Home | Honeywell | Power Humidifier: Furnace Humidifier/ Hum... | Amana Furnace runs shu...
Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Problem for Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Amana Furnace runs shuts down then relights
By rob12961 on Jan 11, 2009
My Amana Furnace runs about 2 and a half minutes then the flame shuts down.The fan will stay running for about 90 seconds then the furnace will relight and run another 2 minutes. then the fan will run another 90 seconds the shut down until heat is called for again.
Same Problem
Apr 21, 2009
-   I have the same problem with my Amana furnace. Furnace cycle starts, flames go, then stops, and repeats cycle several times until furnace "gives up." The flame detectors have been replaced a couple times by the local HVAC Co. but shortly after the 1 yr warranty expires, the problem recurs. I suspect the flame detectors are toast. Also, this causes the igniters to cycle WAY more than they should, and they start to degrade, too.-   dietrich284
Best Solution
posted on Jan 13, 2009
Helpful)
lloydinmexic
Rank: Apprentice
Rating: 85%, 1 votes
flame rod sensor
Was this helpful?
Yes
No
Popular Solutions for Honeywell Power Humidifier:
Questions and Unsolved Problems for Honeywell Power Humidifier:
Do you recommend Honeywell Power Humidifier: Furnace Humidifier/ Humidifier?
Answer
Answer
"replace better" msg light came on; I replaced with 3 AAA Alkalines...3 days later, same... (More)
Answer
Mod#BLU100K948A The 2 selenoids on top of gas valve click when they open (normal). Sometimes they... (More)
Answer
I am trying to wire a honeywell true steam humidifier for a honeywell zone system
Answer
wait 5000 humidifier will not cycle on even when i use a hair dryer to blow hot air
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Honeywell Power Humidifier:...:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
