Question about Maytag Atlantis MAV6000 Top Load Washer
Get into front panel on maytag atlantis top load washer
Someone said to pop the top and pull the front panel off, i don't want to force it, how do i get the front panel off?
  • 4 Answers
There are two retaining clips located a couple of inches from each end of the top edge of the front panel. The best way to find them is to use a flathead screwdriver to wedge a small crack so you can see the retaining clips with a flashlight. Once you're certain of the exact location, you just stick the screwdriver into the clip and it will release that side of the lid. Stick something into the space to keep that one from clamping back down and then do the other one. Prop the top of the machine open and look for the two retaining screws right around the same location as the retaining clips. They are I believe 1/4" machine screws. Just take those two out and the front panel should be able to pivot forward. You need to pivot it about 30 degrees toward you then lift it off the clips at the bottom.
Posted on Jan 16, 2009
I got the top off the washer, and now I cannot find any way to open the front panel of this top loading washer. It is the Atlantis MAV9750AWW.
Most don't have a front panel. Just top panel and rear panel.
Did you raise the top panel?
There are clips there that you have to find with a flat knife type tool.
Jun 26, 2011 | Maytag Atlantis MAV7551 Top Load Washer
Maytag Atlantis leaking water, not from hoses - solution?
Hi this could be coming from a number of places. First get putty knife or possible a butter knife and pop the top. There are 2 clips holding it on they are at the top front about 2" in from the corners... Push in knife and pull up on top at the same time...Fold the top back out of the way and observe inside to see where the water is leaking. If it is coming from underneath you may need to remove the front to screw top left and right then fold out and up to remove. Observe underneath to see where the leak is.
If I can help with anything else please let me know.
Apr 13, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
How do I gat the panel off to get to the motor?
For pictures and step by step instructions, look here... www.applianceaid.com/atlantis.html
Hope this is what you need!
Bondo
Nov 12, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Can i remove the softner dispenser out of a Maytag Atlantis washer. There is a musty smell and I think this is where it is coming from.
yes you can remove both the cover the and the cup
the cover just pops off
grab it with both hands a gentle squeeze and pull tword you,, it should pop right off
then snap back in when your ready
it would also be a good idea to wash your tub once a ytear with crystal dish washer detergent
1 cup and and empty load this will help keep your outer tub clean of soap residue
Oct 23, 2009 | Maytag Atlantis MAV6000 Top Load Washer
How do you get the front off the maytag mav8601aww?
If you have the top loader, there is 2 clips on the left and right wher the front panel joins the top section. Push a flat blade in one side while trying to lift the top at the seam, it should pop open. If you raise the top there is 2 screws top left and right of the front panel inside remove these and lift the front panel up and away.
Sep 05, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water leaking from machine,trying to lift top of washer looks like hinges in back but cant seem to open
usualy there are hinges in the back and spring clips in the front, lift the front top usiing a bit of force( pry it with a thin piece of wood). make sure all the screws are off around the top , and pull out the lint fillter , there may be 2 more screws there
Jun 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Timer on maytag Atlantis
replace water inlet solenoid first if this doesnt work replace timer
Dec 08, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6257AWW
I have a Maytag Atlantis MAV6257AWW. I need to replace the transmission. So I removed all four screws from the inner tub but I couldnt get the inner tub pull out, it's stuck.
From what I read on here, the seal nut doesn't have to be remove in order to remove the inner tub.
I tried every, I even hammer the shaft down from the inside of the tub but still no luck. Can someone help, thanks.
Jun 23, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
137 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
