Question about Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi
95 chevy blazer 4.3L fuel in anti freeze
I am having white smoke and i have the smell of fuel in antifreeze siphon tank,but doesnot run hotThanks,
    Genius:
  • 1,066 Answers
Your head gasket is about to go, which could possibly ruin your whole engine.
Posted on Mar 11, 2009
  • 344 Answers
Did you install a bulldog product in your 95 blazer?
Posted on Jan 25, 2010
  • 41 Answers
There is probably a broken cylinder head gasket.
Posted on Aug 26, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Overheated due to a heater hose leak all hoses were replaced but now have white smoke coming from tail pipe that smells of antifreeze
White smoke is burning antifreeze. You have more than likely blown a head gasket which is allowing coolant into the combustion chamber where is is being mixed with fuel and burnt.
Aug 07, 2011 | 1999 Chevrolet Suburban
There is white smoke coming out the tailpipe no smell of antifreeze
If it doesn't smell like sweet then you most likely got a bad tank of gas. Just to be safe keep an eye on your engine temp. and coolant levels.
Mar 26, 2011 | 1993 Dodge Intrepid
I HAVE WHITE SMOKE COMING FROM TAIL PIPE WHEN IDILING.NOT RUNNING HOT JUST SMOKE
If the smoke has a sweet smell, it is burning antifreeze, if not, it probably just water in your fuel, add some water remover to the tank.
Feb 23, 2011 | 1992 Cadillac Brougham
My blazer is throwing out white smoke when i accelarate. it smells like gasoline. and there are times when my blazer does not turn on, and i have to jump start it.
white smoke means your getting water or antifreeze in exhaust, maybe a blown head gasket, best way to check is give it a compression test
Jan 06, 2011 | 1999 Chevrolet Blazer
White heavy smoke coming out when engine running whith a slight noise from the engine can you help.
head gasket has gone white smoke is water vapout (steam) best advice here is to trade it in on plan renewel
Mar 07, 2010 | 1987 Peugeot Liberte
My Chevy Tahoe started blowing white smoke from the tailpipe. What could be some of the reasons it's doing this.
Only two reasons for this first is its below 0 outside the next is blown head gasket. Now thats WHITE smoke.ONLY.If it smells sweet like anti freeze that confirms head problem. black smoke is fuel, blue smoke is oil. sorry hope this helps TIM
Feb 18, 2010 | 1997 Chevrolet Tahoe
White smoke from tailpipe and low oil pressure
How's the anti-freeze doing? Usually when you see white smoke coming out the tailpipe it's because you are getting anti-freeze in the exhaust somehow. Try to sniff it a little does smell like anti-freeze, or oil? I don't know why the oil pressure would be low unless you are getting anti-freeze in the oil. Does the oil look milky, knda like chocolate milk? The low oil pressure could also be a faulty gauge, you may want to have a mechanic put a mechanical gauge on the car for test purposes.
Feb 03, 2010 | 1995 Mitsubishi Eclipse
325ci loses antifreeze. no leak on ground.smells in the vehicle.
If you smell anti-freeze in the vehicle, you have a ruptured heater core.
Jan 11, 2010 | 2001 BMW 325
White smoke and a smell of fuel
The white smoke is from anti freeze. The smell of gas in your oil is probably from the same cause. I do beleive you did not clean the milled ares good enough before installing one or both of your gaskets. Just in case you did loosen one of the head bolts up for any reason....One bolt I do beleive on the right front bank of this engine has to be also sealed before re enstalling it for coolant will pass through it if not sealed
May 24, 2009 | 1991 Honda Prelude
95 Chevy Blazer 4.3 white smoke at idle
my 1988 chevy blazer 4x4 smokes on cold starts till it warms up then it goes away what is causing it
Jan 11, 2009 | 2007 Mercury Hybrid 4WD Hybrid
Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi Logo
341 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
John
John
baire
john h
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
