Question about Napoleon 36" Zero Clearance Top/Rear Vent Natural Gas Fireplace with Black Door
Burner in fireplace only lights only halfway
This is not the exact model but I have had a local expert come in and replace the burner and cleaned the fireplace but after $600 I am still having half the burner not working and a smell of propane in the house.
2 Suggested Answers
SOURCE: black soot on glass and black smoke comes out
Remove the burner and clean all holes ,typically at the end of the burner is a cheep sheet metal valve.This valve adjusts the air to gas mixture by rotating it to increase or decrease the combustible air intake.Air must be sucked into the burner as natural gas is injected into it, this makes for a clean flame,The flame should be blue with small yellow tips.If the flame is long and yellow and sooty increase the air intake on the burner valve.
Posted on Feb 15, 2009
Majestic DVR 36 RN gas fireplace pilot flickers when ignited, eventually gets to full pilot. Ocasionaly burner shuts off, pilot remains on. Also, need owners manual for part numbers. Help.
Does your fireplace have a thermostat connected? If so, that may be why the pilot stays on and the burner goes off. Otherwise, it could be a bad thermopile. If that is the case, I recommend you just replace the entire pilot assembly. It is an older model and manuals can be hard ti find. If you still have trouble, I recommend you contact a local certified gas appliance technician.
Jan 12, 2014 | Majestic Fireplaces Majestic Topaz 20ILDV...
Hearthmaster fireplace shuts itself off
So the main burner does fully ignite, but after a minute everything shuts off including the pilot? May just need the pilot cleaned
Sep 12, 2017 | Heating & Cooling
Fireplace burner won't stay on
try cleaning the pilot sounds like its a short pilot and when the burner comes on it pulls the gas from the pilot light .
Feb 22, 2013 | Heating & Cooling
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
Napolean fireplace burner wont light
If your pilot is running fine, but your burner will not light:
  • You may have a bad thermopile.
  • There may be blockage in the burner orifice.
You can test the voltage of the thermopile per your owner's manual (replace if necessary).
You can clean out the burner orifice with some compressed air.
Nov 15, 2012 | Pool & Spa
Will not light
Have you removed the burners covers and top to see if the PILOT LIGHTS may have blown out? Hold a stick match or fireplace match (long stick) down in the area of the circular burner after turning on some gas. The burner should light and the pilot light should stay on as well. You local gas company provides service for this type of problem. Call them and have a gas company representative make a home call (free service) in most areas.
Oct 08, 2010 | Kenmore 36 in. 33212 / 33214 / 33219 Gas...
I have a ProCom Ventless Fireplace. LP Sometime
that shouldnt matter u probably have a runner tube where the gas runs from burner to burner sometimes they get clogged or spiders can build webs in them ur best bet is to turn the gas off take apart and clean tat should solve ur problem
Feb 26, 2010 | Procom ML300TBA Heater
Gas logs while turned on seem to fade, nearly go
you must keep the burner and the pilot light area clean and free of dust also,the area where your burner gets air most of the time it has an adjustment to give it more or less air.I have had my dyna glo vent free model for 8 years.A good cleaning in late fall with low pressure air and 1 or 2 times through the winter depending on conditions of use.
gatesmason88
Jan 07, 2010 | Napoleon 36" Zero Clearance Top/Rear Vent...
Black soot on glass and black smoke comes out
Jan 26, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
Kenmore Elite 17680 gas grill needs a new burner. I purchased the burner, but do not know how to install it. Can this be done as "do it yourself" or does it require a serviceman?
I had a local barbeque grill retailer ( a fireplace and barbeque store which did repairs) install a new one for me. I didn't want to mess with the venturi tubes and the exact length of the openings so it would work. I am glad I did as it works perfectly.
Apr 25, 2008 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Napoleon 36" Zero Clearance Top/Rear Vent Natural Gas Fireplace with Black Door Logo
95 people viewed this question
Top Napoleon Pool & Spa Experts
John Rodgers
John Rodgers
Craig Butler
Craig Butler
Paul Carew
Are you a Napoleon Pool and Spa Expert? Answer questions, earn points and help others
