Question about Ovens
Hotpoint EW93 Cooker went bang and now oven wont heat up
  • 338 Answers
SOURCE: oven not heating
you could have lost one of your 120v leads to the machine. that could cause it to work only half way. go turn the breaker off and then turn it back on and see if that corrects the problem.
Posted on Dec 07, 2008
barkencoa
  • 3463 Answers
SOURCE: My hotpoint bs32 oven went
The fan oven element has failed, you need to replace it with a new element.
You need to remove the inner rear cover of the oven.
There you will see the element..
Unscrew and disconnect the leads and refit new element, be care ful not to lose the wires behind the element aperature.
Plz rate my solution.
Thanks.
Posted on Jan 05, 2009
amgm
  • 32 Answers
SOURCE: neff cooker not heating up
Hi, it feels like your oven element has gone.
switch it off from the mains, open the door and remove the screws fixing the back panel. You will find a round two turn element. Unscrew the element fixings and check the element for burnt marks, corrosion. If you have a multi meter, turn it to buzzer and use the meter leads to test the element connections. If it doesn't buzz, it's dead. Just needs replacing.
Cheers
Posted on Feb 15, 2009
hattonhall
  • 349 Answers
SOURCE: hotpoint oven bu72 gave out loud bang when cooking
Sounds like the element has internally shorted to earth and will have to be replaced by a qualified Techo.
While this may have caused a fright...think how lucky you are that the Safety Switch was invented as a fail safe lifesaver!
Posted on Oct 25, 2009
Testimonial: "Thanks for prompt response - will contact Hotpoint Service Centre tomorrow a.m."
barkencoa
  • 3463 Answers
SOURCE: hi.i have a hotpoint creda c362e cooker the rings
Hi.
Frpm the sympton's you list, I would say that the main oven element has failed, espsecially if the fan is working o/k.
The element is located at the rear of the oven compartment behind a removeable cover.
In addition to the grill elements in the top oven compartment, there is an additional base element which you can't see.
If you turn the top oven on, the base of the compartment should get hot, if it does not, then the base element has probably failed.
Hope this helps.
Posted on Jan 09, 2010
My Hotpoint SY36 oven has started making a clicking noise behind the control panel. The temperature light does not come on although the oven does heat up still.
If you have a problem with your hotpoint cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Dec 11, 2014 | Hotpoint SY36 Style Line Stainless Steel...
Light is flashing reading Err 08 on electric oven model EW93 cuts main oven off?? why is this
Error code F08 is indicating that the heater relay is not being activated.
You need to check all the connections on the module, the pressure switch, and the heater element.
Mar 18, 2011 | Hotpoint Ovens
The main fan assisted oven on a Hotpoint BD35 double oven stopped working so I replaced the element, thinking that would be the obvious answer. Unfortunately it is still not working and I notice that the...
Is there a black pole sticking out that goes in when you close the door, my Hotpoint freestanding cooker has it on the right hand side, once this is pressed in the fan and heat starts, i had to replace it on my cooker as it went faulty and stopped things working (all I had was the main oven light on, these are usually like a little black box that are situated on the side of the oven just behind the main metal panel on the outside and will normally have 2 pull off spade connectors connected to it.
i don't have the same model as you but hopefully this mig help you.
Oct 22, 2017 | Hotpoint DY46 Style Line Stainless Steel...
No heat from cooker
If the fan is working o/k, then it is probably a faulty heater element.
This is located at the rear of the oven behind a removeable cover.
Please rate my solution.
Thankyou.
Feb 07, 2010 | Hotpoint SY36 Style Line Stainless Steel...
I have a Hotpoint EW86X Electric cooker, I went to change the element and one of the cables that connects to the element disappeared down the back of the cooker, any ideas of how I can get to the cable?
Only by removing the rear outer panel of cooker, this will give you access to the element terminals..
If it is built in, then it will have to be removed from the housing.
Hope this helps.
Jan 12, 2010 | Hotpoint Ovens
Cant set cooker clock so cant use oven as a result
You will probably have to replace the cooker clock. Do any of the other parts work? This fortunately is not that expensive and you were blessed not to have more damage than this.
Jan 29, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Oven not heating
Dec 07, 2008 | Hotpoint SY36 Style Line Stainless Steel...
EG73 Hotpoint Oven heating when switched off
sounds just like hotpoint customer service "fob off"
your fault sounds more like the selector swich shorting out going by prev repairs i would isolate the cooker straight away and investigate.
ps. would not leave cooker powered up if not in use until fault repaired
Feb 28, 2008 | Ovens
Hotpoint electric cooker sy36
it sounds like you have had bad insalltion caused by your element becoming open circit try replacing and this should solve your problem regards jason
Sep 13, 2007 | Hotpoint SY36 Style Line Stainless Steel...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
