Washer was working just fine last night and all the sudden it stopped. It also started making a strange broken gear sound. Washer does not spin but cont. to make this strange niose. Washer Model Whirlpool LSR8233EZ1 What could be wrong! Thanks
  • alva000 Jan 14, 2009
    Thank you!
    New Friend:
  • 88 Answers
Your motor coupling is broken. You machine does not have a belt. this part does the job of a belt. it is between the motor and the gearcase. The part # is 285753a if I remember correctly it cost about 20 bucks . If you are handy you can do it yourself and save 150 in labor.
Posted on Jan 11, 2009
The machine stopped spinning and started making strange noise. The motor seems to be working, but as if something is stuck. Any ideas what it could be?
It sounds like the belt around the drum of the washer is broken. The noise you hear is probably the belt flapping
Hope this helps.
Mar 07, 2011 | Washing Machines
Last night we were washing some clothes and all of a sudden we heard a load clicking type noise. i checked the timer and it was on rinse. The water does drain but it doestn spin and it still makes the...
This washer is easy as heck to repair. Don't be scared to repair this washer.
You could have a broken brake cam driver.themobilian_1662.jpg To inspect it you remove the agitator and drop the Tranny. Hay you already had the motor and pump off there so 4 more bolts (3 for the tranny and 1 for the agitator) Slide out the tranny and check the brake cam actuator. The little ear on it breaks off and won't release the brake. The part is held with a small easy to remove C clip. The next thing to do is remove the clutch and tranny cover. Inspect the main drive gear and pinion.themobilian_1663.jpg
If that seems to be good remove the main drive gear and look for a smashed down spin pawl.themobilian_1664.jpgthemobilian_1665.jpgUnder that main drive gear is 3 spin bosses. over time the spin pawl takes a beating catching the boss as the neutral pack pauses from pump out to spin. themobilian_1666.jpgThis is the flip side of the main drive gear. Note the 3 notches. These are claeed bosses. Older model washers would spin and drain at the same time. Newer washers will allow the water to be pumped out first by keeping the spin pawl in check. A built-in pause allows the cent force to toss out the spin pawl where is can catch a boss and take off like Moody's goose in a tailwind. Nothing is hard about repairing this washer. Video, bad main drive gear:
I have a service manual and more HERE
Mar 03, 2011 | Whirlpool LSQ9600L Top Load Washer
My myo xp headtorch has suddenly stopped working. As the bulb can't be replaced, how do I fix it?
Very strange. Mine just suddenly stopped working last night as well. I have changed the batteries, but it makes no difference.
Dec 01, 2009 | Petzl Myo XP LED Headlamp
Kenmore 110 Heavy Duty 70 Series Washing Machine won't spin
Can you move the basket by hand...if so you need a basket drive. If not you have a bad clutch or gear case
Jun 07, 2017 | Kenmore 24032\24036 Top Load Washer
Motor is humming loudly.
Motors hum, and your right, it could be no worse than normal.
I would be suspect that there is a gear stripped in the gearcase, since this is a direct drive washing machine.
Reassemble the motor back onto the washer. Run it through a cycle manually (rotate the timer by hand) until the motor turns, then look to see if it's turning. If it is, or even more so, if it pumps water out of the tub, then it is probably the stripped out gearcase.
Reply with you findings and more advice.
Jan 23, 2009 | Kenmore 24872 Top Load Washer
Whirlpool Model LSR8233EZ1
Transmission gearing failed or coupling.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jan 11, 2009 | Washing Machines
Broken kenmore washer
I have a Kenmore style master model #4217013 but it stopped spinning last night. Please let me know what to do.
Mar 27, 2008 | Washing Machines
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
