Question about Jura Capresso Impressa E8 Espresso/Coffee Maker
Jura Impressa C5 is leaking water from the front bottom corner
  • 4 Answers
SOURCE: Jura Capresso Impressa S9 water won't pull into the unit
mnbkjnjk
Posted on Jun 16, 2009
  • 3 Answers
SOURCE: Jura Impressa F50 - tray - fault 8
Hi, if you havn't already solved this one, it has been caused by pulling the drip tray/ dump box out while the brew unit was still active. Switch off the machine and insert the drip tray without the dump box. Turn the machine back on and the brew unit should re align itself.
Posted on Feb 19, 2010
SOURCE: Jura Capresso Impressa S9- no steam
I had a similar problem. I took off the side and rear cover, followed the hose that comes from the steam wand to the rear of hte unit. It enters a solenoid made by ACL Italy. I dismantled the solenoid unit by disconnecting the two hose ends, removing the relay, and unscrewing the plunger unit (vertical pipe). The plunger unit internals should move freely up and down like a piston in a cylinder , powered by a small spring. In my unit, this plunger was calcified and seized. I soaked it in boiling water and pressed on it gently several times and it unstuck. I put it all back together again and presto! Good luck
Posted on Mar 30, 2010
SOURCE: Impressa E8 water leak
Did anyone find an answer to this - sadly we have the same issue.
Posted on May 04, 2010
espressonist
  • 1711 Answers
SOURCE: Jura Impressa F9
You can find some detail procedure in this tip below
http://www.fixya.com/support/r5713182-jura_capresso_impressa_f9_malfunction_8
Try it since it have help some other with same problem.
Posted on Aug 23, 2010
My Jura Impressa C5 does not descale, automatically or manually. If I try the latter by pushing the descale button, all three upper button start flashing, instead of just the middle, with the coffee...
Dont worry about what that bloke said.
I have just had the same problem - the machine thinks it has a filter in it so take it out and follow the manual to deactivate the filter. You will now be able to rin the descale.
Aug 24, 2013 | Jura Impressa C5 Automatic Coffee Center...
It leaks clear water from the front right corner. The leak is through the front right rubber foot. How can I open the machine to take a look inside?
Hi There and Welcome to Fixya.
Usually, I too was having occasional leaks at the bottom of my coffee machine (not the same brand though) and I found out that it was caused by a clogged drain hole with coffee grounds.
Proper cleaning and maintenance can prevent this from happening so I have included the link to the very comprehensive user's manual/instructions that will help you on :
  • Identifying parts and how to do a proper teardown
  • Clean and maintain the machine
Here you go :
Jura Impressa Manual
Please let me know, and Thanks for using Fixya.
Apr 11, 2011 | Jura Capresso Impressa F9 Espresso Machine
Machine leaks, but not in the area where coffee is made. Inside there remains dry. Water appears under right front corner on counter top, but only after a coffee has been made. Seems like piping inside is...
It sounds like it may be the Diaphragm pump controls for the law including seals. The diaphragm control is located on the pump output and adjusts the line pressure, thus the water flow more even and the pump noise quieter. It is in the front right hand corner of the machine. It could also be the hose or gasket that goes into the pump diaphragm. I would start with the diaphragm pump control unit as the seals can degrade after some time.
You can order the item form: http://www.juraprofi.de/Jura-Ersatzteile/Pumpe-Fluidsystem/Membranregler-fuer-die-Jura-Pumpe-inkl-Dichtungen::2896.html it is in German so use Google translate if you are having trouble reading the page. Hope this helps. I had a similar problem. Happy holidays.
Dec 27, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
I have a Jura Capresso Impressa E8. Was working great....put in storage for a year, now water comes out of the bottom of the machine, and not the spouts. Tried cleaning with Duro solution to no avail. I s...
It may be the diaphragm pump controls for the law including seals. The diaphragm control is located on the pump output and adjusts the line pressure, thus the water flow more even and the pump noise quieter. Check if it is leaking from the front right corner, that is where the diaphragm pump control unit is. The seals may have degraded. Or it could be one of the water lines but I'd start there.
fuer-die-%3Cspan%20class=" spwrap?>Jura-Pumpe-inkl-Dichtungen::2896.html">http://www.juraprofi.de/Jura-Ersatzteile/Pumpe-Fluidsystem/Membranregler-fuer-die-Jura-Pumpe-inkl-Dichtungen::2896.html
Dec 06, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
Feb 07, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura Z5 - no water being sucked up through the system
If you are holding the filled water tank in your hands does it leak? If no then the o-ring in the bottom of the hole on the machine where the tank sits is damaged.
If yes then check the spring and o-ring on the bottom of tank.
Apr 28, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Jura Capresso Impressa E8 Espresso/Coffee Maker Logo
707 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
