Question about HP DeskJet 540 InkJet Printer
I have a HP DeskJet 540. Not printing
When I touch the print buttom, all I receive is a loud clink sound and the two lights start to flash.
I've just fixed a Deskjet 420 with the same problem.
In my case the printer had not been used for several years, when I opened the printer lid I could see that the ink had leaked out of cartridge and solidified around the print head. I was able to manually move the printhead out of the way, VERY gently brake up the solidified ink with the end of a screwdriver, after repeating this process a number of times and installing another ink cartridge I had a working printer salvaged from the junk in my garage!
Posted on Feb 07, 2009
HP Deskjet 5740 Printer
Did you check if there is anything obstructing movement inside the printer?
Mar 24, 2008 | HP DeskJet 3740 InkJet Printer
Tip
How to clean ink cartridges HP deskjet printers
You need the following items to clean the print cartridges:
• Distilled water (tap water can contain contaminants that
can damage the print cartridge)
• Cotton swabs or other soft, lint-free material that will not stick
to the print cartridge
Be careful not to get ink on your hands or clothing as you clean.
To prepare to clean
1. Open the HP Deskjet cover.
2. Wait until the print cartridge cradle moves to the
center of the HP Deskjet and is idle and quiet.
3. Remove the print cartridges and place them on a piece
of paper, with the copper strips facing up.
CAUTION: Do not leave the print cartridges outside the HP Deskjet for more than 30 minutes.
To manually clean print cartridge contacts
1. Lightly moisten a cotton swab with distilled water and
squeeze any excess water from the swab.
2. Gently wipe the print cartridge copper contacts with the cotton swab.
CAUTION: Do not touch the print cartridge ink nozzles. Touching the ink nozzles will result in clogs, ink failure, and bad electrical connections.
1 Ink nozzles (do not touch) 2 Copper contacts
3. Repeat this process until no ink residue or dust appears on the swab.
4. Insert the print cartridges in the HP Deskjet, and then close the cover.
on Mar 16, 2008 | HP DeskJet F380 All-In-One Printer
HP 1280 Deskjet is not printing on network
sounds like the computers are not seeing it have the drivers loaded okay,,cartridge contacts may be dirty
Jul 06, 2010 | HP DeskJet 1280 InkJet Printer
Printer won't print and resume light keeps flashing
I went through the HP troubleshooting and it started printing OK when I Stopped and Started the Print Spooling under Administration Services:
-START
-Control Panel
-Administrative Tools
-Services
-Scroll Down & Right Click on Print Spooler, Choose STOP, then OK (if needed)
-Right Click again, choose START, then OK (If needed)
After a few moments, it started right up for me and the Test Page I had in the que.
Hope this helps someone.
Mar 20, 2009 | HP Deskjet D4160 InkJet Photo Printer
Light flashing printer no print
unplug the (USB or Parallel) cable of the Printer from Printer backside which is connected to the Computer
open the top lid of the printer and check whether the carriage comes to middle or not?
It it moves automatically, then its fine.
Check the cartridges.
click the URL Link giveb below it will open a webpage. If it does not open a webpage then please copy the entire link and paste it in the address bar of the internet browser and click on "GO"
HP Deskjet 800 Series Printers - Fixing Blinking Lights
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09169&cc=us&lc=en&dlc=en&product=59305&dlc=en&lang=en
HP Deskjets - What are the front panel lights and buttons on the 800 series printers?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09133&cc=us&lc=en&dlc=en&product=59305&dlc=en&lang=en
Check the End of warranty date on both the cartridges.
Deskjet 882c printer does not support reserve mode printing.
Means, even if only cartridge is defective or expired the printer will not print with other cartridge which is fine.
Both the cartridges should in inwarranty and fine.
Shake the cartridges well
With the color and black cartridges touch a clean, slightly damp cloth (squeeze out excess water),
to the printer nozzle area on the print cartridge, to see if you can make the ink flow freely.
Be careful not to touch the nozzle area (with holes on it) on the cartridges.
Wipe the copper-colored electrical contacts with a clean distilled water or clean tap water and then with a dry lint-free cotton cloth
Also using a new swab, clean the electrical contacts inside the printer, in the carriage.
Install both the cartirdges in the printer, disconnect the printer from the computer and try to print a self test and diagnostic page
Running a sample page
Turn the printer on.
Press and hold the RESUME button until the printer starts printing.
Release the RESUME button.
Running a diagnostic test
Press and hold the POWER button.
Press the RESUME button four times.
Release the POWER button.
Nov 20, 2007 | HP DeskJet 882c InkJet Printer
No pRINT
cartridge is faulty or may be the circuit touching the cartridge surface is not clean.try to clean n reinstall cartridge.or if needed reinstall driver after that.wish u success.
Oct 17, 2007 | HP Deskjet 2360 InkJet Printer
Light is flashing
check cartridge compatibility first:- HP Deskjet 810c HP15................black cartridge compatibility HP 23 ....................colour cartridge compatibility Issue ---A print cartridge is missing. Solution Install the missing cartridge. Issue --The printer detects a faulty, incompatible, or improperly installed print cartridge. Solution 1. Open the top cover of the printer. 2. Make sure the correct print cartridges are installed. Click here to go to the printer/cartridge compatibility chart. 3. Replace or reinstall the print cartridges. 4. Close the top cover of the printer. Issue ---The print cartridge contacts are dirty and the printer does not recognize the print cartridge. Solution Clean the contact points on the cartridges with a dry, lint-free cloth. 1. Open the top cover of the printer. 2. Remove the print cartridges. 3. Clean the copper-colored contact points on the cartridges with a dry, lint-free cloth. NOTE: Do not wipe the nozzle end of the cartridge or touch the silver-colored nozzle plate on the bottom of the cartridge. 4. Use a dry, lint-free cloth to remove the moisture from the contacts. 5. Insert the cartridges back into the printer. 6. Close the top cover. 7. Try printing again.
Sep 11, 2007 | HP DeskJet 810c InkJet Printer
HP DeskJet 540 InkJet Printer Logo
177 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
