Question about Williams Music
Kurzweil piano turns on but no sound comes out
Hugh fulton
  • 62 Answers
SOURCE: Kurzweil piano keys are clicking seems to be worn out.
I don't see you doing any damage by having a look but I would get a piano tuner or repairer in to investigate the problem expertly - no slight on you. But if your Church congregation depend on it it's well worth the money.
Good Luck
Posted on Sep 13, 2009
  • 5603 Answers
SOURCE: Kurzweil digital piano unpredictable voices and volume
The contacts of various switches and keys are likely dirty. They are often conductive rubber and need cleaning with 99% isoprophly alcohol and q-tip. Clean both the conductive rubber pill and th circuit board traces they contact.
Posted on Sep 17, 2009
  • 5603 Answers
SOURCE: I have a Mark V Kurzweil piano - the electrical
Your are likely talking about the input power connector. They are usually a three blade connector in a well.
If the connection is soldered to a circuit board, it has likely gotten bashed in. The circuit board MAY be cracked, but is likely repairable.
Take it to a local electronics repair shop or find one through a music equipment store that deals with pro audio gear.
USUALLY these connectors have "ears" that attach to the case for strength and if the connector has been pushed in the ears likely have broken off. The parts are USUALLY readily available from several sources including Digikey and Mouser.
Posted on Sep 24, 2009
djlaplaya
  • 74 Answers
SOURCE: my kurzweil micro piano will come on and the
Just make sure you are not sending out a midi volume from your keyboard, this could turn the volume down or off. I am not sure what else could cause this. hope it helps.
Posted on May 06, 2010
  • 5603 Answers
SOURCE: On power up my kurzweil micro piano has no audio
If the unit uses a wall transformer power supply, verify that it is correct and in good shape. If it is DC and half of the rectifier is gone, then result would be what you are observing.
Posted on May 22, 2010
How old is my Packard piano serial number 130213
Your piano was manufactured sometime between 1925 - 1930. As far as I can discern, it cannot be pinned down any more specifically than that, nor can it be determined where it was constructed. Sorry. . .
May 04, 2016 | Kurzweil Music Systems Kurzweil MarkPro...
How do I restart when Kurzweil Mark 12 1999 piano hangs at waking up scanner message?
Hard reset procedure
1. Turn the Kurzweil off
2. Hold down the KEY START, KEY STOP, and LAYER VOLUME buttons for 5 seconds while powering the unit up, then release
3. Select RUN DIAGS
4. Press the UP arrow until the display reads RAM TEST
5. Press the START/STOP button to run the test
6. When the display reads SUCCESS, turn the unit off and back on. The unit is now reset.
If your Kurzweil still does not come up to the normal screen after this procedure, it will require service.
Apr 14, 2016 | Kurzweil Music
Tell me some tips and tricks about using the Kurzweil sp3x stage piano
The place to get the best help for Kurzweil gear is Sweetwater Sound.
Other than that, always use it in stereo mode with a decent sound system. Always use speakers with at least a 15" woofer and a horn to get the full range of sound it's capable of.
May 18, 2014 | Kurzweil Music Systems Kurzweil SP3X...
It doesn't turn on
check if the adaptor is ok, if ok you got to call a technician and check the piano.
Apr 08, 2014 | Kurzweil SP2X Stage Piano
Kurzweil eg 20 piano keys sinking
You may not have the patience level to attack it. Few ppeople do.
Sep 25, 2012 | Kurzweil Music
Kurzweil Sp2x
It may be the line current at those venues.
If you have a lightweight switchmode supply, you can try adding some ferrites to the power cord from the wall. but you almost need to switch to an older style heavy transformer supply for reliablity. It is my guess there is a great deal of noise on the supply current at those vehues you have had problems at. That noise does not play well with switchmode.
Feb 04, 2012 | Kurzweil Music
I cannot get the grand piano sound......help somebody!
You are not clear if you can't select it or it just doesn't sound like a grand piano. If it is the latter here are the things to check:
1. Are your speakers at least 15 inch diameter with suitable tweeter as well? This is if you want the deep lows of the piano. Twelve inch are minimum size to sound anything like a grand. The internal speakers found in the pianos just don't quite make it as they are often only 4 to 6 inch.
2. Is your amplifier capable of enough power?
To get the REAL GOOD grand sound you need a capable audio system. A home stereo system just doesn't cut it to reproduce the sound of a grand piano.
Mar 09, 2011 | Kurzweil SP2XS Keyboard Home
My kurzweil micro piano will come on and the lights are on but theres no sound,even the demo will not play.the unit is plugged in correctly.i have not used it for several years.
Apr 19, 2010 | Music
Sep 17, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Good Luck
Sep 02, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Music Logo
Top Williams Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Williams Music Expert? Answer questions, earn points and help others
