Question about GE Monogram ZISS480NRSS 48" Built-In Side-By-Side Refrigerator (ZIS-S480NRSS, ZIS S480NRSS)
Where is the main board located in the ge monogram ziss480d
2 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: I am looking for G.E Monogram parts.
here ya go you may be able to find it cheaper looking around on the internet as well the part number is WR55X10560
Posted on Jan 21, 2009
There is a control panel reset for my GE Monogram side by side, Model # zfsb23dnss, It was "repaired" with a new board and now will not cool or freeze, HELP
There is no such button. What part # was on the replacement control board? Your model also has an INVERTER used to control the compressor... When the machine is turned "on" does the fan in the freezer and the fan near the compressor run? Is there any frost on the back wall of the freezer, or is it room temp? GE Refrigerator Main Control Board WR49X10152 .... GE Inverter Board WR49X10283 These two parts control compressor function on your fridge, the first two are the expensive parts called for by your model number- the second two are identical function, but cheaper part number!
Jul 01, 2016 | GE Monogram Side by Side Refrigerator
I have a zfsb26dnd ss GE Monogram with a Dispenser board dead. ordered a new board and same result, ordered a new main control board and still nothing has changed. what else could I check or change?
You changed the main control board---is that the main mother board on the outside back wall of the refrigerator???? If not then the mother board may need changed. Part number WR55X10942. Just about every part of the refrigerator operation runs through that board. If you did change that already I would look for possibly a bad wiring connection to the dispenser system. There is usually wiring and plugs going through the hinge area of the door with the dispenser in it. some are at the top hinge some at the bottom depending on model number.
Jun 10, 2015 | GE Monogram ZFSB26DRSS Stainless...
Ge monogram won't turn on?
Thank You for providing the model number so I was able to see what parts your refrigerator uses. Some models like yours have something called an inverter board, yours does not. Fans not working properly can also bring a heavy load on compressor causing the compressor to heat up and damaging the motherboard where you hear the clicking.The problem you are having is possibly related to the=> WR07X10074 Start Relay, e=>WR08X10052 Overload WR62X0080 Run Capacitor, and the=> WR55X11130 Main Control Board Here is another board sold at Appliance Parts Pro's=> WR55X11130 Main Control Board Assembly If you would like to do this yourself I will be glad to help answer the questions you have even assist you with installation questions. The problems you are having i typical for GE Refrigerators. If you have questions I am here. Thanks John Tripp Appliance 911
Contact me HERE
May 24, 2014 | GE Monogram ZISS480DRSS Stainless Steel
Temperature Cycles Inconsistently in Freezer and Fridge
Possible thermister our main board. Would need take readings at the board to see what the themisters are reading. If they check good then issue would be in main board
Aug 20, 2012 | GE Monogram Side by Side Refrigerator
GE Monogram ZIS480D broke again
GE refridgerators have what they call a main dome control board. This is located on the back of the machine, usually closer to one side or the other and about halfway up the machine. This board really controls everything, even as far as the dispenser in the door. I personally think this is a poor design, even though they look awesome cosmetically. Locate your model number, usually in the refridgerator side somewhere, and go to www.repairclinic.com to order the part. This is becuase they have a return policy that no one can beat. If you install the part and it doesn't work they will take it back and refund you, where as any other part distributor have a no return policy on electronic parts. Good Luck, but you won't need it. This is an easy repair
May 28, 2012 | GE Monogram ZISx480DR 48-inch Side by Side...
Ge repair man installed new circuit board worked ok for 30 days now open doors and says off in display, press minus button turns on for a while then turns off again. need help.
I would recall that GE repairman. Most likely the board he installed is defective. There is one in the display usually will not light at all when it goes out. Below is a link to that main board in the rear.
Main board
May 21, 2010 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram ZISB36DYB Freezer Not Cold Enough; Burning Center
Pull the refrig out , and remove the panel at the bottom , on the back . Behind this panel , will be the compressor and condenser " roll " coil , and the condenser fan motor . From your description of the problem , the fan motor in not operating , or the coils are extremely clogged with dust . If the fan motor is not operating , the most likely cause , is the main control board . You can try replacing the motor first , but , the board is most likely the cause . This is the electronic board , behind the 8 " X 10 " panel , behind the refrig also . If you remove the panel , and look at the board closely , You may see a burned part ( resistor ) . However , replacing the burnt part , will not solve the problem . The complete board will need to be replaced .
Oct 14, 2009 | GE Refrigerators
Jan 21, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Any tips on replacing mother board
Generally, these boards are located behind the button panel on the top of the unit. Find screws or pryouts. Be sure your fridge is unplugged before starting this operation.
Dec 21, 2007 | GE Monogram ZISS480DRSS Stainless Steel
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
