Question about Microwave Ovens
How to replace the lamp inside model nn-sd698?
3 Suggested Answers
dmftrucker
  • 1922 Answers
SOURCE: Lamp inside my NN-C784MF blown,where can i find a
appliance parts pros 1-877-477-7278
Posted on Nov 01, 2009
ginko
  • 19396 Answers
SOURCE: can I replace the lamp in a panosonic microwave oven model NN CT 857
Hi.
The lamp replacement requires complete removal of the oven external casing. The oven must be tested for radiation leakage after the repair. The replacement must be done by a trained technician. Disassembling procedure is illustrated on the service manual available here: Panasonic Service/repair manuals,schematics.
Regards.
Ginko
Posted on Dec 15, 2011
I have model #NN-5543BFW need to change light bulb here is it???
The lamp is located inside. The cabinet has to be removed to replace it.
Dec 27, 2014 | Microwave Ovens
How do you change the light bulb in a panasonic microwave model nn-st657w
Switch off power ,Remove the top panel cover and the lamp will be visible within. Now unscrew the lamp cover and remove the lamp . check for failure and replace with the same wattage and thread.
Jan 10, 2013 | Microwave Ovens
Can I replace the lamp in a panosonic microwave oven model NN CT 857
Hi.
Regards.
Ginko
Dec 15, 2011 | Panasonic Microwave Ovens
I have Panasonic Microwave oven, model NN-S263WF, serial number 6A63130072, one of the light bulb on the left is burnt out, how do I access it and replace it ? Thank you.
Replacement of the lamp should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its position is adjacent to the vent holes that it shines through.
If you feel confident, disconnect it from the mains power, remove anything in the cavity.
Remove the microwave cover. Purchasing a new replacement lamp will be useful as it will give you an idea of what it looks like. Locate the dead lamp remove the lamp and fit the new one. Replace the covers. Plug it back in and try the lamp by opening the door.
Hope this helps.
Feb 14, 2011 | Microwave Ovens
My model is nn-s253wf, micowave stopped working, no power, checked circuit breaker, is ok ?, unplugged, then plugged back in, still no power ?
Inside the external case and usually to the right left ( from Front) in some models There is a 30 amp fuse ( This may vatry on oven output amperage) Replace that and you should be back in cook mode.
Removing the case you should remember to disconnect from the power plug.
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Panasonic NN-S252WF Microwave Oven
Have a Panasonic Micro nn-T790 SA, need to replace light???
If you don't see an access panel inside the oven, you must remove the outer cover to find & replace the bulb. Be sure to unplug the oven first!
Many models use halogen lamps. You must not touch the new one with your bare skin as the oils will shorten the bulb life.
If you don't have your owner's manual, you can download it here: http://service.us.panasonic.com/OPERMANPDF/NNT990SA.PDF
We're happy to help and we appreciate your thoughtful rating of our answer.
May 17, 2008 | Panasonic NN-T790SA Microwave Oven
Inside light is burned out.
The Sears parts Web site has a ton of helpful info on this model, including disassrembly help. Looks like a lot of the actual service manual online! You can also order parts there. Enter your whole model number NN-S567BAS at http://www3.sears.com/ (the 3 is correct) Terrific!
Dec 26, 2006 | Panasonic NN-S567BA/WA/LA Microwave Oven
Microwave Ovens Logo
66 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
