Question about Whirlpool Dishwashers
Need new control board whirlpool dishwasher 8267371
3 Suggested Answers
  • 7 Answers
SOURCE: resistor # c113 is not getting a reading and post
C113 is a capacitor so voltage differential is nill. The Triac To-220 can BTB10-600BW, in slot Q6, has as pin 2 it's ground. Pin across the heat sink tab and pin 2 and you will see continuity. Seach for NTE5637 as equivalent. Did you get the voltage at pin 1? Pin 3 is the gate.
Posted on Sep 26, 2009
  • 93 Answers
SOURCE: I have Whirlpool control board part #8267371. The
Yeah, I'm in the middle of that, too. There's a thermal fuse you can check with a meter just above the control panel inside the front door. It should be 0 ohms. Then it's the control board, I guess. Looking for the same one myself right now. I'm going to resolder the solder joints on the board and see if that fixes it.
Yup. That fixed it. Now to see how long it lasts.
The joints on the relays are hard to solder, as well as the ones to the wire terminals, because it has a polyurethane coating. You have to burn or scrape through that and just remelt the solder.
Posted on Jul 09, 2010
Won't start, green flashing light next to start button. Tightened door screws last week. How do I fix this
KITCHENAID DISHWASHER REBOOT - YouTube
? 4:17
www.youtube.com/watch?v=XJnzzXJcOV4
Sep 17, 2012 - Uploaded by DIYAPPLIANCEREPAIR How to reboot your Kitchenaid, Whirlpool, Kenmore by Whirlpool dishwashers control board. ... Up next. Dishwasher Repair will notstart - Repair & Diagnostc - Kitchenaid - Whirlpool ... Kenmore Elite Dishwasher blinking light Control Board FIX - Duration: 1:37. by ... Dishwasher Buttons Not Working?
Oct 19, 2015 | KitchenAid 24 in. KUDP02CR Built-in...
I have a Whirlpool Quiet Partner Two dishwasher. The rinse only light & quick wash light constantly blink and I can't run it, none of the buttons will work. Is there a way I can reset my dishwasher?
This generally means the control panel is no longer working and must be replaced. That's the entire plastic assembly at the top of the door, in which the buttons reside. Disconnect power first, remove screws inside the door which hold the panel in place. Unplug power connectors, remove circuit board control board. Find dishwasher model number and search parts for that model. The part is pricey, more than $100 last time I replaced mine. Install control board into new panel, make power connection. Reassemble door. Good to go.
Oct 03, 2015 | Whirlpool Dishwashers
Does a Whirlpool ADG 6552 dishwasher have a thermal cut out or re-set button? If so, where is it located? The dishwasher is dead (no lights) it stopped mid cycle. There is power up to the board and the...
how do you know there's power to the board? If the board has power but no display you need a new control board. Here you go
http://www.4whirlpool.co.uk/catalogue.pl?ss=1&path=600157&model_ref=272119&refine=board
Aug 27, 2012 | Dishwashers
My whirlpool GU2300XTSS0 dishwasher does not cycle between wash/rinse/dry cycles. It fills, washes, drains and refills in the same cycle. What can I do to solve or check for solutions to this?
This means the software in the control board is corrupt. YOu would need to try a power cycle, if that does not work, replace the control board to fix the issue. You could purchase the control board from the link below. Type your model number in the search box to look at a parts diagram.
The screws around the control panel would need to be removed and the control rotated down. The board clips into position and the ribbon cable simply plugs in. Very easy repair.
Appliance & Refrigerator Repair
Mar 22, 2011 | Whirlpool GU2300XTSS Stainless Steel 24 in...
I have Whirlpool control board part #8267371. The problem is that the dishwasher does not complete a cycle. A green light on the door will flash. From what I understand it indicates a failure in the heater...
Jan 30, 2010 | Kenmore 24 in. 16032 Built-in Dishwasher
Resistor # c113 is not getting a reading and post
Jun 11, 2009 | KitchenAid Dishwashers
There is power to the dishwasher but nothing works no lights
You have to do a bit of troubleshooting with a voltmeter. You need to make sure there is 120 volts at the connection box of the dishwasher. You cannot use a proximity voltage tester, because that doesn't identify the presence of the neutral conductor.
Then make sure that the control board also has 120 volts. Check for fuses inside the control panel. If you have voltage, at the control board, then you need a new control board
Jun 10, 2009 | Whirlpool 24 in. GU1500XT - Multiple Color...
Whirlpool dishwasher gu1500xtls2
HI, this is a control fault and you can confirm failure by shutting off the breaker switch or unplugging for 5 minutes. if the unit continues to malfunction after the 5 minute reset, you will need to replace the electronic control board.
Electronic Control board part number----8534866
May 20, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Gold dishwasher
did you check the thermal fuse in the console part #675813? its mounted on the control board white fuse w/ 2 wire leads
Jan 26, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwashers Logo
652 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
