FixYa.com
Tags:
RCA REB1200
Proxy server?? problems
posted by freezefire on Jun 08, 2007
Having a problem connecting 1 of 2 REB1200's to my content.I use an XP box - service pack 2 - as a proxy server and RebLibrarian v2.27 to upload content to the 1200's.
About a week ago both stopped working with the Librarian program. When connected, they wouldn't see any content on the bookshelf. I have since re-installed the librarian program and got the 1'st 1200 connecting and downloading content again.
The 2nd 1200 will connect to the bookshelf, and correctly displays all content. When I attempt to download any of my own content to the 2nd 1200 though, it gives the same error every time...
"There was no response from the server; trying the operation again may help."
I am able to download the "GNU Wget Manual" that installs with the librarian program to the 2nd 1200, not sure why only this file.
I have double-checked that my content is .IMP format. I have also checked the IP address of the proxy server and the 1200, as well as the port both listen on. Everything is the same as the 1st REB1200.
I assigned a new IP address to the second 1200 and still received the same error.
I copied all content between both bookshelves in attempt to make both connect to one bookshelf or the other.
Any other suggestions I can try to get the second unit downloading my own files from the bookshelf again?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 28, 2008
Not Rated (0)
Ekse
Rank:Guru Guru
Rating: 85%, 1093 votes
I supose this old problem has been solved?
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these PDAs problems?
PDAs
i need a user manuel
i need a user manuel for a rca... Answer This...
PDAs
Bought Technica TT708 (From...
Bought Technica TT708 (From... Answer This...
PDAs
benq scanner 4300
i cant download scanner... Answer This...
PDAs
speaker phone works but hand
speaker phone works but hand... Answer This...
PDAs
i can put videos on
i can put videos on my psp but... Answer This...
Repair Service
Find PDA Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
