Question about Refrigerators
Why is my LG fridge freezer model number GWB227WLQA beeping?
3 Suggested Answers
  • 27 Answers
SOURCE: Digital display is blank in GE Profile fridge
Hi. Its either a bad motherboard or control board. I would check the control board for any obvious signs of damage to the board first. I've seen the control board go blank on the GE side by side and it turned out to be the motherboard. The motherboard is located behind a cover on the back of your refrigerator cabinet. You should have a new motherboard on hand at all times because they fail alot. Be sure to put a surge protector on your refrigerator. Good Luck, Mack
Posted on Feb 02, 2008
  • 43059 Answers
SOURCE: GWB227WLQA- LG FRIDGE FREEZER Freezer motor stopped working. Please help. Can't seem to find the motor for this model online.
call a regular repairman of freezers and refrigerators
Posted on Aug 10, 2015
Our fridge bleeps every time the door is opened and now the freezer is not working
Hi Ruth,
If you are seeking assistance, may I suggest you provide more information about your fridge, like brand and model number.
If it was a Fisher & Paykel, and it was beeping, count the number of beeps. This will indicate the fault code. Report back with that information
Dec 02, 2016 | Refrigerators
I have a LG fridge freezer that wont stop beeping any help would be greatful model number..GWB227WLQA
Most new style have a warning tone that door is open.
start by manually pushing any door switches ( interior lights should go out). If light stays on you have faulty switch.
Freezer with no light a little harder, but if you have meter and are able to get switch out you can test for continuity.
Not sure of voltage to switch so remove power to fridge while removing switch.
With power removed ( unplugged) you maybe able to remove switch and connect wires together with electrical tape. Plug unit back in see if alarm is off.
Remember if not comfortable with that process call service.
Sep 22, 2016 | LG Refrigerators
GWB227wlqa. Why is the panel on the front beeping?
If you haven't yet... unplug it for 15 mins without opening the doors.. check the plugs on the bottom that run into the door panels unplug and plug them back in again. Making sure they are clean and fully pushed together.
Aug 06, 2015 | LG Refrigerators
My lg fridge keeps beeeping model number gr642apa 8 years ago the beeping is driving me insane but everything else is workin only beeping all the time
http://www.manualslib.com/manual/692499/Lg-Gr-642apa.html
This is the link to the manual for your model. The beeping fault codes are covered starting on page 19 and get into detail by page 22. There are a number of triggering events or causes so you should read about them and try what the manual describes to try and turn the beep off.
Nov 25, 2014 | LG Refrigerators
Kenmore top freezer fridge beeping problem
Sounds like your on the right track. The switch getting warm is a bit of an issue, but that could be normal operation depending on a number of factors.
But, your right, the switch pops out from the front. Be sure and disconnect power before you attempt this as you don't know if the switch is on 120VAC or a low voltage power from the controller.
Dec 16, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
LG Fridge door constantly beeping when closed
On the display panel press the right key that turns the door alarm on and off
Jul 10, 2009 | LG LFC25760ST 25 Cu. Ft. Panorama French...
LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Mar 02, 2009 | LG LFD25860
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
