Whirlpool Model LSR8233EZ1
Washer was working just fine last night and all the sudden washer stopped during spinning cycle, it also started making this strange broken gear sound.
Inner drum does not work and cont. to make this strange sound, power is ok!
Please help.
Model LSR8233EZ1 Whirlpool Washer
  • 15,935 Answers
Transmission gearing failed or coupling.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 10, 2010
Washer stopped during spin cycle
Hello, try to checked the pump filter, and the pump is actually working. then I would suspect a draining problem.
If filter clean and pump works fine then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Thanks
Jun 04, 2010 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool type 111 model LSQ9200LQ3 washer not
I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
Jan 30, 2010 | Whirlpool Washing Machines
Whirlpool washer makes loud noise now won't spin
HI. The issue here will be with the actual motor coupler. It is damaged at this time. The clutch and coupler should be replaced asap.The coupler is responsible for transferring the rotative torque to the actual transmission(direct drive assembly). The clutch is a regulator. Once these components are replaced, the unit will operate properly.
Now. The actual parts cost will be $50.00. This includes the clutch kit, and coupler, as well. Total repair cost, if service is requested by a tech, will be $150.00, roughly.
Nov 04, 2009 | Whirlpool Washing Machines
Will not spin on any rinse cycle
Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
If you will get me a model #, I can look this up for you and give you a better idea.
Vic
Jul 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
GE Washer Knocking During Spin Cycle
remove the agitator and inspect the main shaft on the gear box.and check the belt underneath.if the shaft is bend you will need a new gearbox. hope this helps.
Feb 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Washer was working just fine last night and all the sudden it stopped. It also started making a strange broken gear sound. Washer does not spin but cont. to make this strange niose. Washer Model Whirlpool...
Your motor coupling is broken. You machine does not have a belt. this part does the job of a belt. it is between the motor and the gearcase. The part # is 285753a if I remember correctly it cost about 20 bucks . If you are handy you can do it yourself and save 150 in labor.
Jan 11, 2009 | Washing Machines
Washing Machines Logo
136 people viewed this question
Top Washing Machines Experts
