Question about Maytag Dryers
Remove door on maytag dryer model HYE3658AYW - Maytag Dryers
5 Suggested Answers
SOURCE: how to remove lint tray receiver: maytag dryer model#pye2300ayw
Unplug first with a straight blade screwdriver, pry up on the top of the dryer where the front wall of the dryer and the top meet. there are 2 screws 1 on each side inside the dryer where the sides and front meet, remove them and unhook the wires from the door switch. the whole front will now pull out and up, now open the door remove the 2 screws at the bottom of the door opening and the whole lint tray will pull out. sounds like a lot but only takes about 5 minutes.
Posted on Dec 04, 2008
  • 122 Answers
SOURCE: dryer wont dry, element comes on and off, model
Could be the thermal fuse. look online for your model and it should tell you where it is located. once you find it olh it out and see if it is open, if so it's a simple and cheap fix.
Posted on Aug 12, 2009
rylee_smith
  • 8619 Answers
SOURCE: need to install belt and
Hi
Thanks for using FixYa. Please check this video on how to replace the belt in dryer and check the idler pulley. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 11, 2010
  • 272 Answers
SOURCE: DRYER HUMS WHEN CNTROL KNOB
Greetings,
This sounds like the motor is bad, or going bad...I would have someone help you try and start it....open the door and hold the door switch in and keep holding the door switch while pushing the knob to start it and at the same time....have someone try and turn the inside drum usually, counterclockwise and see if it takes off....if it does...let go of the start switch up on console(timer),
but keep holding in on the door switch to let it run for awhile...you can shut the door real fast and it should keep running... if none of this works and it still will not start and just hum...the motor is bad
Posted on Dec 08, 2010
Dryer won't start the drum light doesn't come on either
did you check the breaker being tripped. do you know you have power to the unit?
Sep 15, 2015 | Maytag Dryers
Maytag Centennial 7 Cu. Ft. Electric Dryer, how to remove front
unplug it,remove the top panel screws in the back,remove the control panel and then you can remove the front.go here
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MDG9700AWW/3048/0151200/M0702017/00001?
blt=06&prst=&shdMod=
you'll see number 14 and 15,you have to remove the 4 1/4 inch screws on the top and the two phillips screws that are behind the door.
Oct 13, 2013 | Maytag Neptune MDG9700A Gas Dryer
Maytag mod#hye3658ayw
Open the door and push the door switch by hand. You should hear a click when you push and release it. If not you will need to replace the switch with this part. If the switch is good, post back to me and let me know.
Oct 19, 2012 | Dryers
Belt came of dyer where does it go
Most maytag dryers you cannot work from the back side. The old style dryer is accesed by removing phillips screws at the base of the dryer. The newer models use a putty knife to realease the top. Some models called slopefronts you remove the door and then the front to get to the innards.
I have a page on maytag dryers which features videos and service manuals. MAYTAG DRYER PAGE
Mar 06, 2012 | Maytag Dryers
DRYER HUMS WHEN CNTROL KNOB IS PRESSED & MOVES SLIGHTLY..IF HELD IN TOO LONG IT BKICKS BREAKER. MODEL#HYE3658AYW
Greetings,
Dec 08, 2010 | Maytag Dryers
How do you take the caSE OFF OF A MAytag Neptune model MSD5500aww dryer to check burner
Open the door, remove the screws holding the hinges, then the door. Then remove the screws on the opposite side of the door opening, the front panel will then come off.
Feb 04, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer wont dry, element comes on and off, model HYE3658AYW
Aug 12, 2009 | Maytag Dryers
Maytag Dryer won't turn on
Go to RepairClinic.com, find your model, and read the instructions!
May 11, 2017 | Maytag Dryers
How to remove lint tray receiver: maytag dryer model#pye2300ayw
Nov 30, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
57 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
