Question about JVC AM FM CD DET FACE CAR STEREO
Jvc kd-g510 wiring harness plug diagram
Need picture of plug to make a harness
SOURCE: Install JVC Car stereo
no power
Posted on Jul 27, 2008
SOURCE: JVC Wire Harness
i need to match up color wire to my 1998 honda accord
Posted on Oct 22, 2008
etirbynnor
  • 655 Answers
SOURCE: color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Posted on Apr 24, 2009
josetejas
  • 300 Answers
SOURCE: Just installed jvc kd-s16 and it loses power after
Connect Yellow to Battery (always 12V), red to ignition, and black to ground. Disconnect all others. Check it. If the radio stays on and plays CD, then radio is good. You may check other wiring
Posted on Jan 19, 2010
josetejas
  • 300 Answers
SOURCE: need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Posted on Jan 25, 2010
Installing a jvc cd player into a 99 crown vic
the best thing to do is not to cut factory wires and buy a wire harness from walmart or miejer and the wires will be color coted match up and tape them up them plug the two harness's together that is the best way to wire up a aftermarket radio
Sep 24, 2012 | JVC USB/CD Receiver with Dual AUX Input...
How do I set the clock on a JVC KD-G510 car cd player? I lost my manual some time ago. Thank you.
You can download the user manual from the manufacturer's web site at
http://resources.jvc.com/Resources/00/00/94/GET0267-001A.pdf
If you need the installation manual, you can get it at
http://resources.jvc.com/Resources/00/00/94/GET0267-002A.pdf
Dec 26, 2010 | JVC KD-G510 CD Player
I need a JVC KD-S550 wiring diagram for a 95 Saturn SC2
You do not need a wiring diagram....just go here and buy this harness, or purchase one at an electronics store. You will probably want to purchase an antenna extension adapter cable as well...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=230398679871&crlp=1_263602_263622&ff4=263602_263622&viewitem=&guid=91c6dec71250a0aad5b65db6fc08aeec&rvr_id=&ua=WXF%3F&itemid=230398679871
Dec 14, 2009 | JVC KD-S550 CD Player
Need wiring diagram for kd-shx700
Hi There, if you click on the link you'll find a wiring diagram...
http://resources.jvc.com/Resources/00/00/95/LVT1158-002A.pdf
Rich...
Aug 16, 2009 | Car Audio & Video
Connect jvc kd-lh1150 in elantra 2001... different connector
Hello claude_bouth,You need a vehicle specific aftermarket connector generally called a "wiring harness". Your JVC came with a plug that fits the back of the receiver with "pigtail" wires which you splice to the harness wires. http://www.SonicElectronix.com sells the Metra 70-7301 which appears to be the correct harness for your Elantra.You can tap into the wiring of the car harness and splice the wires by function into the appropriate car wires, but using the aftermarket vehicle specific wiring harness is a lot easier and you don't need to disturb the vehicle wiring in any way, just plug into it. It also makes it possible to re-install the factory radio if you ever need to do so. If you choose to tap and splice, you can find your Elantra's wiring color code at http://www.modifiedlife.com.Hope this helps.
Jun 05, 2009 | JVC Arsenal KD-LH1150 CD Player
Dont have wires
I had this same problem with a sony deck. Try ebay and search wiring harnes for JVC KD-SC500.
Jun 02, 2009 | JVC KD-SC500 CD Player
JVC Wire Harness
If it fits it will work, If the manufacturer stays the same so does the wiring loom.
Feb 06, 2008 | JVC KD-S5050 CD Player
Wire harness diagram
www.scosche.com will give you the cars wires, u may want to just by a harness adapter, cutting wires=bad
Don
Nov 21, 2007 | JVC KD-S680 CD Player
JVC AM FM CD DET FACE CAR STEREO Logo
129 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
