Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
Generator doesn't start - Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
  • Thomas F. Schneider May 11, 2010
    Spark at plug? Gas at throat of carb?
  • 211 Answers
Hi
Check the spark at the plug,compression and carburation.Priming the engine,putb some gas in the cilinder and start the engine.If the engine runs only the gas you puted in the cilinder you have a delivery problem to find and fix.Remove the carb,disassembly and clean it,check and clean the air and gas filters.
best regards savumihai71
Posted on Feb 12, 2009
Car won't start. it tries to turn over, but just doesn't .battery replaced several months ago so it's not that. The red "GEN" light pops up. Is that the generator signal? Manual doesn&
Interesting. They haven't used generators in over 50 yrs.
But yes that was the warning light for the generator.
If you have a volt meter that would tell you what the system is doing.
If the engine will not crank, and the battery is fully charged, you would need to check the connections at the starter for voltage and ground.
And the red warning lights would normally come on until the engine starts.
Jan 13, 2013 | 1996 Jeep Cherokee Sport
Model EG5000, one year old;last fire up in March, now it doesn't start. Has fresh gasoline
i'm sure you primed it - or go get a can of ether spray in carburetor
Oct 28, 2012 | Honda EG5000 Generator
AKIRA GAS GENERATOR START BUT DOES NOT GENERATE ANY POWER
Reset overloads if tripped. If this doesn't help, inspect and replace if needed the brushes in the generator. If that doesn't help. Inspect for
loose/broken wires. Last resort is a qualifies generator repair tech.
http://www.powermate.com/productmanuals.php?cat_id=3
http://www.powermate.com/pdfs/2011/05/26/pm0106507.pdf
http://www.powermate.com/pdfs/2007/11/17/parts_pm0116000.01.pdf
Oct 05, 2012 | Coleman Powermate Premium Plus 6250W...
My Makita G5500r power generator doesn't have smooth Idle?
sounds like the carb needs to be cleaned inside any fuel the was left in the carb goes bad and it never runs it all out
Sep 06, 2012 | Electrical Supplies
Generac 20,000kW Standby generator doesn't start shows message STOP ALARM OVERCRANKED
Overcrank means that it tried to start and couldn't. It will go through 5 crank cycles and then stop with this alarm. Switch to off, hit enter to clear fault and then try to start in manual. Check to make sure you have fuel and pressure is 11 to 14 in WC.
Jun 21, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
Onan gasoline generator dies when turning on air conditioner
the air conditioner is over loading generator, and safe shuts it off so it doesn't ruin generator windings, the a/c might have worked with it, but as they wear the need more power to start up
Jun 04, 2012 | Watts Onan Portable Generator - 4000 ,...
I have an '05 Honda Civic, and we thought the battery was gone. We jump started the car, and drove it home. We fully charged the battery, but it still doesn't start. Lights are funny, and while...
if your seeing 12 volts after the charge, it doesn't mean the battery is good,, a single cell thats bad in a battery will give you fits and produce the problems you listed,, remove the battery , and have it LOAD tested, that way you will get a true correct reading, a battery can show `12 volts, but a bad cell will not let it charge to the correct amps it needs to start the vehicle. once you've done that , and your sure you have a good battery ,, start the vehicle,, ( make sure that when you replaced the battery , that all the connections are clean and tight) with a meter, place one lead on each battery terminal, you should get a reading between 13.5 and 14.5 volts, if you do , then your alternator is doing its job, if not,, replace the alternator, ( your vehicle doesn't have a generator)
Sep 18, 2011 | 2005 Honda Civic
I have a yamaha EF2400IS generator that starts fine, but when i shut it down and try to restart it hot it will not start up again until it cools down. Please help.
If it doesn't start but turns over ok. It may be a problem with the magneto / wiring or spark plugs. It seems as though this unit has no automatic shut down. I would try replacing the spark plugs BPR4ES NGK or equivalent and gap to .030, oil 5/30 or 10/30 will do takes less than 1 quart, & air filter (basic tune-up) if not performed in some time. Yamaha recommends every 20 hours. Then try again. Here is a link to the owner's manual. http://www.poweredgenerators.com/yamaha/manuals/ef2400is.pdf
Jul 23, 2011 | Yamaha EF2400iS Portable Generator
The generator doesn't turn off after transfering power back to the utility
The transfer switch is responsible for starting / stopping the generator. Check your auto - start circuit. It is 2 wires that go between the genset and ATS. They are generally normally open. When the genset is to shut down this circuit needs to change state.
Jul 09, 2011 | Briggs & Stratton Briggs Stratton 7 kW...
Generator starts than shuts down on under voltage
The problem is related to the engine. When a load is put on the generator, the engine's throttle will want to open to maintain RPMs. If your carburetor is misadjusted or gummed/varnished, when the throttle opens, you will get a fuel starvation and the engine will die. If the generator is used regularly and hasn't sat for a while, first check to make sure the spark plug is good since you don't want to make a carb. adjustment using a worn plug. After you adjust the carb. manuallly flick the throttle to ensure that the engine doesn't 'stutter' or die out. If it does, increase the gas in the air/gas mixture and if that doesn't solve it, remove, disassemble and clean the carburetor.
Jun 30, 2011 | Generac Electrical Supplies
Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
588 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
