Question about GE DBVH512GFWW Dryer
Natural gas smell
Installed gas dryer that had been sitting for awhile, checked all gas piping to the dryer there are no leaks, only smell the natural gas when I start the dryer.
  • 700 Answers
Then checkout the tubing that goes to the burners and pilot flame tubing too,
Posted on Jan 11, 2009
GAS Odor? Gas dryer smells of gas after it runs a cycle, just replace ignition gas valve assembly, still has gas smell?
Did you also replace the coils on the valve assembly?
Which parts did you replace exactly?
Nov 07, 2012 | Dryers
Our Maytag Neptune gas dryer is exhausting a natural gas odor now... This smell only occurs when it has been running for awhile and never when it's turned off. Also, it ONLY smells outside the house via...
The burner is not lighting right...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
A lingering natural gas smell after a hot water heater fires up in the basement the unit is Sears Power 12 50 gallon model bought in spring 2009
make sure you have the proper piping for out side combustion air. this is a code in some areas?? this will help dispate the gas smell after the water fires up and causes the gas smell... also might check the flue make sure it is properly installed and venting properlymm
Mar 24, 2010 | Water Heaters
We just had new Rheem Natural Gas Furnace
Hello. yes there is a 2 second delay and when the conditions are just right you can smell gas. Although this is not dangerous or a health risk, you could run the exhaust pipe up in the air a few feet to get rid of the smell. Regards, Joe
Feb 25, 2010 | Heating & Cooling
Smelled mild gas odor after moving dryer. Replaced gas line connection. Still smell gas. Tried to tighten gas line have strong gas odor after running dryer. Does not seem to be heating
The gas valve should not be opening unless the glow igniter glows and sends a signal to the gas valve. I suspect a small leak in either the gas pipe or at the gas valve. You will have to get to the gas valve to perform a leak test. While the dryer is open, replace the igniter.
Jan 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I smell gas when the dryer is on. More so when
You got a loose connection on your dryer.  Turn off the gas line going to the dryer. Get you two pipe wrenches and disconnect the gas line going into your dryer.  Go to Home Depot and get the yellow pipe thread tape made for gas lines.  Clean the threads and then wrap the threads a few times around your gas dryer pipe.  Re-secure the gas line and snug up the connection real good and tight but don't go all ape **** and strip the threads.  Turn back on the gas line feeding the dryer.  Go get you some liquid dishwashing soap and put a little in a container with water.  Swish it around a bit to produce some suds.  Then take you a sponge and put it in the container so it will absorb some of soapy dish water.  Then squeeze some of it around the gas connection you just made.  You will know you got a good connection if the bubbles just sit there and drip down.  You got a gas leak if the bubbles start blowing up and around, which means more thread tape or tighten the connection up another quarter turn.
Oct 24, 2009 | Maytag Dryers
GE Dryer has gas smell inside.
i would not play with this problem , the lines and the seals in the dryer must be checked .. by a proffesional ... hope u dont get a spark , get this checked imediatley
Sep 26, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
HOW TO INSTALL THE BELT ONTO A LG DRYER MODEL DLG2532w
Connect Gas Supply Pipe
(Gas Dryer ONLY)
For further assistance, refer to section on Gas
Requirements.
1. Make certain your dryer is equipped for use with the
type of gas in your laundry room. Dryer is equipped at
the factory for Natural Gas with a 3/8” N.P.T. gas
connection.
2. Remove the shipping cap from the gas connection at
the rear of the dryer. Make sure you do not damage the
pipe thread when removing the cap.
3. Connect to gas supply pipe using a new flexible
stainless steel connector.
4. Tighten all connections securely. Turn on gas and
check all pipe connections (internal & external) for
gas leaks with a non-corrosive leak detection fluid.
5. For L.P. (Liquefied Petroleum) gas connection, refer
to section on Gas Requirements.
Oct 15, 2007 | Kenmore 63932 Electric Dryer
Dryer smells of natural gas
Of course, this applies to gas dryers only. If you smell natural gas near your gas dryer, do not light matches or a lighter and don't operate electrical switches or anything that might spark, igniting an explosion. Immediately shut off the gas valve that serves the dryer. If the smell is mild, ventilate the area, wait until the air is clear, and re-light your pilot light. If the smell is strong, move everyone outside, leaving the doors open to ventilate the house. Turn off the gas supply valve --located by the gas meter on the gas inlet pipe-- by rotating the valve one quarter turn with an adjustable wrench. The valve's oblong stem should be perpendicular (at a right angle) to the inlet pipe to stop the flow of gas. Call your gas supplier (or the fire department) from a neighbor's phone or a cellular phone outside the house.
Jan 18, 2006 | AEG T57800 Electric Dryer
Dryers Logo
234 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
