Question about Nuova Simonelli Oscar Coffee Maker, Espresso Machine
OSCAR NUOVA SIMONELLI WONT" GO ABOVE 165F AT GROUPHEAD
Hi, THe boiler element has been replaced by service as well as the p'stat with a commercial one. Machine is 1.5yrs old. Everything works fine except grouphead temperatures are extremely low.(165Fmax) after 2.5hrs of being on. I double checked with a new digital thermometer and a manual one. the temps were identical. The steam is incredible and the pump works great. Please advise. cheers
  • nudgeb Apr 15, 2008
    I have exactly the same situation. Oscar is only 7 months old and used very little , but grouphead water temperature tops around 160f. Steam is phenomenal however. This i think is the cause of the ulta fast extraction....and almost immediate blonding. 2 oz in around 10 seconds
    President:
  • 1,618 Answers
Descale boiler and group then make sure steam gauge reads 1.2 bar. If not adjust p.stat.
Posted on Nov 18, 2009
My nuova Simonelli oscar doesn't heat
This is a good little machine. its basically a commercial machine shrunk down for home and is worth repairing even if you have to take it in. go to nuova simonelli usa website and download the parts manual and check the 009500014 thermal fuse and the 09500004 highlimit thermostat and see if one is gone or tripped. check the pressure stat, check if power to elements and if there is check to make sure the elements havnt failed from being heated with no water. like i said this machine is on par with a rancilio silvia so well worth repairing.
NUOVA SIMONELLI ESPRESSO MACHINES
Apr 08, 2014 | Nuova Simonelli Coffee Makers & Espresso...
Machine won't heat
thermal overload maybe open, reset if resetable, change if fixed type
Jan 18, 2013 | Nuova Simonelli Oscar Coffee Maker,...
Nuova Simonelli Oscar No Steam After Descale
when you descale your machine, how did you drain the water? I think the scale particles clogged your steam pipe. And also if you had put a lot of descaling chemicals, this chemicals can eat up the heating element. If you can remove the heater and check it physically and also cleaning and removing the scale inside the tank will help.
Jul 15, 2012 | Nuova Simonelli Oscar Coffee Maker,...
Water will not come out of the brewing head but will flow from the over flow valve.
I can think of 3 issues, the screen is clogged or the solenoid has a blockage at the pathway leading to the grouphead.
Nov 26, 2010 | Nuova Simonelli Oscar Coffee Maker,...
Nuova simonelli vip over pressure problem
Could be lack of water in the boiler, could be a faulty pressure stat or vent valve. Check the level probe first, then the vent valve and then the pressure stat. You can also use the manual fill to make sure water is getting to the boiler.
Jun 27, 2010 | Nuova Simonelli Microbar Espresso Machine
Heating light kicks off and on during brewing and does nit get hot enough
Sounds like there are a few things, happening.
The thermostat could not be operating properly.
The boiler and exchanger need to be descaled.
There is a short in one of the element wires.
The heating light is damaged.
Feb 27, 2010 | Nuova Simonelli Oscar Coffee Maker,...
Mac cup V commercial Nuova Simonelli will not **** water and will not build pressure
First check the reset thermostat on the right side of the boiler below the level probe, make sure there is water in the boiler before resetting.
Sep 25, 2009 | Nuova Simonelli Oscar Coffee Maker,...
Heater problem with espresso machine
Make sure there is water in the boiler, unlug machine remove the top panel and on the side of the boiler is a reset thermostat.
Jun 03, 2009 | Nuova Simonelli Oscar Coffee Maker,...
Pump keeps running and excess water goes into the cup tray
check the level probe on side of boiler may not be facing down as it should or need to be replaced.
Nov 16, 2008 | Nuova Simonelli Oscar Coffee Maker,...
Open Questions:
Nuova Simonelli Oscar Coffee Maker, Espresso Machine Logo
250 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Eric Ramos
Eric Ramos
Tom Chichester
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
