Question about Whirlpool Dryers
Dryer is not heating is kenmore
Dryer is working except for heat has none
  • 700 Answers
Check for a plugged up vent line that goes behind the unit . is it electric or gas,?
Posted on Jan 11, 2009
All mechanical function work well except dryer will not heat up ,blowing cold air.Model DCLR333ETOWW GE
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 01, 2011 | Kenmore 62822 Electric Dryer
I have kenmore he2 dryer. it works fine except stopped heating. how long should heating element last? what else should i check?
heatman101][
\[0-
Mar 31, 2011 | Kenmore 62602 Electric Dryer
My Kenmore Elite dryer works except there is no heat to dry.I am looking for suggestions to repair. Thanks
There is a moister sensor in your dryer that detects any lint build up inside the exhaust vents. If any obstruction is inside the exhaust tubes this sensor will put the heat in the check mode. Inspect and clean thoroughly and see if it will heat up again
Aug 03, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore 500 series dryer blows cool air only
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 10, 2010 | Zanussi TC180W Electric Portable Dryer
Dryer will not heat
Have a certified electrician check your outlet. The dryer requires 220VAC for the heating elements to work. If this is ok, check the heating elements it may be broken.If this is ok, check the high and low limit switches, this could be defective.
Apr 04, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
I am currently having a problem with my Kenmore Dryer. It is running but it is not heating up to dry the clothes. Someone told me to take the back off and check the heating element but I can't find the...
I would check your vent if I were you disconnect the vent and run the dryer to see if it works better. also clear the vent line. good luck
Jan 10, 2009 | Dryers
Kenmore dryer won't heat on low temp
Hi , the high temperature causes the heat sensor does not work properly , in delicate setting are having heat , the heat sensor are busted or open elements was not heating .
Jan 25, 2008 | Dryers
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
