Question about Music
Hi, can you tell me why half my roland jv-2080 display screen has half faded... one half is good and other is going blank? Is this a serious problem or can Roland fix? Thanks
SOURCE: i need a power transformer for roland sde -3000
I need a transformer part 32 no:11-32-000 class 2 ac power transformer mod:mw48-090200a Input:120 ac 60hz output:9vac 2000ma.
(UL) US Ite powuer supply made in japan
Posted on Apr 23, 2009
slave2aslave
  • 302 Answers
SOURCE: Roland E-86 manual
diplodocs.com has a download for that manual
Posted on Sep 22, 2009
  • 1138 Answers
SOURCE: what is better, roland e-09 or roland e-14?
Here is the spec sheet for the Roland E-09:http://www.rolandus.com/products/productdetails.php?ProductId=828 The Roland E-14 was manufactured in 1996 and the specifications are not easily available on the internet. If you are considering buying one (E-14) make sure it is in good shape with everything working and you can get it cheaper than a new E-09. If you really want to compare you will have to find a manual for a E-14 and download a manual for a E-09 and compare the features side by side. If you have an E-14 and are considering purchasing a new E-09 find a local dealer who is selling the new one and see if you can take yours there and compare them side by side. Comparison should be a personal decision. I might like a Chev and you might like a Ford. You pretty much have to decide for yourself. If you are buying one look at your budget and compare other keyboards with similar features. Also consider whether the amount of playing you will do might justify saving up some money to buy a higher end Roland if you are particular to Roland. Let me know if this helps.
Posted on Dec 03, 2009
  • 5 Answers
SOURCE: My roland xp-50 keyboard is dead.
Ok guys. Just got mine XP50 fixed with the "No Display" problem. The LCD screen was blank without text and only shown orange color. The problem is one of the capacitors on the main board was dead. I have replaced all 3 caps on the main board and the problem is solved and if you are a little handy on soldering, you can do it yourself. The 3 caps you should replace are:
- C901 (I used 16V 330MicroF)
- C65 (I used 5V 4.7 MicroF)
- C 902 (I used 16V 330 MicroF)
Posted on Mar 07, 2010
  • 74 Answers
SOURCE: roland hp550g digital piano has a couple of dropped keys
Power off the unit. Disconnect all cables that plug into the speaker base if you have one - It may be wise to document the individual wires to make their reinstallation easier. Remove the unit from the speaker stand and lay it on the floor on something like an old towel - you may get some dark colored grease on the rug. Remove the screws only for the bottom rear, not the front - you don't need to remove them. Do this by gently turning the unit upside down. Only remove the screws from the sides/rear bottom, and note which screw types you removed from where. Once all bottom rear screws are removed gently return the unit right side up. now pivot the top rear cover - the sides of the cover are attached to the rear - pivot it toward the back. No need to remove the ribbon cables - just let the top lay there or prop it up with something if the ribbon cables don't have enough slack for the top cover to lay flat on its back. You should now be looking at all of the keys uncovered. notice the rear of each key is where it hinges. You'll notice the grease at the hinge point. The keys are thin plastic so you must take care not to damage them. The way to remove a key is to spread the ears at the hinge point of the key you want to remove. I use a screwdriver sharpened to a point, but a large pair of needle nose pliers work good too. You insert the tapered point of the tool between the ears gently to spread them far enough to just clear the pins. Once they are spread wide enough you'll feel them disengage. Each key also has two hooks located side by side towards the front of the key on the bottom side - they are not visable until the hinge is released, but you must realise they are there or you'll either snap the key back onto the hinge or not be able to pull the key out once you've got it off the hinge. Pivot the key towards you to remove it. What you now have in your hand is not the defective part. You have the top that is touched when playing the keyboard. The defective part is still setting in the mechanism. What's actually happened is the keys are made of very thin plastic where they are glued around the weight and this plastic breaks leaving the weighted end down there somewhere. Examine where the key top came from and how it works. The key top is the part you took off of the hinge. You can see how the keys on each side work and you'll also see what is missing from the mechanism for the key you're working on. To make things easier I always remove one additional key top on each side of a key that I repair to make access easier. Just place the other keys you remove right behind the key area in the order you took them off so it'll be obvious how they go back on. Now the broken weighted mechanism you can lift right out. Actually you can lift it out easier with the weighted end broken off, but once you glue it back together you can still get it in there without to much trouble. You only need to remove the damaged weighted mechanism for the key you're repairing. I remove the key tops on each side of the damaged key for visability only. Take your pair of needle nose pliers and pick out the broken end. Now fit it onto the end of the weighted mechanism in preparation for glueing - just so you can see how it's going to go on there. I use a high quality modeling super glue. Before I came across this glue I used JB Weld, but it takes a few hours to dry. The high quality super glue allows you to put everything back together immediately. Installation is reverse of removal: Snake the weighted mechanism back in once you've repaired it - you can always examine those on each side if you get confused. Hook the key top front first then smoothly snap in place the hinge ears over the pins. Make sure to check the movement of the repaired key, and check also to see if anymore keys are setting lower as they may be in process of breaking off. Once all keys are repaired, carefull lower the top rear cover onto the key assembly. While holding the cover onto the key assembly/base, gently turn the unit over onto its back and reinstall the screws. Should be all washer headed screws - do not over tighten. Check the keys again. Set the keyboard onto its base (if it came with one) and you're done. A little practice and it'll take you less than a half hour to fix the key and get it back together
Posted on Sep 23, 2010
Can anyone tell me how to adjust the pitch bend range on a Roland JV 2080?
Software, download the Owners Manual and get into it.
Nov 30, 2017 | Roland Music
My screen is out on my roland jv 80 keyboard
This problem will require servicing. The screen is bad, and has to be replaced.
Apr 18, 2014 | Roland Music
Roland pad 80 is it normal for the lcd display to show a bar of squares and nothing else when pluged in to power and not pluged into anything else?
The Roland Pad 80 has a contrast control, if it's not correctly adjusted, it could cause it to appear all black or all blank.
If the LCD were bad, it's uncommon for both sections to both go out around the same time, since it uses two seperate 7 segment LCD components. About the only way to cause both to go out at about the same time, would be to get the equipment wet, or let it get way too hot or left sitting out in the sun, long enough to dry up the "liquid" part of "Liquid chrystal display".
Oct 15, 2013 | Music
When I switch on the power in the roland HPD 15 handsonic, the number screen in the centre has the light but is blank, and the semicircle which has the numbers for different percussions has two lights on...
I had this problem and was about to send it back to Roland but tried a Factory Reset . It managed to fix it self but it has happened again so I woul dbe interested in finding a more perminnat solution .
Did you fix the probolem?
robin
Jan 23, 2012 | Roland Elektronische Musikinstrumente...
Where can i get a screen replacment for the juno g ? and how much is it?
You will have to go to Roland parts to get the item and the price will vary depending on your location. The display is going to be expensive... Here is a site...
http://www.instrumentalparts.com/rojuglcdscju.html
$205 it looks like... I would contact Roland directly first. Use google to find their contact info.
Apr 11, 2011 | Roland JUNO-Gi 61-Key Mobile Synthesizer...
Screen on roland td7 lights up but is blank
Look for a contrast control for the display... often a small tweek shaft that comes out of the case. This is only if the thing operates but has no display.
Oct 19, 2010 | Roland Pd 8 Dual Trigger Pad
Apr 07, 2009 | Music
Music Logo
97 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
