Question about Cisco - Linksys Wireless-n Home Router - Black (wrt120n)
WHERE IS THE WPS BUTTON ON MY ROUTER LINKSYS WRT120N
Where is the WPS button
2 Suggested Answers
  • 3287 Answers
SOURCE: I have a CISCO Basic Wireless Router. Can this
The router is capable of at least Wireless B (11MB) and possibly Wireless G (54MB) or Wireless N standard speeds. The HP Photosmart will do at least Wireless B speeds (and depending on which model - even possibly the faster "G" or "N" standards, too), so yes; it can be connected wirelessly.
You'll have to set up the the HP Photosmart printer the same way you set up other wireless devices to connect to the router. You'll need to input the SSID, Security Encryption Type (WEP or WPA) and associated security "Key" to match those settings that are in the router.
If you can't remember those settings, or never set up the wireless options, you'll have to access the Cisco Router's built in web set up page. Since you didn't include your particular model number, you'll have to look up this info at Cisco's web site yourself.
If you have trouble, include the model of your router and I'll see what additional info I can get for you.
Please rate this reply - thanks!
Posted on Jan 11, 2011
Where is the WPS button on linksys wireless-N router
you need to look at the back of your router you will able to see a blue color button . this button is known as wps button .
Dec 30, 2013 | Linksys Wireless-N WRT150N Router
Where is the was button
I'm guessing you mean the WPS button - "Wireless Protected Setup" - As far as I can see from the User Guide this router doesn't have an actual WPS Button - You need to log onto its admin web interface and browse to the WPS setup page - Press the WPS button on your client device (laptop, printer, etc) then Click the WPS button in the router's web interface and let them talk to each other to establish a secure connection - The WPS light on the Front Panel should then light up when connected - You can find a user guide at the following url:
http://downloads.linksys.com/downloads/userguide/1224642967100/WRT54G2-EU_V10_UG_combination_NC-WEB.pdf
Jun 14, 2013 | Linksys WRT54G2 V1 Wireless-G BROADBAND...
Factory restore
According to Linksys support, you should not reset your WRT120n wireless router unless you are having difficulties with the unit. The WRT120n user guide also recommends applying other troubleshooting options before attempting to reset the device. Resetting the WRT120n restores the router back to factory defaults. After resetting the Linksys 120n, you''ll have to reconfigure the router back to your preferred settings.
Locate the Reset button on the back panel of the WRT120n. The button is labeled "Reset" and situated between the power port and the "1" Ethernet port. Press and hold down the "Reset" button for five seconds. The device resets. Open a Web browser on your computer. Type "192.168.1.1" into the browser's address field, then press "Enter" on your keyboard. A login prompt opens. Enter "admin" as the password. Leave the User Name field blank, then click "OK" to log in to your router and access your network settings.
Apr 02, 2013 | Linksys WRT120N Router
Where is the wps button on a linksys router
Depends on the on router. The button should have a picture of an antenna on it or say WPS. Pres it and the light will flash then press the wps feature button on the device you are connecting. If this is a Linksys EX0000 model it should be on front and center on the top of the router.
Nov 23, 2012 | Linksys 2.4 GHz 802.11b Wireless - B...
I need a password for Linksys wireless router WRT120N no longer under warranty
Default Password is ADMIN
If you are not able to login.
Please reset the router for 30 seconds by pressing the router reset button.
Mar 04, 2012 | Linksys WRT120N Wireless Router
Forgot my password for wrt120n
Looking for the Linksys WRT120N default password? You probably have little reason to access your router on a regular basis so don't feel too bad if you've forgotten the WRT120N default password.
However, when you're troubleshooting a network problem and need to get in to the device, the WRT120N default password suddenly becomes very important.
For most versions of the Linksys WRT120N, the default password is admin. As with most passwords, the WRT120N default password is case sensitive.
In addition to the WRT120N default password, you can also see the WRT120N default username and WRT120N default IP address in the table below.
Note: The Linksys WRT120N default password may be different for certain hardware orfirmware versions.
If I have that information, I'll include the exact WRT120N version number along with the correct default password. You can usually find your Linksys WRT120N version number on the bottom of the router.
Be sure to change the default router password on your WRT120N to something more secure as soon as you're in. Then use a free password manager so you'll never forget your new WRT120N password.
Help! The WRT120N Default Password Doesn't Work!
At some point during the life of your particular Cisco Linksys WRT120N, the default password, username, and/or IP address might have been changed.
In most cases, if the Linksys WRT120N default IP address has been changed, the new IP address for the WRT120N will be the same as the default gateway IP address configured for your network connection.
See How To Find the Default Gateway IP Address for help.
In situations where the WRT120N default password or WRT120N default username has changed, you'll need to reset the Linksys WRT120N to factory defaults. You can usually do that via a special button or sequence of actions.
The WRT120N manual will have specific directions for performing a factory default reset. You can download the manual for the WRT120N from Linksys Support.
Please let me know if any of the WRT120N default login data below needs updated. For other questions about the WRT120N default information on this page, see my Default Password FAQ.
WRT120N Default Password & Other Default Login DataVersionDefault UsernameDefault PasswordDefault IPPrivilegesAll[none]admin192.168.1.1Administrator
Jan 13, 2012 | D-Link 802.11g Wireless Router WBR-1310...
Does my WRT160N have a WPS button and if so, where is it?
The Linksys WRT160N has WPS (Wi-Fi Protected Setup). If you are using WPA-PSK encryption (recommended), then you can easily connect the C4780 to your wireless network using WPS:
1) On the Linksys router, press the WPS button that is top of the case just under the Cisco label. When the LED on the button starts to blink, then the WPS process has started.
Jul 06, 2011 | Linksys WRT160N Wireless Router
How do I reset my router password
Here is the step-by-step instruction to reset Linksys WRT120N Router
  • First af all you have to make sure the power is "On" . Power the router up while pressing the reset button located at the back of the router using pencil or paperclip
  • After around 30 seconds you will be prompted with the boot loader. Connect the boot loader using the standard IP address if you have not changed it (http://192.168.1.1)
  • Upgrade the firmware to the latest one from Cisco site
  • Power cycle the router and allow it to come up.
  • When it is fully up, press and hold the reset button for 5 secondsThe LED light will blink indicating that you're done holding the reset bottom. If the Power LED won't blink try to press and hold the Reset Button for I minute and then power cycle the router for another 1 minute.
  • Power cycle the device and now you have reset your linksys WRT120N router See the following link if you forgot to setup linksys router
(http://infoteknotainment.com/reset-linksys-wrt120n-router)
May 24, 2011 | Linksys WRT120N Router
Where and what is the PBC button on the wireless linksys router?
Push Button Configuration (PBC)
NOTE: The PBC method is to be used if the wireless client device (device that you are using to connect to the network) has a WPS button (either an actual one or a virtual one).
Step 1:
Click or press the WPS button on the client device.
Step 2:
Click the WPS button on the Linksys device. A pop-up window from the Wireless > Basic Wireless Security tab of the Linksys device will appear. This window will indicate the progress of WPS client configuration.
Dec 31, 2010 | Computers & Internet
Cannot reset to factory settings my linksys WRT120N I tryed with reset button 30 seconds but nothing change
Turn the router off.
Hold the RESET button in, for 30 seconds.
Turn the router on, and see if it has reset.
If not, then with the router still on, hold the RESET button in, for 30 seconds, and see if it has reset.
Sep 30, 2010 | Linksys WRT120N Router
Cisco - Linksys Wireless-n Home Router - Black (wrt120n) Logo
122 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
