Question about Nesco Crock Pots & Slow Cookers
Nesco pressure cooker e3 error
Trying to slow cook baked potatoes. After warming up I get an E3 in the digital display. Can't find that in the manual.
SOURCE: Rival 38601 Smart Pot 6-Quart Slow Cooker can't get to to go to warm
While holding down the "cook time" button, press the "off" button, release the "cook time" button, the control will go to the "warm" setting.
Posted on Dec 24, 2007
SOURCE: user manual for breville mm8 slow cooker
My mum has given me a Breville meal maker slow cooker but she could not find the user manual. I am looking for this manual if you can help.
Posted on Dec 09, 2008
  • 86 Answers
SOURCE: need cooking manual for hamilton bch 6qt prog slow cooker-
Please click the below link with leads to the download page for this manufacturer. You will need to select your exact model via the dropdown and then click "submit"
Posted on Mar 27, 2009
  • 97 Answers
SOURCE: slow cooker will only stay on warm. How do I put
This slow cooker has 3 settings LOW, HIGH, & WARM
When you plug the slow cooker in the display should show a "0". When you press the "COOK TIME" button, the display should go to 1 then 2 then 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the "HIGH" setting. If 7,8,9, or 10 hours are selected, then the slow cooker will operate on the "LOW" setting. To start the cooking cycle press the "ON/OFF" button. To interrupt the cooking cycle at any time, press the "ON/OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the "WARM" setting. If the "ON/OFF" button is pressed when the the digital display shows "0", then the slow cooker will automatically start on the "WARM" setting.
If the "COOK TIME" button does not change the display numbers then unplug the slow cooker and hold both buttons down as you plug the slow cooker in. Keep the buttons pressed for a count of ten, then release them and the slow cooker should work correctly
Posted on Mar 06, 2010
SOURCE: Owners Manual Franklin Chef Slow Cooker
I broke the power control button on my cooker. Can I buy a replacement button and if so where.
Posted on Feb 16, 2011
Paula deen pressure cooker. Can I use it for slow cooking? What is temp of keep warm? Could put lid on loose. Also, timing notches are mixed into keep warm button. I overcooked my first batch
A pressure cooker is NOT anything close to a slow cooker. The cooking philosophy are practically totally opposites. A pressure cooker basically cooks your food in a fraction of time because it is under pressure. A slow cooker takes hours.
The whole idea of using a pressure cooker is that it is sealed and applies pressure to cook the food faster. The lid needs to be sealed for the pressure cooker to operate properly. It is frequently referred to as "infusion" cooking now days.
You need to read the instruction book that came with the pressure cooker. Pressure cookers usually cook for less than an hour--my homemade pressure cooker spaghetti sauce is cooked in less than 30 minutes. They are nice and were very popular long before anyone thought of microwaves and slow cookers. However, there are some precautions to be taken. There must be water or liquid in a pressure cooker. The rubber seal needs to be cleaned frequently and, when the rubber seal warps/stretches and no longer seals, it needs to be replaced. There are also certain foods that CANNOT be cooked in a pressure cooker like rice, dry beans, etc. The pressure control valve operates to regulate the amount of pressure and releases extra pressure otherwise the unit would blow up (very dangerous!). Most pressure cookers (required on all new ones) have a small rubber emergency stopper that will "blow off" in case the pressure is too high. I've seen this happen and my mother cleaning potatoes & meat from the ceiling!
Mar 03, 2017 | Crock Pots & Slow Cookers
What is code e3
No one, including the manufacturer seems to be able to answer for that error code. Sorry.
Mar 02, 2016 | Crock Pots & Slow Cookers
What does e3 mean on the power pressure cooker
as there is no make/model listed we can not even search for the error code .SORRY
Aug 20, 2015 | Crock Pots & Slow Cookers
Slow cooker will not cook potatos and carrets in 8 hr. on high
You should call the manufacturer for a replacement if the slow cooker is new. It should never take that long on high!
Feb 02, 2013 | Crock Pots & Slow Cookers
I pushed the cook time button but it still says zero what do I do
Hit the on/off button, so that the cooker looks like it is off, then hit the cook time button up the the number of hours you need to cook. This slow cooker has three settings: LOW, HIGH and WARM..... When your corningware slow cooker is initially plugged into a wall outlet, the display will show "0". This display indicates the programmed number of hours for which ameal will cook. The slow cooker can be programed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears. If 1,2,3,4,5, or 6 hours are selected, then the slow cooker will operate on the high setting. If 7,8,9, or 10 hours are selected then the slow cooker will operate on the low setting. To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the warm setting.
May 11, 2010
Nov 19, 2012 | CorningWare SC60 Slow Cooker
Presssure valve to be turned off or on when using pressure cooker
pressure cooker cooks by the pressure inside the cooker.
So you need to put those on when cooking.
The excess pressure will automatically drain off.
Jun 12, 2012 | Nesco Electric Pressure Cooker
My bravettii slow cooker would not cook baked beans they cooked for 18 hrs total 6 hrs was on high and 12 hrs was on low and the beans are still not fully cooked it never came to a boil is there...
I can't solve your problem but I can sure relate. I am having the same problem with my Bravetti Pro (it's far from Pro - it should be called Bravetti Amateur) I tried cooking a small ham with cut up potatoes recently, and after 11 hours cooking at the medium setting, the potatoes were not cooked. I got this thing as a gift about a year ago, and although I've only used it a few times, it never seems to cook properly. Mine was purchased at Canadian Tire and although I don't have a receipt, I think I'll try to take it back. Good luck with yours!
Tom
Feb 08, 2011 | Bravetti PC107HA Slow Cooker
Slow cooker will only stay on warm. How do I put
Feb 11, 2010 | CorningWare SC60 Slow Cooker
How do I start the cooker on low?
The manual says "When your corningware slow cooker is initially plugged into a wall outlet, the display will show"0". This display indicates the programmed number of hours for which a meal will cook.
The slow cooker can be programmed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears.
If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on HIGH setting. If 7,8,9 or 10 hours are selected, then the slow cooker will operate on the low setting.
To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
When the full cooking cycle is complete, your corningware slow cooker will automatically switch to the warm setting, to keep food at a warm serving temperature."
If, after you plug the slow cooker into the outlet, the COOK TIME button does not work, unplug the cooker, hold both ON/OFF and COOK TIME buttons down, plug into wall socket and wait till the display flashes. Release both buttons and the slow cooker buttons should both work.
Dec 18, 2009 | CorningWare SC60 Slow Cooker
Need a manual for the corningware sc60
The manual basically says... This slow cooker has 3 settings LOW, HIGH, and WARM. W hen you plug the slow cooker in the display shows "0". When you press the "COOK TIME" button, the display should go from 0 to 1 to 2 to 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the HIGH setting. If 7,8,9,or 10 hours are selected, the slow cooker will operate on the LOW setting. To start the cooking cycle, press the "ON/OFF" button. To interrupt the cooking cycle at any tim, press the "ON?OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the WARM setting. If the "ON/OFF" button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
If the "COOK TIME" button does not change the display numbers, unplug the slow cooker. Hold down both buttons and plug the slow cooker in and keep them pressed down for a count of 10. Release the buttons and the slow cooker should work now.
Nov 28, 2009 | CorningWare SC60 Slow Cooker
Crock Pots & Slow Cookers Logo
Top Nesco Crock Pots & Slow Cookers Experts
ZenFire
charles
Sock Puppet
Are you a Nesco Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
