Question about Denon Avr-1613 Home Theater Receiver
Denon 1613 green light flashes and then turns unit off
Turns on and grren power light flashes and shuts off immediately
SOURCE: denon avr2105
See this post:
http://www.fixya.com/support/t421934-power_button_flashing_red
Sounds like the same problem to me...
Posted on May 26, 2008
SOURCE: my denon reciever display wont't work
I read something the other day in the user manual about re-setting the microprocessors if the display doesn't display properly. Turn the amp off.  Hold down the input mode & analog buttons while turning power on. The whole display should flash on & off at 1 sec intervals, then release the two buttons. This resets the microprocessors & supposedly fixes display problems.
Posted on Jul 17, 2008
Foxyjay
  • 13 Answers
SOURCE: Power Button Flashing Red
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Posted on Aug 16, 2008
  • 3 Answers
Try unplugging the entire unit and letting it sit for 5 minutes. See if this helps. If not, you need to do a complete reboot, which will cause you to lose your settings, but will probably solve your problem. To do a complete reboot, you will need to hold down two of the front bottons on the front panel. I'm not sure which, so either consult your manual or see other posts here which describe the reboot process for Denons. Hope this helps.
Posted on Jan 05, 2009
  • 11 Answers
SOURCE: unit''trips'' off shortly after powering up
Disconnect ALL of the speaker wires from the back.  Turn it on again, if it still trips, then the unit needs to be repaired.  If it does not trip with no speaker wires connected, turn it back off, connect 1 speaker at a time and turn it on, when it does trip, that speaker that you just put on has a short somewhere, it could the be the wire or in the speaker.
Posted on Apr 02, 2009
Why won't it turn on?
Hi Scott,
Green light flashes and the set goes back to stand by means it is trying to start but the action is not completing because of some fault either in the power supply itself or some other section. Please consult some local TV Tech to handle it.
Aug 07, 2015 | Sylvania LC320SLX 32 in. LCD TV
Why does the On/ off button keep flashing red fast . on the AVR 1613 ?
Does the display ever come on when you hit the power button?
Aug 11, 2014 | Denon AVR-1613 Receiver
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
Red power light blinking on my denon avr 1907, tried reset procedure, no speakers hooked up now and it still goes from green light to blinking red light and shuts off...Any clues?
This is a protection mode. The receiver protection circuit detects an internal problem like missing power supply voltage or blown channel and shuts down the receiver. You need to bring the unit to a repair facility.
Sep 26, 2011 | Denon AVR-1907 Receiver
The green light flashes when power is turned on and then flashes red and turns off. Can this be reset ?
what do i do when my DENON AVR-1506 turns on then flashes red and turns off?
Mar 08, 2011 | Denon AVR-1506 Receiver
It turns on light turns green then shuts off flashing green light
Typical for that model. You have bad power supply or bad channel.
Thanks, ebcelectronics
Nov 17, 2010 | Denon AVR-788
Shuts off then red light indicator flashes, disconnected all speakers but still wont work
Hi, this is a power board issue. remove the cover and make sure that this unit doesn't have blow fuse. if the fuse is fine, you will then need to replace the integrated power/ main board.
May 21, 2009 | Denon AVR-1803 Receiver
Dec 14, 2008 | Denon AVR-1908
Power wont stay on
Hope your under warranty mate and if so hope its not in Australia as they cannot fix this problem. My denon was allegedly fixed twice but has now failed a third time (just out of warranty) and denon have turned their back on me.
SHAME ON YOU DENON.
Jul 08, 2008 | Denon AVR-2105 Receiver
Denon Avr-1613 Home Theater Receiver Logo
260 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
