Question about Panasonic PT-51HX41 51" Rear Projection Television
Convergence for HD channels only
I just replaced my convergence IC's per all the great advice online and it fixed all the channels except my HD channels (through cable). The HD channels still have the red ghosting problem. My TV is a Panasonic PT51HX41E Are there other Resistors/caps/fuses that need to be replaced? Thanks in advance
  • Phil Winters Jun 09, 2007
    Thank you. Worked like a charm
What were the IC part #'s for the PT51HX41E? And where did you order them?
Posted on Jun 19, 2007
    Sergeant:
    Champion:
  • 326 Answers
Hello, please check the IC7102 (24LC64). This is eeprom that contains the convergence data. Please ask the Panasonic dealer if they can supply a replacement IC with the data for your HD. If you need more info please advice. Arpi
Posted on Jun 08, 2007
I have an rca r52wh77 it is bowed in the top and bottom. it also is way off in convergence and i can not seem to get the crosshatches to come together. i have changed the fl123 part that was sent in my kit...
Does the kit have a pair of convergence ICs? That is what you will need to fix the convergence problem. The kit should also contain thermal grease(a white paste that should be applie to the ICs before you solder them) and resistors that may also need to be replaced. When a convergence IC blows its usually due to failed resistors.
May 26, 2011 | Televison & Video
I am not sure what it is called but in the middle of the screen the picture is great but the further you go left or right the colors are not alligned they start off by only alittle bit but get...
You are suffering from a convergence problem. In this case I recommend you see a TV tech. To pull the convergence board is a real chore. Your convergence board will have too many bad grounds to even begin to count. You may not have to replace the convergence IC. The IC will be of a STK-393-110. In many cases this IC will be replaced by an after market part. You will have to check and replace resistors of a 2 watt value of about 3.9 ohms. In good faith, the TV man will replace this convergence IC ,as to try to correct the problem the first time. Good advice for the ,do it your selfer. Take this note to a TV tech. Some knowledge could save you a few bucks. Thanks for asking and show all hands of support!
May 04, 2011 | Mitsubishi WS-55819 55" Rear Projection...
I purchased a tv repair kit and replaced the convergence ic chips to fix my convergence problem. put everything back together and now, no picture. I tried magic focus and it works great, the colors are...
As per statement, "the magic focus works great, the colors are bright and aligned" it means the tubes are working ..you need feed a signal to see the picture...the tv video goes muted without signal
Dec 29, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Only HD channels have 3D look - Sony KP-57HW40
have you ran magicfocus on hd channels and if you have and still have problem
it will most likely have to have adjsutments done in the service menu when running on a hd signal
Oct 24, 2009 | Sony KP-57HW40 57" Rear Projection...
Hitachi Projection Color Lines
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
Horizontal Curvature with convergence problem
DA, convergence circuit has failed, the IC`s and possibly a couple of support resistors need to be replaced, your right about it being a good set, 6 years is about average for convergence IC`s, call your local shops for a few estimates and get it fixed, it will run for a lot longer than 6 years, hope this is the advice your looking for, e-mail me if you have more questions, BMW Rider
Dec 10, 2007 | Toshiba 65H81 65" Rear Projection...
Green tube not converging properly
Replace both convergence IC's.....STK392-110 X 2........T.
Nov 15, 2007 | JVC AV-48WP74 48" Rear Projection...
Right side convergence
A convergence IC has burned out. If I remember correctly, those Pioneer sets have one huge convergence IC, but that IC only has 5 channels in it so they use another smaller dual STK IC and one half of it is used for the 6th channel and the other half is the vertical output. Look on the convergence board, find the blue convergence jack, identify the blue horizontal channel, follow the traces and replace the IC handling the blue horizontal channel.
Aug 28, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Phillips 60PP920217F Convergence Problems
replace ic chips pt# stk392-120 or stk392- 150 and there are 12 resistors located near ic clips pt# 6r8 ( color code blue - gray - gold - gold ) board location no#s 3149 thu 3160 if you look close you may find two resistors discolored as i found on my convergence circut board , also use heat sink compound on new ic chips , take your time to mark all wire connectors going to board from tv , also use .022 dia gage rosin -core solder and a 15- 25 watt soldering iron you may have to adjust the red - blue convergence afterwards my tv set is 3 yrs old also ( thanks holbert )
May 03, 2007 | Philips 60PP9202 60" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
118 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
