Question about Sony VAIO VGN-S360 Notebook
"No Audio Device"
I no longer have any sound capabilities. Accessing the "Sounds and Audio Devices" through Control Panel, all tabs and drop down menus are grey. I went through the Device Manager to "Sound, Video and Game Controllers", and all are said to be working properly and drivers are fine. I am at a loss.
  • 64 Answers
From Device Manager, I would highlight each of the devices and then delete. Reboot and the laptop will re-detect and reinstall. Then if you see yellow exclamation marks besides of any them, you've got trouble. Make sure you are logged in with Administrator rights. You could also from Device Manager, right click and choose "scan for hardware changes" and see if that crops up anything. It's always a good idea to check the manufacturer's website for updated hardware drivers periodically, that's another way to go.
Posted on Jun 08, 2007
My computer don't any sound.
which operating system desktop or Laptop ??????....
Desktop
If your computer came with a motherboard disc the sound drivers could be on it
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers.
Click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
If this does not fix the problem
Click start control panel sounds and audio devices you can adjust the volume there also select speaker.
volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume.
Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable).
The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side.
You will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity.
Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit.
Dust causes static to build up in a computer
http://download.cnet.com/2000-20_4.html
On the home page you should see a search tab just type in what you are looking for.
Tick in either the all software or windows software box
IE: motherboard name audio driver you might have to try a few times to get it right
for windows 7
Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers.
Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software.
Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers.
Right click on the speaker icon in the bottom taskbar you will see an array of options select
playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although
once speakers are connected widows 7 should automatically update the drivers.
Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker.
You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
Laptop
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it.
If his does not fix the problem
Click start control panel sounds and audio devices you can adjust the volume there also select speaker volume.
You can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume
from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets they are usually at the side of the laptop.
You will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good with no dust as dust causes static electricity
dust causes static to build up in a computer
on the home page you should see a search tab just type in what you are looking for
for windows 7
be updated.
If you computer came with a motherboard disk the drivers could be on it although
Sep 29, 2013 | Samsung Computers & Internet
My audio cannot work,no sounds
Desktop or Laptop ?? and operating system ??
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers. Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings.
If his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker.
volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume. Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable). The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side.
sure the connection is good with no dust as dust causes static electricity. Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
Dust causes static to build up in a computer http://download.cnet.com/2000-20_4.html On the home page you should see a search tab just type in what you are looking for. Tick in either the all software or windows software box IE: motherboard name audio driver you might have to try a few times to get it right for windows 7 Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers. Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software. Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers. Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker. You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Hope this helps. Laptop If your computer came with a motherboard disc the sound drivers could be on it
If his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker volume. You can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets they are usually at the side of the laptop.
sure the connection is good with no dust as dust causes static electricity Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
dust causes static to build up in a computer http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: motherboard name audio driver you might have to try a few times to get it right for windows 7 Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated. If you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
Feb 05, 2013 | Microsoft XP Computers & Internet
I installed audio driver but speaker is not enable
Which operating system ? What type of computer Desktop or Laptop ?
for windows 7
Hope this helps
Laptop
for windows 7
be updated.
Hope this helps
Nov 19, 2012 | Intel Computers & Internet
No sound
Desktop or Laptop computer and which operaing system ??
for windows 7
Hope this helps
Laptop
for windows 7
be updated.
Hope this helps
Nov 18, 2012 | Computers & Internet
My sound is gone? The sound icon in the tray is no longer there?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
the speaker plug/outlets is usually at the side of the laptop
you will have to open up the computer to check the lead attached to the rear of the input plug make
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
for windows 7
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers
click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
hope this helps
Oct 29, 2012 | Toshiba Satellite P35-S611 Notebook
reinstall drivers
for windows 7
hope this helps
Oct 29, 2012 | Toshiba Computers & Internet
My computer no sounds
Desktop or Laptop Computer ?
reinstall drivers
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
for windows 7
Laptop
reinstall drivers
for windows 7
hope this helps
Oct 21, 2012 | Biostar NF61S MICRO AM2 SE...
I DO NOT HAVE SOUND
desktop or laptop computer ? which operating system ?
reinstall drivers
for windows 7
hope this helps
Laptop
reinstall drivers
for windows 7
hope this helps
Oct 16, 2012 | Intel Motherboard
No have sound
reinstall drivers
for windows 7
hope this helps
Laptop
reinstall drivers
for windows 7
hope this helps
Oct 04, 2012 | Dell (E210882) Motherboard
No audio
go to control panel>sound speech and audio devices>sounds and audio devices and click audio tab and see if there are any drop down options to change the microphone recording device
Jun 14, 2007 | Zio Corporation CameraMate VideoSafe...
Sony VAIO VGN-S360 Notebook Logo
75 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
