Question about Stanley NEW Bostitch 2 HP 6 Gallon Electric Air Compressor
Bostitch 150 psi 6 gallon compressor manual - Stanley NEW Bostitch 2 HP 6 Gallon Electric Air Compressor
4 Suggested Answers
  • 4 Answers
SOURCE: bostitch air compressor cap 60p-of
Mine had the same problem.
One of the reed valves in the head had broken off due to metal fatigue. Take off black plastic housing with 5 screws along the bottom and one bolt under the handle (the front only). Unscrew the four allen headed screws on top of the compressor. Unscrew the discharge line from the head. You'll need part # AB-A640050 which is the valve plate assy. and possibly AB-9007012 which is the intake valve located in the top of the piston (if damaged). About $18 including shipping from Bostitch.
Posted on Dec 16, 2008
  • 323 Answers
SOURCE: Will only charge to 40 psi, is supposed to charge to 150
You may have a problem still related to the original reason it was reconditioned.
However, you should have a regulator that you set to the tank pressure you want to maintain. Most have a tool regulator as well and 40 psi sounds like that is what it is set for.
If you do have a tank pressure regulator and it is still not charging above 40 psi, then either take it back or pick up a new regulator for under $20 at Home Depot and replace the gauge you have now.
Also, sometimes the gauge will have a needle tilted so that one end presses against the glass, and if you tap the glass hard with your finger it will move on around to the correct pressure.
Finally, if you are not experienced with small compressors, look under your gauge and see if there is not a black knob that pulls out and pushes in to turn and change the pressure.
Sirwriter
Posted on May 22, 2009
  • 236 Answers
SOURCE: On a Bostitch CAP60P-OF air compressor I can get
i also own a bostitch and it works great, the pressure regulator knob on mine is red not sure if yours is the same color but just turn this knob until you get the nail depth that you need , it should be near the pressure gauge, a quarter turn of this knob at a time is recommended until you get the pressure you need, i think you turn it in the loosen direction to get more pressure
Posted on Jan 23, 2011
Testimonial: "I think you solved it. The threads are stripped that the red knob screws into. Thanks."
My compressor keeps turning off and on
Try opening the drain at the bottom all the way and let it run for 20 min or so on a dry day.The check valve it sticking its a self lubercating pistion with teflon powder you are supposted to do this the first time you run it
Aug 14, 2016 | Bostitch BTFP02011 6 Gallon 150 PSI...
My bostitch 6 gal compressor keeps running , and running , even goes into a higherpitch motor noise. can i check something ? or clean something to fix it ?
is it building up any pressure on the gauge
if the pressure recorded is around 40 psi or less , replace the failed poppet/reed valves in the compressor head
if it goes to 100 psi then replace the automatic controller for the motor
Jun 15, 2016 | Stanley Bostitch CAP200P-OF 6 Gallon...
Why will my bostitch pancake compressor 240 psi tank 180 regulator that the guages will not show building pressure
Hi, There are different posibilities. I would need more information. Was it always like that? Does the guage on the main tank and the guage on the regulator both not show more than 20psi? When the auto shut-off is triggered do you feel there is more than 20 psi in the tank?
Sep 15, 2014 | Stanley NEW Bostitch 2 HP 6 Gallon...
How to take the top off mf my bosttitch 6 gallon pancake 150 psi air compressor
the should be a bunch of phillips head screws and 2 flat heads deep inside it
unscrew and it will come apart
Jan 04, 2014 | Stanley Bostitch 2hp 6gal Air Compressor...
I have a porter cable 6 gallon compressor. The motor used to cut out at 150 psi, but now it cuts out at 135. Is this a faulty tank pressure gauge misreading the pressure or a motor cutting out too early
it could be your air pressure adjustment knob, where your air line hooks up, which controls the psi to a lower or highist seting to adjust for different tools and uses.
Aug 26, 2012 | Porter Cable C2002 6 Gallon 2 Compressor
I do not know how/or where to insert the end of the hose to the Bostitch 1850BN compressor.
http://www.docstoc.com/docs/56973363/Factory-Reconditioned-Porter-Cable-C2002R-Oil-Free-UMC-Pancake-Compressor
Usually when buying new/reconditioned it doesn't have the female coupling installed.You need to buy it separate and a roll of Teflon tape.On your model its to the right of the psi adjustment knob.Take a look at the link,it connect to the 2 brass peices on the front right.Good luck.
Feb 22, 2011 | Stanley FactoryReconditioned Bostitch...
My stanley compressor will not shut off untill the safety pop off valve activates
The pressure cut off setting is too high. Locate your operation manual and adjust the pressure to the manufactures specs. Normal shut off pressure is @ 125 psi.
Feb 15, 2011 | Stanley NEW Bostitch 2 HP 6 Gallon...
Sirwriter
May 21, 2009 | Stanley Factory Reconditioned Bostitch...
Stanley NEW Bostitch 2 HP 6 Gallon Electric Air Compressor Logo
220 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
