Question about Logitech Z-5300 Computer Speakers
Z-5300 Do I need the remote this or can it be use as a sub for home stereo
I've got a nuance home stereo self amplified sub
A electronic perts supply store, Like radio shack or the scorce.
Nov 11, 2012 | Car Audio & Video
I have a Box With 2 audiobahn 1200 Q 700 Watt Subwoofers and I hooked them up to my home stereo and noting at all comes out of them.... Is there any way i can fix them or get them fixed they are very...
Your home stereo is a 120V system, while your subs are designed for 12V use. Your home stereo doesn't have the amps to push your subs. They need alot of amps at 120V. Your best bet is to is an AC to DC converter, but to get one that is powerful enough to run your system would be more expensive than just buying a decent set of home subs. Also, your box design for home audio is different that car audio. Home enclosures usually use a bandpass box, while car enclosures rarely use this method.
May 04, 2011 | Car Audio & Video
Can I plug just one subwoofer into my Yamaha EMX88S? What kind of sub do I need to get for it? Do I need to have 2 subs plugged in for it to sound right? Do I daisy chain the subs with the A15 speakers I...
it is not reccomended to daisy chain passive subs with main speakers, because there is no crossover unit involved. you want a sub to have a crossover frequency around 100hz, so that only frequencies lower than this go through the subs, and not in the main speakers.
you could get away with 1 sub plugged into the mono output on the front, subs dont have to be stereo. you would need a self popwered sub, or an additional amplifier+crossover for passive subs. your best bet would to be to get a powered sub and hook it up to the front panel mono out. powered subs usually already have the crossover built--in.
Nov 25, 2010 | Yamaha Emx88s Powered PA Mixer System
I installed the amp and the light is on but no sound from speakers. i've checked everything i can think of. any other ideas?
There are several things that you can check for this issue:
Check that the remote turn on wire is connected.
Check that the RCAs from the stereo are connected at both the amp and the sub output of the stereo.
Check the stereo; some head units have settings for the sub output. You made need to set the sub output to "on" at the stereo.
If your subs/speakers are in a box, check the connections there.
Nov 16, 2010 | Alpine MRP-F250 Car Audio Amplifier
I have a Art *** ht-813 5.1 home theater system
check sound card output and settings , may only output 5.1 in optic ir coax connections . and amp will only decode 5.1 when connected to fibre optic sorce same for coax imput.stereo phone connetions can only decode up to 3.1 ,so if you are not getting a puesdo rear and centre then your sound card setting will need changing.
Oct 04, 2009 | Audio Players & Recorders
Sub continuously thumps when stereo is on
The remote on might be suppling intermitten power. Try jumping the remote on from the power wire
or...
If you've abused it, It may be going straight DC output (if that's the case you need to repair or replace the amp)
Apr 29, 2009 | Car Audio & Video
Sub cuts out
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, the sub may be damaged. You'll need to measure the resistanace of the voice coil. It shouldn't read less than ~85% of the rated impedance.
Oct 26, 2008 | Cadence Z8000 Car Audio Amplifier
Subwoofer noise
You didn't say is your sub active or passive.If its active first check signal cables from theater system,power line of the sub, it has to be the same phase as the system.If its passive take a voltmeter disconnect the sub from the system and measure for DC voltage on the SUB output on the system when its OFF.If DC voltage is present your amp is damaged.It can also be that the preamp circuit for the sub doesn't mute the input when unit is on stand by and you hear frequency of your power supply (50-60Hz) on the sub
Mar 09, 2008 | Audio Players & Recorders
Jvc home stereo subwoofer
just chek the cables.. f it not work open the sub box , and check the sub speaker., , , , maybe the wire is burnd
Mar 01, 2008 | Audio Players & Recorders
Protection light stays on no output
i have the same amp and have that same issue before. yes you are correct that if you take off the RCA cables on the input there will be no light. either you have plug the remote line on the 12v or a grounded sub. it should be 12v/remote/ground from the corner. good thing im just fixing my sub earlier. it is no problem if you have hooked the remote line on the 12v, it is the same supposed to be. to check if your amp is working, short the 12v/ and the remote line and play your stereo and see if your sub is working. by the way, what sub are you using? i just blew my sub and need a new one.
Feb 02, 2008 | Pyle 1800-Watt 2-Channel Bridgeable MOSFET...
Logitech Z-5300 Computer Speakers Logo
52 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
