Question about Sony Video Cameras
I have a sony handycam CCD-FX300E that only plays tapes in black & white. the recordings were originally in colour, so why won't the camera play them back in colour?
This camcorder was purchased in approx 1994 and was used for recording until 2003. I have used a Hi8 head cleaning tape on the camcorder, but this did not help in anyway. I still have all the original anolgue connections to connect it to the TV and these all appear to be ok.
SOURCE: Hi8 playback problem
your guides have come loose , probably - the digital sound will be next to go because the bottom edge of your tapes are being folded - open the cassette tape lid by pressing the small pin near one hinge and gently lifting the door - if there are any creases ? get the guides aligned ! to protect your library ; ( if there are no creases , try a sony d8 cleaning tape - once ! before getting a repair quote ) ;
Posted on Jul 29, 2007
  • 36 Answers
SOURCE: Black and white playback with sony handycam dcr-hc20
There is no problem on your camera, DCR-HC19E is PAL system(European system) DCR-HC20 is NTSC(American system). Are you in US or Europe? I think your TV is NTSC, cause the tape recorded on DCR-HC19E you played has no color. To confirm, connect your HC20 to TV in camera mode, not recording yet, just look at the TV as your monitor, If its in color, no problem, just erase the old video recorded on the HC19E, but if its important to you, you can convert it to NTSC using a PC. thanks
Posted on Sep 13, 2007
SOURCE: very grainy playback
Same problem with my Sony CCD-TR416 recently. Know what finally worked? With camera playing a tape, I picked up the camera and tapped it sharply on a solid desktop. Had to do it 3 times. I held the camera with two hands, one on each side of the camera, raised it about 3 to 5 inches off the desktop and then quickly tapped it on the desk holding the camera parallel to the desktop so that it solidly hit with all of the lower surface of the camera body.
I know it sounds crazy. I swear it worked. I had tried cleaning the heads over and over. I examined them with a 20x loupe and they looked fine. I doubt that the problem was oxide and debris build-up on the heads.
I planned to order a new head/drum just to see if I could manage the replacement procedure by myself (I'm a chronic do-it-yourselfer/experimenter). I guess I don't need to do that now.
Why did the slam technique work? My guess: Inside the rotating head, there must be some sort of electronic track like the brushes of a motor or something similar.. Some sort of debris must have been involved in a corruption of the transfer of impulses from the heads. A few taps and it broke free.
If banging it on the desk didn't work, I was next planning to remove the drum to check for bad connections. I'm sorry I didn't have to do that.
Nevertheless, don't listen to everyone when they say that the "heads must be dirty." Nope. With the loupe, I could see mine were sparkling clean. But, I still had those multiple horizontal rows of short white streaks obliterating the video image. Tap. Tap. Tap. Now they're gone.
Try it. Couldn't hurt. Though chances are, you won't see this. I'm posting 6 months after your original post. I just happened upon your post as I researched the problem through Google. Neverthelss, someone might see my response someday and maybe they, too, will get luck with the tap, tap, tap procedure.
Posted on Jan 15, 2008
welcomejee
  • 10594 Answers
SOURCE: Rolling picture on TV while playing back Hi8 tape on TRV460
Hello richiehere,
Check and correct Color System of your TV set. I think you have Multi-Color System TV set and Its not match with your camera system.
Posted on May 27, 2008
SOURCE: Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Posted on Jun 21, 2008
Sony CCD FX500E ejects tapes
Mechanical fault. Contact any service technician; or the authorized service centre for Sony. Electro help
Nov 29, 2014 | Sony Video Cameras
I have sound and can view previously recorded videos on my camcorder. However, on Christmas morning my camera doesn't record or view images. It just records a black screen with white lines. The li
The recording head is probably the source of the problem and will need to be replaced, other than putting a dry cleaning tape or better still a new blank tape, allow it to play right through, it may work.
Mar 10, 2012 | Sony Handycam DCR-DVD105 DVD Camcorder
How do u delete stuff on tapes from a sony handycam vision
I don't know if there's a function to delete video from a used 8mm, but you can do it the old way
1. Option: the first way occurs accidentally many times because you take video on top of what's already recorded... meaning record on top of the old tape
2. Option: leave the lens on the cam, and press record... it will record a blacked-out screen on the tape with nothing on it.
hope this helps
Aug 08, 2011 | Sony Handycam CCD-TRV37 Camcorder
Sony CCD V800 change colour to black and white The hi8 lose the colour to black and white when playing
Ether the unit is very dirty and needs to be cleaned as far as the heads go or you got a bad head inside. This will be determined by a camera shop most likely its just dirty and needs its heads cleaned. A HI 8 still is a magnetic tape and thus dirty or dust can get in the recoder head and thus obscure the color or recording. I would be on the safe side here and have a camera shop take a look is you best bet.
Thanks and please do be considerate and leave feedback and ratings for your free answer today.
May 29, 2010 | Sony Handycam CCD-TRV318 Camcorder
Playback is black and white
if this is b/w on the tv then you have a settings problem.
you need to check you connected the camcorder to the tb correctly, it should be yellow for video and red and white for audio, and you could try looking at the tv menus
if its the camcorder then check the cc monitor. and all the settings. Get anew dv tape and record something , check its colour then play it through the tv.
Sep 17, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Sony Handycam CCD-TRV21 won't play tapes.
no that u must remove ur camera and try to clean all strip that connect with board and mechanisum and all connectors legs solder then it will work .any doubt call u.a.e no 00971503853766
Jul 04, 2009 | Sony Handycam CCD-TRV21 Camcorder
Dont know how to play a tape from camcorder onto my tv
just insert the tape in camera and connect yellow to yellow port in camera and audio is white and red on the other side follow the color code on tv back panel or front if u have and put ur tv into AV mode and then play back ur camera tape using playback mode look out for switch with play icont on it to select the play mode in camera u are set watch it on tv u want anything else i am here to help u
pls rate me FIXYA for help
Apr 14, 2009 | Sony Handycam CCD-TRV57 Camcorder
Sep 12, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Will not playback or record
I have a Sony handy cam ccd-trv108 Hi-8 and I can not get it to play or record, everytime I insert the tape and hit play the display screen flashes c:31.22 Please help me?
Aug 10, 2006 | Sony Handycam CCD-TRV108 Camcorder
Video Cameras Logo
353 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
