Question about Pioneer AVH-P6400CD Car DVD Player
Red wire missing
The red power wire is missing from my iso plug, there are 2 holes left spare on the iso plug which one doe's the red wire in the stereo is a pioneer avh-p6400cd could any one HELP For the person that said below or next to yellow wire it can't as there are wires already next to them.
    Scholar:
  • 61 Answers
The power wire goes above a blue wire or next to (white/orange) and (green) in top row if there is a space there
yellow should be above black
(white/orange) should be above (blue/yellow) i think
than red over blue
hope this helps
Posted on Mar 04, 2009
3 wires were taken off the turntable Sharp
The RCA plugs are the Right (red) and Left (white) sound channels.
The 3 thin wires are the power connect. It's likely this will only fit one way into the unit, unless you have broken or cut of the connector. One wire will then be the + wire (under 12volts DC) the other - wire and the other earth. As long as the wires don't touch each other all that will have is the turntable will go backwards if the - wire is connected to the plus terminal.
The phono plugs reversed will simply switch the left sound coming out of the right channel etc...
Dec 17, 2012 | Audio Players & Recorders
My lg telly has no sound or picture power button just flashing red
There are red,white,and yellow wires at the back of the T.V. Make sure
that the yellow wire is plugged into the yellow plug in hole, white wire has to be plugged into the white plug in hole, and the red wire plugged into the red plug in hole.Sometimes for the red wire you have to plug it in a black plug in hole. Make sure your T.V. is connected to you reciever. If this doesn't help I'd try calling somone to fix it for me.
Jun 24, 2012 | LG 42LC2D 42 in. LCD HDTV
A creative speaker SBS A200 connector pin was damaged. we need to connect that cable directly into the board.so we need that pin details.
Hi, I hope this helps,
Pins look like this: (Top view, not copper side)
1 2 3 4 5
6 7 8 9
1 = Thin white wire from thick white cable (Left input)
2 = Gray (Speaker out)
3 = Orange (+V return from volume unit to bass unit)
4 = Not connected
5 = Thin Red wire from thick red wire (Right input)
6 = Blue (+V power from bass unit to volume unit)
7 = Black (GND - if socket removed, solder 3 socket shield holes to each other or solder black wire directly leftmost hole)
8 = Not connected
9 = Shield copper from thick red wire
Shield copper from thick wire : Solder to GND or Left unconnected
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
Schematic to driver side fuse box
Cavity Fuse Description
1) 15 Amp Blue Horn Relay, Power Sunroof
Relay, Power Window Relay
2) 10 Amp Red Rear Fog Lights (Export Only)
3) 20 Amp Yellow Cigar Lighter
4) 10 Amp Red Headlight Low Beam Right
5) 10 Amp Red Headlight Low Beam Left
6) 20 Amp Yellow Body Control Module/Power Door Locks
7 )10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
8) Spare
9) 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/Cluster
10) Spare Cavity Fuse Description
11) 15 Amp Blue Flasher
12) 15 Amp Blue Stop Lights
13) 10 Amp Red Body Control Module/CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight
Mirror/Light Bar Switch (Renegade Only)
14) 10 Amp Red PDC Fuel Pump/AC Clutch,
Starter Relay/Engine
Controller/Transmission
Controller (Diesel Only)
15) Spare
16) 20 Amp Yellow Power Outlet (Rear)
17) 15 Amp Blue Rear Wiper
18) 20 Amp Yellow Radio Choke & Relay
19 20 Amp Yellow
Frt Fog Lights/Trailer Tow
Stop and Turn Lights
20 Spare
21 10 Amp Red Radio
22 20 Amp Yellow
Power Sunroof Relay/
Antenna Module (Export
Only)
23 Spare
24 10 Amp Red PDC Blower Motor
25 10 Amp Red Heated Seat Switches/HVAC
Control Head/Trailer Tow
Battery Charge
26 10 Amp Red Headlight High Beam Right
27 10 Amp Red Headlight High Beam Left
28 Spare
29 10 Amp Red Heated Mirrors/Rear Window
Defroster Indicator
30 15 Amp Blue Heated Seat Module
31 Spare
32 10 Amp Red Wiper Switch/Front and
Rear Wipers
33 10 Amp Red SKIM Module/Data Link
Connector
34 15 Amp Blue Body Control Module/
Cluster/Interior Lights,
Hands Free Module/Radio/
CMTC/ITM Module & Siren
(Export Only)
35 Spare
36 10 Amp Red Airbag Control Module/
Occupation Classification
Module (Right Front Seat)
37 10 Amp Red Airbag Control Module
38 10 Amp Red ABS Controller/Shifter Assembly
39 10 Amp Red Hazard Flasher (Turn
Signals)/Backup Lamp
Switch (Manual Transmission
Only)/Transmission Range
Switch (Automatic Transmis
May 23, 2011 | 2005 Jeep Liberty
What wires connects to the holes on the motor there afe red grey and white???
The 4 holes are color coded. Red wire in first hole. White wires in either hole 2 or 3 and Grey wire in hole #4. I am counting holes left to right.
Mar 29, 2011 | Sears Craftsman LiftMaster Chamberlain...
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Which colour wire to use to hook up a trailer for a Kia Carnival 2000,trailer leads are yellow, green,black,brown,red,white and blue(no connection). just want to know which lead goes to which in the Kia?...
Here is a cheat sheet I compiled that you will find very helpful:
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are Color, Function, Mark on the plug.
Seven wire Trailer plugs
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
Oct 28, 2009 | 2000 Kia Amanti
Wire colours
Check if this applies to your Rover
White/Blue - Perm 12v,
Yellow/Red - Switched Igntion,
Red/Black - Night time illumination,
Black - Earth
 Blue/Green & Grey/Black at ISO Connection is LH Front Door Speaker
 Red/Green & Brown/Black at ISO Connection is RH Front Door Speaker
Blue/Yellow & Grey/White is LH Rear Speaker
Brown/White & Red/Yellow is RH Rear Speaker
Power connector:
1. n/a
2. n/a
3. n/a
4. 12V permenant
5. n/a
6. n/a
7. 12V (ignition on)
8. Ground
Speaker Connector:
1, 2: rear right speaker
3, 4: front right speaker
5, 6: front left speaker
7, 8: rear left speaker
Sep 01, 2009 | Philips Car Audio & Video
Wiring diagram for PowerBright VC-1500W Step Up&Down Transformer
I just had a similar problem but only a couple wires popped out. I took a guess at where they came from and it works again.
Top right corner - left hole - black wire
Middle, right side - left hole - brown, right hole white
bottom centre - left hole - blue and green, right hole yellow and green
Apr 03, 2009 | PowerBright Power Bright PW200-12 12 Volt...
No red power wire
should be next to or above yellow wire.
if not, re-post
Jan 11, 2009 | Pioneer AVH-P6400CD Car DVD Player
Pioneer AVH-P6400CD Car DVD Player Logo
126 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
