Question about Philips Cineos HTS9800W System
DVD keeps ejecting
When I put a dvd into player it ejects them straight away
jackboy
  • 2985 Answers
SOURCE: DVD will NOT eject!
Looks like it will have to come apart. Can you see how? Usually the top/side casing is simply 5/6 screws 2 each side and 1/2 at the back then slide back away from the from panel. Technical help at Philips may be helpful.
Posted on Jul 02, 2007
SOURCE: dvd player won't open
I had the same problem for my panasonic dvd player (ht540). Neither of the above solutions worked so I found this one on the panasonic website:
1. turn off unit by holding down the POWER button for 10 seconds.
2. unplug the power cord and wait for one minute.
3. plug the cord back in and turn on the unit
4. when the dvd begins to play, press "EJECT".
It worked for me. The site for other troubleshooting is:
http://www2.panasonic.com/consumer-electronics/support/FAQs/details-FAQs+for+DVD+Recorders-UCM_PRD_CNT_001989#dvdrec6
Peter
Posted on Nov 16, 2007
SOURCE: DVD load / eject problem
This is a solution to all those who have either a DVD which does not load and which cannot be ejected and also to those who have the system stuck in MP3 mode. The solution is the same for both problems. Unfortunately due to the design of the HTS6510 it’s not a simple job but if you are methodical and take your time then most people should be able to do it.
 I personally think the problem stems from dust building up on the laser. I noticed that the extraction fan at the back of the unit draws air, partly, in from the front slot and over the DVD and (Sony) laser.
Anyway I’ll talk you through what I did but please be aware that this is not a screw by screw, connector by connector account.
You’ll need a small torx screwdriver (the unit is put together almost exclusively with a single torx screw size),  a very small Phillips screwdriver and a pair of snipe nosed pliers. Also a couple of small bowls to hold the screws in will be a good idea.
Firstly make sure the unit is disconnected from the mains. Then begin by undoing  the four torx screws at the back of the unit which are holding the cover on. Then remove the silver plastic side sections by sliding them towards the back of the unit. Under these you’ll see two more torx screws to be removed on each side. Remove these and you can then remove the top cover.
Have a look at the first attached picture. You should see the same thing with the lid off the box. I’ve labelled all of the assemblies up. There are four circuit boards which are arranged two on the top and two underneath these. You will be removing the top two (Audio amplifier board and the power supply board).
The aim of the game is to move the front section (the bit with all the control buttons on) away from the main section so that you can get access the to the DVD housing (this is the player unit where your DVD is housed). The front section is attached to the main section by four plastic clips (the plastic barb to metal slot type). Two are accessed from the base of the unit and more on each side. Don’t unclip these yet because the circuit boards are attached by ribbon cables which attach to the front of the unit . It is these ribbon cables which must be disconnected before the front can be unclipped and access can be got to the DVD unit. There are also a couple of bonding leads which attach the front of the unit to the ain chassis. These have small spade (push on) connectors and are very simple to remove.
You don’t need to disconnect all of the ribbon cables – just enough for you to be able to swing the front of the player out of the way.  Make sure you mark any connectors which you disconnect in some way so you remember where they connect to when you re-assemble the unit. I used a permanent marker to put a series of dots on the ribbon end of the connector and board end of the connector. (i.e. one dot on each denotes a pair, the next pair has two dots etc etc.)
Some of the leads which you will need to disconnect are attached to the two processor  boards which sit below the two uppermost circuit boards. Gain access to these by removing the four screws (one on each corner) holding the power supply board onto its mounting (there is also a nylon support in the middle of the board – squeeze it with a small pair of pliers to release the board).
Next remove the black plastic insulator sheet below the board. With this board removed, the metal shelf which the Audio amplifier board is attached to can now be removed. Note that some of the screws on the external back of the unit will also need to be removed before you can do this. You don’t need to take the audio amplifier board off the shelf – just remove the shelf and audio  amplifier board together.
You should now have an assembly which looks like my second picture. As with the top two boards unplug the connectors on the boards to allow the front section of the dvd player to be moved away from the main part of the system. Again don’t forget to mark the connectors so you know how to re-connect them.
If you have got this far you are doing very well!  I then undid the four screws holding the dvd housing and unshipped the entire housing, but with hindsight this wasn’t necessary. There are four Phillips screws holding the top cover of the DVD housing on. Remove these with your Phillips screwdriver and lift off the lid.
You can now remove the DVD / CD. At the same time carefully remove any dust which has accumulated in the DVD housing. Take care not to damage the delicate lens or its assembly. I used a dry cotton bud but a blast of dry air or a lens cleaning brush would be an even better choice.
Once the dust is removed refit the cover the DVD housing and assembly is basically a reversal of the dismantling. Once its all back together switch on and they system will be back to normal. If it doesn’t switch on – open it up and recheck your connectors – most likely one of them isn’t properly engaged.
Posted on Nov 02, 2008
SOURCE: DVD loaded into player,system says no disc and
I had this same problem and fixed it by unplugging main power cord from back of unit for 30 minutes and voila, seems fine again
Posted on Aug 01, 2009
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
The DVD player is in constant eject mode - discs will not stay in to play. It has worked perfectly for years. Tonight I was watching a disc, finished, ejected it and put in another and the player just...
Two possible scenarios: First the optical pick up assembly that read the disc has malfunctioned or the eject button is faulty. Either way it is just cheaper to replace the DVD player with a standalone dvd player connected to one the tv input(s). Too expensive to repair just the dvd player if it is tv/dvd combo. The cost for labor and parts is more expensive these days to repair tvs or dvd player. For around $30 you can just replace...much more cost effective.
Aug 15, 2009 | Sylvania 6620LDF 20 in. EDTV-Ready LCD...
DVD player wont eject
Try Turning the unit off and then back on. As soon as you turn it back on push eject .
Jul 25, 2009 | Audiovox VOD102 Car DVD Player
DVD won't eject from magnavox MWD2206
Do u see a small hole in the front plate of the dvd player?
if you do ur in luck, unravel a large paper clip to make it straight, then very slowly push it straight into the hole until you see the dvd open.
If no hole then u will have to open the case while it is unplugged.
May 24, 2009 | Philips MWD2206 DVD Player/VCR
DVDS stuck in overhead DVD player
the motor will not be strong enough to eject. you can try the emergency eject hole with a paper clip . just push straight in and the gears will began to turn so push straight in a couple of times and it should began to eject.
Dec 13, 2008 | Jensen 8.5'' Overhead DVD Player Package...
Dell inspiron 2200
at the front panel of the dvd drive where u normally press the eject button look carefully u will find a very small hole some where in around the eject button. now look for a broom stick or any tiny but straight object that can go in through the hole. put the broom stick into the hole gradually not with force. the dvd player will eject if it doesnt eject then i dont know.
to replace a new dvd player u just unplug the formal one from yr system and insert the new one thats all. make sure no screws r holding the dvd player b4 u do so.
hope this helps
do come back n tell us if don
thank u
May 26, 2008 | Dell Inspiron 2200 Notebook
Video keeps ejecting
put tape over the VHS portal as soon as you put it in then it will not be able to get out
Oct 22, 2007 | Samsung DVD-V4600 DVD Player/VCR
DVD (JVC XV-S502) Does not eject dvd. Word "lock" appears in screen
hey, this happened to me too. what you have to do is put it in standby mode, then press and hold the eject and stop button on the actual dvd player, the remote wont work doing this. this is how you can unlock and lock the dvds into the dvd player. why this is a feature jvc thought this needed im not exactly sure, but thats how you fix it.
Aug 11, 2007 | JVC HR-XVC19S DVD Player/VCR
Philips Cineos HTS9800W System Logo
19 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
