giving u some steps so that you get anser to ur question that why your color ink cartrideg is not workign
It might be beacuse of faulty printheads of printer or fauly printheads of cartridge
To check which one is faulty : take a tissue or cloth ...slightly moistened it with water an dtry to clean nozzles of cartridg and observe that some ink is coming out from cartridge or not , if not shake the cartrideg again clean its nozzles , if still no ink comes out that will ensure that the cartride is bad
Nov 29, 2007 | Lexmark X1270 All-In-One InkJet Printer
Colored Ink problem
Nov 19, 2007 | Lexmark Color Z35 InkJet
Lexmark Color Z35 InkJet Logo
561 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
