Technika lcd32-207 reset switch
Blue flashing light
Shuttle83
  • 1139 Answers
SOURCE: technika lcd 32
Hello hibbie,
I gave this advice on another post, it applies in this case too so here it is:
This is an indication that there may be a problem in the power supply, possibly bad capacitors, and or defective active components. I would suggest first checking to see if there are any blown fuses, and or loose connections. Past this point I would advise that you either take the TV to a TV repair shop or have a TV technician troubleshoot the TV in home to determine the problem it is having.
I hope this helps,
Thank you,
Shuttle83
Posted on Aug 10, 2008
ginko
  • 19396 Answers
SOURCE: blue flashing light. will not turn on at all.
Hi.
If the TV stays in stand-by, with the LED light on, but does not respond to remote, or to the buttons on the chassis, then that means that the TV has gone in protect (safe) mode because an internal fault had been detected.
Follow the basic troubleshooting on this article: Why my TV does not start up, by disconnecting power cord and connected devices. The article is for rear projection TVs procedure is same on CRT, LCD and Plasma TVs. Disconnect power cord for at least 30 minutes, and test using different connected devices.
If that does not work, then a technician must test the TV and replace the faulty component. In that case contact the support number listed on the owner manual to get the TV repaired by a licensed technician.
Regards.
Posted on Mar 14, 2010
SOURCE: Technika lcd32-207 is stuck in standby. Blue standby light dims.
Hi brendafoud, have you had this fixed as mine is the same and has been for months. It happened just after the warranty had ran out(typical). Bought from ebay and the people I got it from are not very helpfull. Have you got yours fixed yet?
Posted on May 05, 2010
  • 82 Answers
SOURCE: the blue flashing light will not stop flashing on
Had the same problem, i removed all the plugs of the PCU power suply board then replaced them all again , blue light stoped flashing, if this does not cure problem try constantly swithching on and off on power switch for a good number of times as i have been told that this some times cures the problem as it in fact trying to sort the programes out not sure if this is true but it's worth a try. best of luck.
Posted on Jan 19, 2011
SuperTech-11
  • 1591 Answers
SOURCE: I Have A Technika LCD32-209X
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Jun 26, 2011
Technika 22-700 standby light flashing
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 25, 2013 | Televison & Video
Technika lcd 32-207 television powers up but will noit come on blkue light keeps flashing
Hello.
if the blue lights keep flashing you have shorted parts inside. usually the inverter board have a shorted IC, try to remove the connector from inverter then try again..
if your blue lights lit replace the inverter which you disconnect.
Dec 06, 2012 | Televison & Video
Technika flat screen - model No LCD19ID-107. WHEN
There is a Diode and probably a Resistor blown on the power supply board... Check out the fix on my website:
http://normsweb.com/tektips/technika.shtml
I hope this helps you.
May 18, 2010 | Televison & Video
Technika fm/digital frozen
Possible shorted power supply capacitor or bad diode.
Rod
Apr 20, 2010 | Audio Players & Recorders
Technika flat screen: Will not switch on, the blue standby light just flashes
Technika flat 32 screen: Doesn't not switch on, the blue standby light just flashes.
Apr 14, 2010 | Televison & Video
Jul 09, 2009 | Televison & Video
I want to reset my TV
well when the blue light is on and ur tv is on standby, just use the channel changing button, simple!
Dec 06, 2007 | Televison & Video
Televison & Video Logo
175 people viewed this question
Top Televison & Video Experts
Electro Med Services...
