Question about Belkin (F5D7050) 802.11a/g/b Wireless Adapter
I have my wireless adapter connected and it shows my required network in the list, but I am not able to connect to it
  • rharper272 Jan 21, 2009
    I can see the networks and it usually automatically connects to mine but now it cannot aquire the address and will not connect at all. I tried running diagnostics etc and they say my network key does not match router which is stupid as I have checked and double checked the code and it is correct as other people can connect.
I have belkin f5d7050 wireless adapter load up ok but computer says cant recognise it
Posted on Feb 04, 2009
I had trouble with linksys router and modem, it saw connection but would not connect. I found that my network adapter (drivers) were not installed. Make sure you check that the drivers are installed. If it looks like it, then uninstall then re-install again.
Hope it helps.
Posted on Jan 11, 2009
How do i connect to a wireless network?
If you have a laptop, you can see a list of available wireless networks, and then connect to one of those networks, no matter where you are. The wireless networks appear only if your computer has a wireless network adapter and driver installed and the adapter is enabled.
To view and connect to available wireless networks
  1. Open Connect to a Network by clicking the network icon (eff2d36c-9e0d-4d1a-9859-3af14fa4ccfc.jpg or da12251d-1e9a-4032-afae-009876c6c5a3.jpg) in the notification area.
  2. In the list of available wireless networks, click a network, and then click Connect.
    Some networks require a network security key or passphrase. To connect to one of those networks, ask your network administrator or Internet service provider (ISP) for the security key or passphrase.
Whenever possible, you should connect to security-enabled wireless networks. If you do connect to a network that's not secure, be aware that someone with the right tools can see everything that you do, including the websites you visit, the documents you work on, and the user names and passwords that you use
Apr 05, 2011 | Sylvania G-Netbook
Can i get a new access point for my computer since my family members hid it??
Of course, providing you have sufficient rights on your computer. Go to network connection. click on the wireless adapter. go to advance settings and refresh the wireless list. Make sure the box at the top - let windows manage my connection is checked-. The wireless access point should show up on the panel. Click connect on this.
Jul 06, 2010 | EnGenius EUB-362 (EUB362 EXT) Wireless...
I can't get it to work.
To view the wireless network connection dialog box, follow these steps:
  1. Click Start, Run, and type ncpa.cpl, and then click Ok.
  2. Right-click the Wireless Network Connection icon, and then choose Properties. (Or you can right click the Wireless Network Connection icon and choose View Available Wireless Networks from the shortcut menu.)
  3. Click the Wireless Networks tab.
  4. Under Available networks, click the View Wireless Networks button.
From the wireless network dialog box, you can refresh the network list. This performs another scan of wireless networks within range. The wireless network connection dialog displays the following for each detected network. The following shows the new connection box.
When the wireless network adapter displays the detected networks, you'll able to select a wireless network name and attempt to connect to it. The antenna icon indicates an infrastructure mode wireless network. The icon that shows two wireless client computers indicates an ad hoc wireless connection.
The lock icon and the "Security-enabled wireless network" label indicate that the wireless network has security enabled. The gold lock means you need a network key in order for you to connect to a wireless network. If it's not security enabled, you'll be able to connect to the network without a network key.
Apr 28, 2009 | Airlink AWLH3026T 802.11g/b Wireless...
Dont know how to install wireless net gear for wireless ant.
The instructions are on the CD that should have come with your adapter. Few companies supply anything in print now; the manual is usually in a pdf file.
Put the CD in and start the installation program. It will probably start automatically, in fact. The program will guide you through whatever steps you need to follow. Usually it's just a matter of installing the required drivers, maybe restarting your system, then plugging in the adapter.
Once the adapter is installed, you run the connection software, pick your network from the list it will show you, enter any security passphrase your network requires, and you're wirelessly connected. You may also need to configure wireless operation on your router if that hasn't been done yet.
Apr 20, 2009 | Computers & Internet
Unable to connect to wireless network
Re-Enter your wireless key correctly is normally what thats means
Mar 15, 2009 | NetGear WG311T 802.11g/b Wireless Adapter
D-link DGL-3420 wont work with Xbox 360 and Airport Extreme
For gaming it is best to use WEP personal, if you are try connecting with a computer. A linksys or cisco router is ideal.
Mar 14, 2009 | D-Link DGL-3420 Wireless Adapter
Cannot connect to wireless network
may be your router needs a firmware upgrade.
check the router's website.
and make sure the router and the wireless card are both using the same 802.11 protocol
Feb 22, 2009 | Linksys WMP300N Pre-802.11n Wireless...
PCI G802 wireless adapter installed, can't get on internet
You must install driver included with PCI adapter using driver CD. Follow the steps shown during installation. Your Adapter will start successfully.
Dec 27, 2008 | Computers & Internet
I have a Compaq PC with Windows XP and the flat I've moved into has wireless broadband - how do I connect to it?
You can use a wireless network to share Internet access, files, printers, and more. Or you can use it to surf the Web while you're sitting on your couch or in your yard. Plus, it's easier to install than you think.
There are 4 steps to creating a wireless network:
1.
Choose your wireless equipment
2.
Connect your wireless router
3.
Configure your wireless router
4.
Connect your computers
For Windows XP users, Windows XP Service Pack 2 is not required for wireless networking, but it does make things much easier. Service Pack 2 also helps protect you against hackers, worms, and other Internet intruders.
If your computer does not have wireless network support built in, plug your network adapter into your USB port, and place the antenna on top of your computer (in the case of a desktop computer), or insert the network adapter into an empty PC card slot (in the case of a laptop). Windows XP will automatically detect the new adapter, and may prompt you to insert the CD that came with your adapter. The on-screen instructions will guide you through the configuration process.
Note: The steps below only apply if you're using Windows XP Service Pack 2. If you're running Windows XP and you don't have Service Pack 2 yet, plug your computer into your wireless router and download and install Windows XP Service Pack 2.
Windows XP should show an icon with a notification that says it has found a wireless network.
wireless_connected.gifFollow these steps to connect your computer to your wireless network:
1.
Right-click the wireless network icon in the lower-right corner of your screen, and then click View Available Wireless Networks. If you run into any problems, consult the documentation that came with your network adapter. Don't be afraid to call their tech support.
2.
The Wireless Network Connection window should appear and you should see your wireless network listed with the network name you chose. If you don't see your network, click Refresh network list in the upper-left corner. Click your network, and then click Connect in the lower-right corner.
wireless_chooseconnection.gif 3.
Windows XP prompts you to enter a key. Type the encryption key that you wrote down earlier in both the Network key and Confirm network key boxes, and then click Connect.
4.
Windows XP will show its progress as it connects to your network. After you're connected, you can now close the Wireless Network Connection window. You're done.
Note: If the Wireless Network Connection window continues to show Acquiring Network Address, you may have mistyped the encryption key.
Nov 05, 2008 | Compaq Computers & Internet
Blitzz BWU 713 Wirless G
Here is a link to get the drivers for the BWU 713 wireless adapter: http://list.driverguide.com/list/company2072/index.html This site requires you to register for free in order to download the file. After you install it, go to START, CONTROL PANEL, NETWORK CONNECTIONS. You will reach a window that shows some connections with computer icons. Right-click on the wireless connection and select 'view available networks'. In the next window that pops up (in the left pane) click refresh network list. If there are any wireless routers in your surroundings, they will show in this same window on the right. These drivers are for windows 9x and xp. They might not work for vista. If your OS is vista, please let me know so I can try to locate a vista driver. Hope this works for you. Lolita
May 15, 2007 | Blitzz Technology Wireless G BWU713...
Belkin (F5D7050) 802.11a/g/b Wireless Adapter Logo
101 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
