Question about Refrigerators
2001 kenmore refrigator 10672864100 makes clucking sound ,tap the refriegator on the side and it will stop clucking then it will clunk again if you hit the side with your hand ,it good temp in refrige
Makes clunking noise tap the side and it quits clucking,or it may come back and hit the side again ,other the that it works good.
SOURCE: Kenmore Coldspot Side by Side Model 51559101
I also have the same refrigerator model 106.56566400 and periodically when the power goes off in the house the refrigerator & freezer will stop cooling. Try pushing the on/off button located inside the refrigerator to the left of the digital temperature controls. Hold the button down, this turns the unit off, then press it again to turn it back on. This basically resets the refrigerator, and most of the time works to get the refrigerator cooling again. Try this first before calling a repair man.
Posted on May 14, 2008
  • 66 Answers
SOURCE: Kenmore fridge, about 8 years old, making noise
The compressor on your fridge is mounted on rubber grametts and inside the dome the internal parts the do the pumping of the refrigerant are mounted on springs. When a compressor gets old some people complain about two much vibrating, this could be the rubber grommets the support the compressor. When one of the support springs inside the compressor is broken it will have a distinct rapping sound when the compressor shuts off. There isn`t anything you can do about this, short of replacing the compressor. It will eventually get worse untill something is seriously broken inside the compressor and the compressor will die. You may want to consider replacing the compressor now or purchase a new fridge. You will need to consider the cost of both and the age of the fridge" Is it worth repairing?". You can actualy find a repair company in your area from this site if you like, and compare the costs.I hope I have helped explained the problem well enough for you. I will help you as much as I can.
Posted on Nov 16, 2008
rpbuice
  • 161 Answers
Unplug the Ref for 15-20 min., plug it back in and listen for the compressor to start. You will need to be behind the Ref so you can tell if the compressor or the fan is running. It will help to take the cover off so you can see the compressor.
Compressor not running but you hear a clicking noise. The relay needs to be replaced.
Compressor runs but not cooling. Low on coolant
Posted on Feb 11, 2009
MNTECH
  • 1543 Answers
SOURCE: freezer cold /refrigator warm
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Posted on Jul 04, 2009
SOURCE: Whirlpool top freezer refrigerator- compressor makes a loud noise
The compressor is that black casing you see at the bottom of your refrigerator - inside this sealed case is the motor assembly which stits on 3 or 4 springs that act like a cushion - you have a little gap at the bottom where the lubricating oil is present. Your springs have likely worn out and when the compressor shuts off the assembly is banging against the rigid casing make that loud "klonk" or bang noise. It IS normal for compressor to make some faint "tick-tick-tick...tick.....tick" when shutting off, but loud banging, bell sounds, etc, means the assembly is banging on the case from the inside - you can indeed live with the noise, your compressor will function normally, probably for months, or even years - it can also keep wearing out and one day the noise might get very loud (like a very high humming noise) - There is NOTHING that can be fixed, you either pay $400+ to change the compressor or buy a new refrigerator - If you DO replace a compressor usually the replacement will be noisier - Keep a thermostat inside your refrigerator at all time to make sure your compressor is still keeping your refrigerator and freezer cool.
Posted on Aug 16, 2009
Kenmore side by side 253.52349302 making stalling noise
motors start capacitor relay may be going bad..
Jan 20, 2014 | Kenmore Refrigerators
Compressor on refrig/freezer not working, fan next to compressor stopped working also.
Sounds like you need to replace the thermostat which is located behind the refrig control knob . Tap on the knob and if the refrig starts , replace the control behind the knob .
Oct 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Clucking in the front end already replaced bushings and swar arm
Depending on the mileage - probably lower ball joints need replaced
mine came with no grease zerks - installed after ball joints replaced.
had clunking sound also - went away after new replacements.
Oct 04, 2010 | 2001 Dodge Caravan
What is the clunking noise made after the refrigerator stops running? Its a Kenmore and is 10 yrs old. We have thoroughly cleaned behind and beneath the refrigerator and now the noise seems louder.
The clunking noise you hear , is probably when the compressor shuts off , due to temp reached or when it goes into defrost . An internal motor mount spring , inside the compressor , is broken ( rusted and broke ) . The refrig can go on working for years , without any problem , except noisey , when it cuts off . To stop the noise , replaceing the compressor is the only option . I have heard of placeing objects under 1 leg of the compressor , to " re-adjust " the ballance , but thru my experience , another spring broke , causing more knocking .
Mar 24, 2010 | Kenmore 64802 Top Freezer Refrigerator
Frig shutters and makes noise when the cooling cycle shutoff.
It is probably caused from one or more of the four rubber bushings that mount your compressor to the refrigerator frame. The bushings wear over time and causing the compressor bracket to have a little play. Then when the compressor stops it moves the frame slightly bumping against the mounting bolt causing a slight to moderate sounding clunk when stopping, Also check a lines and cords as a cord refrigeration line near the compressor or fram can also cause the problem.
Oct 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Stopped making Ice cubes on S/S kenmore refrig. water nnot flowing in tube that runs up the back
This problem is the dual water control valve coil for that side. If you fill the ice maker with tap water and it cycles then the problem is most likely the dual water control valve on the rear and near the floor. Also make sure that the fill tube inside back of ice maker is not frozen over. Let me know the model number and I can tell you the part number for the replacement, Kenmore model numbers look like this for example 213.256489 Thanks, Sea Breeze
Aug 15, 2009 | Kenmore Refrigerators
Refrig shut off and will not restart - light bulbs still working
this refrigerator sounds like a 'frost free' type, and as such can, usually, only be repaired by the manufacturer. local refrigeration engineers cannot get the parts. your fault sounds like a PCB (printed circuit board) has gone, which only the manufacturers have in stock.
Jan 25, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser makes cluking sound
I set fire to my house and claimed the fridge on insurance.
however I was uninsured and now require financial assistance.
please send
1. $2950 so i can buy a new fridge
2. $0.05 if you are concerned about my mental health
3. an insult if i am wasting your time.
rgds..John
Jan 07, 2009 | Whirlpool ED2FHEXN Side by Side...
Nov 22, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore 106.7687461 about once a week refrig stop, light still on?
Try to locate the defrost timer. It sounds like the defrost timer has an intermittent fault and is not operating as it should. It should be situated in the compressor compartment. It is a white or black box with a little knob protruding from it. When the motor stops again, try turning the little knob on the timer untill you hear a loud click. The motor should then start running again. If it does, the timer is faulty. Replace it.
Oct 30, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
