Question about GE Profile Spacemaker Over-the-Range Microwave
I have a GE spacesaver 2 microwave model number JEM31CA001. The unit will not respond unless it is unplugged and reset. After a couple of days, the same thing occurs. Sometimes it will not shut off unless the door is opened and then unplugged. Sometime there is no display at all.
MicrowaveSvc
  • 9098 Answers
SOURCE: GE spacemaker Profile XL1800 vent fan will not shut off
It may be a bad door switch, a loose door switch mount, or a problem on the control panel, such as a sticky relay.
I would suspect a sticky relay first, but the door switches should be checked.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
If you need your control panel assembly (smart board) repaired, we do that for $39.95 nationwide.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Dec 02, 2007
  • 108 Answers
SOURCE: GE Spacesaver XL JVM1341WW002 microwave broken door handle!
Its a free country Bage, but microwave energy is extremely dangerous! Repairs are not feasible unless performed by factory personnel under warrantry, and certified. I suggest you contact the manufacturer about the problem.
Ray
Posted on Nov 19, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Reset for GE Microwave?
There's no other reset function. If a reset (unplugging) does not correct it, it will need to be repaired.
If it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free. GE Customer Service is here.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I would suspect a blown fuse or the magnetron;s thermal cutout / thermal fuse.
Posted on Dec 28, 2008
  • 52 Answers
SOURCE: Broken door handle on GE Spacesaver microwave
TIP: Go to the web and type www.partselect.com enter your model number then scoll down to your part. Panel,door (PANEL DOOR) click to enlarge exploded diagram on left. Veiw enlarged diagram at top of page. You can print the entire diagram for exact assembly by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. If you found any of these suggestions helpful, please rate my solution. D. Lange
Posted on Apr 26, 2009
praky16
  • 744 Answers
SOURCE: The microwave oven does not have power to the panel.
HI, this will require the skilled hands of a qualified GE tech. the damaged part here is the Magnetron assembly. this is a very sensitive part that creates radiation and the heating process as well. you will need to replace this device asap if possible.
Posted on Jul 02, 2009
MY GE SPACESAVER MICROWAVE MODEL JVM-1653-SHO-1 SHUTS DOWN AND TELL YOU TO REPROGRAM THE CLOCK BUT YOU RESET USING ALL INSTRUCTIONS I INSTALL COOK TIME PRESS START IT WILL COME ON FOR 3 SECONDS AND SHUTS...
This is magnetron-related.
See
this FixYa solution (solution #2) even though your model number is different.
Jun 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Microwave and while pushing button the keypad locked and i got the message CONTROLS ARE LOCKED - how do i get out of this? I can't clear it and the buttons don't respond to touch. Kelley
If a hard reset (unplugging power for 2 minutes)does not fix it, then you have a failed membrane keypad.
To give you any further free help, we would need your full model number form the tag in or on the unit.
Please make a new post with that your full model number and symptoms.
Jan 28, 2011 | GE Microwave Ovens
Keypad number buttons not working on ge spacesaver microwave - auto program buttoms work?
Very angry. Fairly new, little-used Spacesaver Microwave [3][Clock][Surface Light] buttons now do not work. We never even press [3], just [1] and [2] to warm sandwiches.
Unplugged for an hour. Still not working. Everything else works. We never use anything else. Bad solder joint in circuit board or keypad?
Thank you.
Aug 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I need to find and order the correct mounting p;ate and bolts for mounting the GE Spacesaver XL1800 microwave.
open door to unit get model number and got o searspartsdirect.com and enter it in to get part number and prices...... or shop locally,, also repair clinic.com also sells parts and shows pictures of most hope this helps let me know
Apr 08, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave GE spacesaver is not working. It
TAKE MICRO APART PHILLIPS HEAD SREWDRIVER LOOK FOR A FUSE DOWN WERE THE PLUG COMES IN OR ON THE RIGHT HAND SIDE.iF THAT DOUSNT SOLVE IT TRY TO TIGHTEN ALL THE SCREWS BE CAREFULL YOU DONT HAVE TO TIGHTEN VERY TIGHT. THANKS FOR ASKING Troy Lawton
Jan 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Heat doesn't come on in microwave
If you have the experience with discharging a capacitor and you have a (VOM) Volt Olm Meter. Unplug microwave, discharge capacitor, and check the resistance of the two thermal cut-off discs by removing the lead and set VOM to RX1. If you don't get a reading of zero, replace the discs. For part go to www.partselect.com and enter your model number. If you found any of these suggestions helpful, please rate my solution. D. Lange
May 01, 2009 | Microwave Ovens
Spacesaver powers off 2 seconds after resetting clock and time...
The clue is that you have to reset the clock. You are losing power somehow. the Main Board thinks it is being unplugged and it resets the clock and you have to start all over. The fact that after so many times it will finally work tells me that whatever bad connection you have is finally getting hot enough to expand and make a good enough connection to keep working. Intermittant connections are the worse to find. A lot of trial and error to find the problem. can be bad fuse and fuse holder ( in the unit), bad outlet, loose wire at circuit breaker, loose wire at outlet. Even a loose breaker where it snaps onto the buss bar in the Breaker Box. Etc, it an really drive you nuts trying to find it. Try the unit in a totally different area making sure it is on a compleately different circuit breaker and see what it does, if the problem follows the unit, the problems is in the unit. If not, electrical problems, outlet, breaker, panel,
Aug 18, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver Microwave Oven JVM1640BB
unplug the unit and if you can open the housing and slowly remove the ribbon cable of the touchpad console to the main board. put it back after 5 minutes and try it. let me know what happen.
Feb 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver doesn't heat
if you are as lucky as i was...i have a ge spacesaver model jvm130...same problem. first unplug unit and check fuse on the "power control module". if fuse is ok...unscrew the screws holding the "power control module" in place...carefully tilt module and see if a solder joint needs to be re-soldered. my problem was the solder joint under the front plug (5 large wire plug). you may have to unplug the three connectors to the board to get access to bottom. this is the second time i had to re-solder...last one was several years ago though. best of luck tennisrme
Aug 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker Over-the-Range Microwave Logo
32 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
