Question about Microsoft Xbox 360 Console
No video no audio
Watching dvd of Newsradio, picture started to look like a painting in motion, so I shut it off. When turned on again, green lines appeared across the screen, so I shut it off again. When turned on for the third time, there was no picture or audio. I've tried starting it up on other televisions, but with the same result. Do I grin and bear it, and save up for a new system, or is there something that can be done to save it?
    New Friend:
  • 40 Answers
Is there video when you are not playing a dvd? Example. Like playing a game or in the dashboard
Posted on Jun 13, 2007
Black vertical lines (watching DVD); blank but lit screen (watching TV)
After 10+ years of service, it is a likely candidate for replacement.
Mar 21, 2017 | Sony Grand WEGA KDF-42WE655 42" Rear...
Choppy Video? What do you mean choppy video? Is the video starting and stopping rather than playing continuous? If so, either you need more memory or the site you are watching the video from is slow. Also sometimes you line speed on the computer might be slow if you are watching the video online.
How does the video play if you played a DvD in your computer? If it plays the DvD without stalling, then your problem is more than like the site you are watching or the line speed as you stream the video.
Mar 29, 2012 | Computers & Internet
My panasonic viera television is only displaying green...we can hear the programs but no picture, only green
It is my pleasure to guide you.
What is the source the you are watching, video or tv show?
If it is a video from a VCR/DVD player then you may have RCA cables problems.
1. Component video/audio requires five connections,
a. Three for video (green, blue and red) and
b. Two for audio (red and white).
Check to see if all of the cables hooked up properly? The cables are color coded but the red one is used for both video and audio so be careful.
2. Composite video/audio uses three connections,
a. One for video (yellow) and
This will give you some where to start so
Good luck and please post back that you are successful, giving thumbs up, or that I can be more help.
Jun 10, 2011 | Televison & Video
Getting sound but no picture when watching dvd and in can't get sound from tv when watching tv
Thanks for using FixYa. Make sure the Red and White wire is connected into your TV “AUDIO IN” and the Red and White wire is connected into the L & R. Also check that the DVD player Audio setting Analog Out is set to “2 Channel” and the TV is turned to the correct Video line (AV Input/Video Input 1,2,3.etc). Once your TV is turned to the correct video line, you should see the “COBY” logo and it will work normally. If still the issue persists, then you’ll need to reset the DVD Player for which you’ll need to follow these steps---
Using the DVD player remote control: Open the Tray and press the “PROG” button and then press the “ZOOM” button.
Once the above procedure is performed the tray will be closed which means the DVD player has been reset back to the factory default settings.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Oct 18, 2009 | Coby Televison & Video
Where does the green wire go
the green wire is the "parking brake wire" which is supposed to go to the cars e-brake wire that grounds with it is engaged. this is a safety feature to keep you from watching video while driving. if you would like to watch videos while in motion. you will need to put a toggle switch on this wire.... one wire from the switch to 'Ground/metal chassi or black wire behind the radio , the other side of the switch to the liight green wire. it will act like your ebrake switch therefor allowing you to watch video while in motion.
Aug 17, 2009 | Pioneer AVH-5700DVD Car DVD Player
TV turns on with a green screen with curved horizontal lines.
It seems you may have a serious problem with your video board. That's why you are getting those symptoms. It's better if you replace it asap!
Aug 04, 2009 | Mitsubishi WS-48315 48" Rear Projection...
46 inch Sony flat panel lcd has vertical red and green lines down right side of screen and you can be watching tv and picture will go right out and leave grayish blank screen until restart. Black...
If the screen works for a short while and then completely fails once the TV warms up you have a problem with the main unit video board or the LCD control logic board. Most often if the picture cuts out but audio continues to work the logic board is over heating and should be replaced. However if the picture cuts out and audio shuts off as well then its your video input board.
Apr 28, 2009 | Sony Televison & Video
Audio Yes, Picture No
From your description, it could be the back light has 'gone'.
Feb 16, 2009 | Sony BRAVIA KDL-40V3000 Television
Tunner? Picture whites out
Is this when you are watching a DVD, or Tape, or when watching TV using the Combo's tuner? The effect you describe is caused by the video signal losing its DC level.
Hope Ya Fix it.
Jan 08, 2008 | JVC DR-MV1SUS DVD Recorder / VCR Combo
No picture or sound
perhaps the xbox is causing the tvs to malfunction. i would get a new one. remember that xbox is giving everyone a 3 year extended warranty on the xbox 360
Jul 31, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
75 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
