Question about Nokia 3120 Cellular Phone
Phone is asking to enter security code number while switching on
My phone is nokia 3120 ......security code is asking while it opens
  • avinashkisho Mar 30, 2009
    phone is asking to enter security code number while switching on" problem
  • dohancrp Apr 21, 2009
    This is not working is there other codes?
Security code is 12345
Posted on Jan 11, 2009
Password reset code
In order to reset the security phone codes of a Nokia 3120 Classic, you must do the following:1.Press the phone's 'menu' key.2.Select 'settings', and then 'security settings'.3.Select 'Access Codes', and then enter the requested security code for your Nokia 3120 Classic. The default code is '12345'.4.Select 'Change Security Code', then enter the desired code.5. Press the phone's 'exit' key. GOOD LUCK LET ME KNOW IF IT WORKS
Dec 29, 2013 | Nokia 3120 Classic Cell Phone
FORGOT MY NOKIA 3120C-1C SECURITY CODE
If you forget the security code, please try nokia master reset code : 12345. If it fails , just get the code by key in your IMEI number at :
www.nfader.su
or
www.nokialockcode.com/calculate.php
Regards, Jay
Feb 24, 2011 | Nokia 3120 Classic Cell Phone
When on my nokia 3120 asked restriction code
First Try it
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
1. Switch off your Nokia phone
2. Now Press following key sequence *#7370# or *#7780#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button and switch on the phone.
5. Wait for message ‘Format it http://www.unlocknokia.us/index.php Thanks
Aug 28, 2010 | Nokia 3120 Cellular Phone
I need to reset my nokia 3120 security code. Already tried typing in the master code but to no avail. It says code error.
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
You could ring the phone provider and ask for the unlock security code because you are going overseas and wish to use your phone with a prepaid SIM card from another country. This maybe a free service.
The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services. Use Google and search for "Security unlocking code” companies in your area.
You can also try this WEB site :-
http://www.mobileunlockguide.com/mobile-phone/
www.unlock-free.com/nokia-master
Jan 04, 2010 | Nokia 3120 Cellular Phone
How to reset security code for nokia 3120 classic, i cant use my phone...
I put a security code to my Nokia 3120 classic mobile. But suddenly it asking me the security code n when i provide the correct one it says code error. www.UnlockMe.co.uk doesn't work. They mentioned there that 3120 classic phone is incompatible for this master code method. pls give me a solution......
Jun 07, 2009 | Nokia N72 Cellular Phone
Forgot security code
First, don't EVER EVER print your IMEI number. Hackers can easily take over the telephone using that number.
Typically it's all zeros, or all 1s. I know when I used that particular phone it was *1 to disengage the lock on it. OR as my moms was **** [4 stars] that disengaged it...
Your company can reset it for you as well. Occasionally taking out the battery for 1 - 3 minutes will reset it...but not always...especially with Nokia.
May 30, 2009 | Nokia 3120 Cellular Phone
Let me have your IMEI code it is located behind the battery inlet.
May 25, 2009 | Nokia 3120 Cellular Phone
I forget my nokia 3120 classic mobile security code so how can i
IMEI(International Mobile Equipment Identity) needed to get you the master code.The imei number is a 15 digit number and with that I can provide you the master code which acts as security/master code.
THE MASTER CODE HAS TO BE TYPED 3 TIMES ONLY , SO BE AWARE.
The master code can be typed as security code,when the phone asks for code.
The pin number is different from this master code,since it is attached SIM(subscriber identity module) card
"OR"
"Give it to the Nokia care centre,they will clear it in 5 minutes(without asking any questions to you)"
Mar 04, 2009 | Nokia 1100
Nokia 3120 phone restricted code
hello
1_ can you save your formation in other phone .
2_that code format your phone for Nokia only
3_ *#7780# if you know your security numbers use it. if you don’t know it use 12345
4_ other numbers *#7370# and the security n ......
and look if the problem is solve it
because after this . you have like a new mobile
Jan 26, 2009 | Nokia 3120 Cellular Phone
Nokia 3120
Write here your phone's IMEI number here. To see the imei press *#06# in your phone. It will be of 15 digit.
May 25, 2008 | Nokia 3120 Cellular Phone
Nokia 3120 Cellular Phone Logo
202 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
