Question about Jamo SUB-650 Subwoofer
Jamo sub has power and just the red light on but no green light, if i unplug it from the Yamaha receiver and plug it back in it works then eventually the green light on the sub goes to red and no bass
I switch out the coaxial cables to see if it was old cables but still same problem.
SOURCE: just got a jamo A3SUB.3
check all your plus sign and minus sign that connected to the receiver , if connected wrong you will not have any bass,because it going backward. Good luck!! any quest email me jimmytnguyen71@yahoo.ca
Posted on Jan 30, 2008
sanjin
  • 56 Answers
SOURCE: I have no amp for jamo 1060 sub
Dual Voice-Coil
The unique Dual Voice-Coil design allows both left and right channel sound from just one speaker. Simply hook up both the left and the right channels to the special terminals on the speaker. Hook up one channel only, if the speaker is to be used in a conventional stereo set-up.
I found this on jamo site hope that will help you
Posted on Mar 18, 2008
  • 151 Answers
SOURCE: JAMO SUB 650
The jamo sub is a fine buy but also look at subs from REL as they can hit hard when needed and are great for music.Now on to your amp,look round the back and you should find a socket marked sub pre out,plug a sub or phono lead into this and then into the input on the sub,this could be marked in or line in,turn up the volume or gain on the sub and also make sure you have the sub turned on in the speaker settings in your amp.
Hope this helps.
Cable guy.
Posted on Jun 27, 2008
  • 127 Answers
SOURCE: my jamo sub 200 & pioneer vsx517 receiver is not working properly
What do you mean that it sometimes doesn't work? It doesn't power on automatically?
Check settings of your receiver - if it has subwoofer output enables and if low frequencies from all channels are directed also to the SUB. By default only the LFE channel (.1) of 5.1 signal input is fed to the subwoofer. So Sub will work in this case only when you listen to 5.1 signal (DVD movie for example), but for radio or stereo music, only front speakers are used. By configuring this bass redirect, you can use subwoofer for all signal types.
Posted on Mar 03, 2010
  • 127 Answers
SOURCE: I have bought JAMO sub 250 subwoofer and Pioneer
You don't need such cable, although you can use it if you have one. If receiver has only mono SUB output (as majority of receivers have), you just connect it to the Left socket on the Sub and it will work.
Using the Y cable would probably cause that you will fed the same signal to both left and right sockets, but half the intensity (you would divide the output from receiver by 2). So in the end the Sub would receive exactly the same signal as when using normal straight cable.
Why won't my a102 speakers from jamo witch came
The Jamo speakers need an AV Receiver to drive them properly. The TV doesn't have the correct outputs nor does it have the power required.
The Jamo kit consists of a powered subwoofer ans 5 small surround speakers. Each surround speaker needs to be powered by the speaker output from an an AV Receiver. The subwoofer should also be connected to the receiver, but the connection is a phono/RCA lead from the receiver's "Sub Out" socket.
Your TV connects to the AV receiver via the Optical out.
Sep 01, 2014 | Audio Players & Recorders
I brourt a jamo sub 200 and five a102speakers but
Aug 31, 2014 | Audio Players & Recorders
Please help! Jamo SUB 300 subwoofer still blows (0.8A) fuses after replacing a faulty thermistor, despite a high ohms reading directly across AC mains terminals on the board. What is causing the fuse to...
hi,
i have a jamo 250 sub.the blue light is working.when i connect the jack to the left line IN according to the manual it makes a sound as well.but seems not working.is it related to the fuse????i know the fuse box.but i dont know how to remove the fuse to check.pls help me out.my receiver is onkyo tx-sr 608
thank you
ron
Jan 08, 2011 | Jamo SUB300BA SUB 300 Powered Subwoofer...
My jamo sub 200 & pioneer vsx517 receiver is not working properly
Feb 08, 2010 | Jamo SUB 200 Subwoofer
I am trying to hook up a powered sub woofer to a yamaha rx-v461 and i dont know what cables go where on the back of the sub there are two speaker ports and there are two plug ins but each speaker port has...
Your subwoofer probably has both high-power inputs and "normal"low inputs. The first are for receivers, which don't have link-level output for sub, so they are able to take already amplified signal as input.
You need to use link-level input of your sub and connect it to subwoofer-output of your receiver. The output is marked as OUTPUT - Subwoofer and is black-color RCA plug (don't confuse with subwoofer INPUT under MULTI CH INPUT).
Receiver has only mono output for subwoofer. If your sub has stereo input (white/red RCA plugs), connect just the left channel to the receiver, it will still work.
Don't connect anything to the speaker output on the sub, you don't need that.
Sep 28, 2009 | Yamaha RX-V461 AV Receiver
JAMO SUB 650
hi
since it is a powered speaker, probably it just needs a sound signal which you can get from the headphone socket. please double check with someone else.
May 26, 2008 | Jamo D 4SUB Subwoofer
Subwoofer
i have the same tuner.on the back you will see all connectors bottom row of rca jacks you will see subwoffer if your sub has to rca. red/white use a splitter monstor cable gold ..works best. i use Home Theater Reserch speakers... you can also plug your subs power plug into the tuner snd you never have to power it on seprate .........
Dec 08, 2007 | Yamaha HTR-5230 Receiver
Jamo SUB-650 Subwoofer Logo
Top Jamo Audio Players & Recorders Experts
Electro Med Services...
Tom Chichester
Steve
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
