Question about Freezers
What year is this kenmore chest freezer model # 253.8193681 Serial # s009204876
I want to know how old this kenmore Chest Freezer is?
dididsaythat
  • 291 Answers
SOURCE: chest freezer
Need to find out IF the compressor is running or not.. thats the frist thing to do.
Posted on Sep 20, 2007
bobotfel
  • 236 Answers
SOURCE: kenmore chest freezer power problem
Try to unplug the the unit power supply to reset the error. But if the error persist you have to call for a qualified technician,
Posted on Dec 28, 2007
hotuna
  • 288 Answers
SOURCE: Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Posted on Feb 19, 2008
dauphine
  • 207 Answers
SOURCE: Kenmore Chest Freezer
It might be freezing normally but that doesn't mean that compressor's motor isn't overheating due to lack of freon or mechanical problems on motor itself. Better not risk a fire and let someone experienced check the compressor's motor. Overheating is never a good sign.
Posted on Apr 20, 2008
brainyass
  • 242 Answers
SOURCE: Frost in Chest freezer
Not much you can do except ensure you have a tight seal and not to open it more than you have to.
Posted on Oct 24, 2008
How do i find out how old a freezer is?
Search online to find the manufacturer's website. Call or email them. Be sure to have the model number and serial number. They should be able to help you.
Jan 07, 2015 | Kenmore 24.9 cu. ft. / 705 liter Chest...
Kenmore model 19502 chest freezer green light blinking
My Kenmore chest freezer just went dead today. It ruined my Ribeye steaks, my shrimps and other meats. I will not buy a Kenmore again.
Jan 12, 2013 | Kenmore 5.1 cu. ft. Chest Freezer - White
Lid on chest freezer will not securely close Model #FCM 7DAA WH Serial #RTI63278 Mfg 81998
Remove lid, squeeze hinge back into shape and refit, adjusting screws in rear of hinge bracket as you do.
May 19, 2012 | GE Freezers
Kenmore chest freezer wont cool
Hi.
Here is a tip that will help you...
There are also more tips at the bottom of this one...
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
heatman101
Feb 26, 2010 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Kenmore chest freezer does not stay below 30 degrees compressor runs but I don't see a fan to cool the compressor
If your chest freezer is less than 50 years old, it does not have a fan. Cooling coils contact inner walls of freezer compartment, warm coils dissipate heat through outside walls of freezer. If compressor runs, temp is 30+ degrees, gasket is OK, lid not left open, then you have one of two contions: 1. Low capacity compressor 2. Refrigerant leak. Solution to either is to replace freezer. (My opinion: Don't get a Kenmore brand, which generally ties you into poor warranty and slow and poor service.) No matter what brand name is on the freezer, it is most likely manufactured by Electrolux (in St. Cloud, MN) or Haier (from China). Look at the model / serial number plate before purchase to see where it was manufactured. Yes, the USA manufactured ones are better. (and I'm not just saying that because the plant is less than 15 miles from where I am sitting right now)
Jan 01, 2010 | Freezers
My chest freezer shut off (the outside light was
Try to plug somthing that you know it works ,in that outlet ,and if it doesn't work or goes on and off , the problem is in the outlet, but if works without trouble ,the problem could be in the freezer plug , the cord or the cord conections to the freezer.
Sep 13, 2009 | Kenmore Freezer 8.8 cu. ft. Chest Freezer...
I have a Kenmore chest type frost free freezer
I am not aware of a chest freezer that is auto defrost.Go ahead and defrost it like you would any chest freezer. Eric
Aug 10, 2009 | Freezers
Need -20 degrees Celsius...Will this brand get there?
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
May 29, 2009 | Kenmore 24.9 cu. ft. / 705 liter Chest...
Kenmore chest freezer about three or four years old.not cooling
Probably a freon lean and not worth repairing. You can never find the leak in a chest freezer. Recharging will buy a little time but you can never reallly trust it again.
Apr 28, 2008 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Freezers Logo
51 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
